查看: 3678|回复: 5
[综合讨论] Runtime error 报错不能运行呀
发表于 2007-1-26 09:04 | 显示全部楼层 |阅读模式
兄弟姐妹s,紧急求助,以前我的matlab运行很好的,可是前几天突然打开matlab时弹出对话框Runtime error 报错不能运行呀,请问怎么处理?现在一直不能运行怎么办???
我重新安装了n次都还是遇到同样的问题。。
ps:我给matlab 客户,技术支持 部门写信问题怎么解决,不过他要序列号许可码,由于大家都知道的原因,这样我就没办法找他们了
报错对话框的信息如下:
Runtime error!
Program: F:\MATLAB6P5\BIN\WIN32\MATLAB.EXE
This application has requested the Runtime to terminate it in an unusual
way.Please contace the application's support team for more informations.
同时,命令窗口显示的信息如下:
       Segmentation violation detected at Thu Jan 25 15:13:43 2007
Configuration:
  MATLAB Version:   6.5.0.180913a (R13)
  Operating System: Microsoft Windows XP
  Window System:    Version 5.1 (Build 2600)
  Processor ID:     x86 Family 15 Model 2 Stepping 9, GenuineIntel
  Virtual Machine:  Java 1.3.1_01 with Sun Microsystems Inc. Java
HotSpot(TM) Client VM
    (mixed mode)
Register State:
  EAX = 00000000  EBX = 14273b50
  ECX = 00007fff  EDX = 00000501
  ESI = 144691a8  EDI = 00dfd238
  EBP = 00dfd228  ESP = 00dfd204
  EIP = 7900ea88  FLG = 00010202
Stack Trace:
  [0] MFC42.DLL:0x7900ea88(0x00dfd238, 0x14273a10, 0x7909f368, 0x7909d674)
  [1] MFC42.DLL:0x79065b7e(0x7a541db4 "MatlabCommandState", 0x14273ad0,
0x14273a10, 0x7a4fb3c0)
  [2] uiw.dll:protected: int __thiscall
CCmdFrame::CreateToolBar(void)(0x14273a10, 0x00dfd54c, 0x00dfd334,
0x79001d42) + 179 bytes
  [3] uiw.dll:protected: int __thiscall CCmdFrame::OnCreate(struct
tagCREATESTRUCTA *)(0x00dfd54c, 0x14273a10, 0x14273a10, 289392) + 96 bytes
  [4] MFC42.DLL:0x79001d42(1, 0, 0x7a535f08, 0x00dfd350)
  [5] MFC42.DLL:0x79001b63(1, 0, 0x00dfd54c, 0x00dfd54c)
  [6] MFC42.DLL:0x79001aec(0, 590480, 1, 0)
  [7] MFC42.DLL:0x79001a74(590480, 1, 0, 0x00dfd54c)
  [8] uiw.dll:long __stdcall AfxWndProcDllStatic(struct HWND__ *,unsigned
int,unsigned int,long)(590480, 1, 0, 0x00dfd54c) + 46 bytes
  [9] USER32.dll:0x77d13a5f(0x7a531500, 590480, 1, 0)
  [10] USER32.dll:0x77d19797(0, 0x7a531500, 590480, 1)
  [11] USER32.dll:0x77d15874(0x00f3dcd8, 1, 0, 0x00dfd54c)
  [12] USER32.dll:0x77d19a87(0x00dfd524, 184, 184, 58)
  [13] ntdll.dll:0x77f5108f(0x80000000, 0, 0x00dfdb3c, 0x00cf4000)
  [14] USER32.dll:0x77d1add9(0x80000000, 0x00046ac8
"Afx:7a4f0000:b:10011:6:6d0325", 0x00dfdb3c, 0x00cf4000)
  [15] USER32.dll:0x77d11505(0, 0x00046ac8 "Afx:7a4f0000:b:10011:6:6d0325",
0x1445e698 "MATLAB Command Window", 0x00cf4000)
  [16] MFC42.DLL:0x7900c486(0, 0x00046ac8 "Afx:7a4f0000:b:10011:6:6d0325",
