查看: 1903|回复: 3
[数学理论] 有同事在做图论吗?
发表于 2007-2-1 20:42 | 显示全部楼层 |阅读模式
因为做混沌同步,要用到图的Laplacian谱,有些知识不太明白,需要请教。
发表于 2007-2-4 01:59 | 显示全部楼层
什么问题?几年前学过一点,简单的可能知道些
 楼主| 发表于 2007-2-8 21:30 | 显示全部楼层
这是我在Yahoo Graph Group 中问的,可还没人回
Given a graph G(E,V), |V|=n,its Laplacian matrix L=D-A, the second
smallest eigenvalue Lambda_2 of L is called algebraic connectivity.
Assume X= (x1,...,xn) is the corresponding eigenvector of Lambda_2.
My Question is:
If |x1-x2| is the maximum among all difference of |xi-xj|,i,j=1,...n
can we deduce that vertices 1 and 2 have the longest path among all pair of vertices? Is the inverse true?
发表于 2007-4-18 03:16 | 显示全部楼层
没太看明白你的问题,不好意思
GMT+8, 2025-1-10 16:14 , Processed in 0.052251 second(s), 17 queries , Gzip On.
