查看: 3256|回复: 1
物理内存2G,但pre_memory只能设到1200M。求教!
发表于 2007-3-3 22:25 | 显示全部楼层 |阅读模式
我的机器是2G的内存,但是standard_memory设到大于1200M时就出现如下错误。 监视系统中内存分配情况没发现什么问题,不知道朋友们有没有碰到这种情况的,大家谈谈看法。谢谢了!
***ERROR: THE REQUESTED MEMORY CANNOT BE ALLOCATED. PLEASE CHECK THE SETTING
FOR PRE_MEMORY. THIS ERROR IS CAUSED BY PRE_MEMORY BEING GREATER  THAN THE MEMORY AVAILABLE TO THIS PROCESS. POSSIBLE CAUSES ARE  INSUFFICIENT  MEMORY ON THE MACHINE, OTHER PROCESSES COMPETING FOR  MEMORY, OR A LIMIT ON THE AMOUNT OF MEMORY A PROCESS CAN ALLOCATE.
发表于 2007-3-5 12:04 | 显示全部楼层
看ABAQUS DOC就知道了
The maximum amount of memory that can be allocated by the ABAQUS/CAE and ABAQUS/Viewer kernel. If the limit is exceeded, ABAQUS/CAE displays an error message. The abq_ker_memory must be specified in MB (megabytes) and is used only for 32-bit systems. For Windows 32-bit systems the default is 1800 MB; for Linux 32-bit systems the default is 2800 MB.
Increasing the memory limit is not recommended unless you are using a Windows 32-bit system with the boot option /3GB /userva=SizeInMBytes to extend the amount of memory available for ABAQUS/CAE. In this case the limit can be changed to 2800 MB (the same as Linux).
GMT+8, 2025-1-19 23:15 , Processed in 0.075759 second(s), 18 queries , Gzip On.
