查看: 4538|回复: 2
[Nastran专区] 为什么会出现BDF_WARNING_MPC_SPC_CONFL?
发表于 2007-1-4 09:58 | 显示全部楼层 |阅读模式
在提交分析计算时,弹出这个对话框:
MSC.Patran has found nodes for which both SPCs and dependent MPC relationships exist. MSC.Nastran will not accept such a specification.  The affected nodes have been placed in a group by the name of "BDF_WARNING_MPC_SPC_CONFL".  You may choose to proceed with your specified course of action provided that there are no other problems, or you may choose to bypass the job submission, if requested, and modify the database.  If you choose to proceed, the SPCs for the affected nodes will be omitted, thus creating an analysis deck that MSC.Nastran will accept, but which may not conform to your modeling specifications.
If you choose "YES", MSC.Patran will complete the requested tasks, including job submission, if no other problems are present.
If you choose "NO", the analysis deck will be translated, but no job submission will take place.
我已经把开始建立的MPC删除了,提交分析计算,还是这样,为什么?
模型为对称的,取一半,背部固定123456自由度,对称面约束345自由度,圆孔面加total load 1000N,端面加total load 2160N.
BDF_WARNING_MPC_SPC_CONFL组内显示出两个节点node26 ,node33.
发表于 2007-1-4 10:02 | 显示全部楼层
在load/BCS步骤加边界条件时,dependent面上的节点不要加约束
 楼主| 发表于 2007-1-5 09:46 | 显示全部楼层
楼上说的“dependent面”是对称面吗?
   如果是的话,BDF_WARNING_MPC_SPC_CONFL组内不应该只显示出两个节点。
GMT+8, 2025-1-6 17:57 , Processed in 0.080554 second(s), 21 queries , Gzip On.