0x1445e698 "MATLAB Command Window", 0x00cf8000)
  [17] MFC42.DLL:0x79012050(0x00046ac8 "Afx:7a4f0000:b:10011:6:6d0325",
0x1445e698 "MATLAB Command Window", 0x00cf8000, 0x790d42b8)
  [18] uiw.dll:public: virtual int __thiscall CCmdFrame::LoadFrame(unsigned
int,unsigned long,class CWnd *,struct CCreateContext *)(129, 0x00cf8000, 0,
0x00dfdd90) + 107 bytes
  [19] MFC42.DLL:0x79011c7d(0x1445e508, 0, 1, 0x0047f617)
  [20] MFC42.DLL:0x79016360(0, 0, 1, 0x0047f617)
  [21] uiw.dll:_MSWCreateCommandWindow@8(0x00dfde08, 0x7a541794 "MATLAB
Command Window", 0x0047f617, 1) + 50 bytes
  [22] uiw.dll:_opnCmdWnd(4194304, 1, 0x7a541794 "MATLAB Command Window",
1) + 24 bytes
  [23] uiw.dll:_uiwSetupWindows(4194304, 1, 1, 0) + 131 bytes
  [24] matlab.exe:_WinMain@16(4194304, 0, 271244, 1) + 3819 bytes
  [25] matlab.exe:_WinMainCRTStartup(0, 1, 0x7ffdf000, 0xef2e9cf4) + 308
bytes
  [26] kernel32.dll:0x77e5eb69(0x0047172c, 0, 0, 0)
Please follow these steps in reporting this problem to The MathWorks so
that we have the best chance of correcting it:
  1. Send this crash report to segv@mathworks.com for automated analysis.
     For your convenience, this information has been recorded in:
       C:\DOCUME~1\ZHANG\LOCALS~1\Temp\matlab_crash_dump.3500
  2. Also, if the problem is reproducible, send the crash report to
     support@mathworks.com along with:
       - A specific list of steps that will reproduce the problem
       - Any M, MEX, MDL or other files required to reproduce the problem
       - Any error messages displayed prior to this crash report
     A technical support engineer will contact you with further
information.
Thank you for your assistance.  Please save your workspace and restart
MATLAB before continuing your work.
发表于 2007-1-26 12:04 | 显示全部楼层
是不是被检测出来是盗版,不让用了啊
没遇见过这种情况,猜测的
 楼主| 发表于 2007-1-26 13:25 | 显示全部楼层
原帖由 mulan 于 2007-1-26 12:04 发表
是不是被检测出来是盗版,不让用了啊
没遇见过这种情况,猜测的
应该不是,
因为和我同一个实验室的师兄使用的是同一个matlab版本 , 并且使用的很好。。
 楼主| 发表于 2007-1-29 11:31 | 显示全部楼层
难道没人懂嘛????
发表于 2009-6-21 08:56 | 显示全部楼层
现在解决了吗?
我也有这样的问题,还没解决,你要是知道怎么办了给我说一下吧!
邮箱:zqszmd@sina.com
发表于 2009-6-21 09:03 | 显示全部楼层
呵呵!解决了!
之前用过一些仿VISTA风格的主题包,需要修改系统资源,因此感觉是系统资源被改后matlab无法识别,于是把系统主题还原为XP类型或其他非VISTA类型,问题就得到了解决[1]。
但是这样一来就不能使用漂亮的VISTA主题了,难免有些遗憾。今天忽然想找找别的解决办法,在网上搜寻网友们的方法,结果发现有效的也只有更换主题这个方法。没有参考,只能靠自己搞。使出了运行软件无效时的常用方法之一:超级用户,竟然奏效。点击Mablab图标,右键-〉运行方式,在弹出对话框中,选择系统管理员Administrator运行程序,就能够正确运行Matlab[2]。
GMT+8, 2025-1-11 17:03 , Processed in 0.080299 second(s), 18 queries , Gzip On.
