查看: 3898|回复: 11
[综合讨论] 请教ATV的计算
发表于 2006-12-16 16:16 | 显示全部楼层 |阅读模式
本算例利用ATV计算板的声辐射。
总是到最后的 计算场点的时候,其他都正常。
提示的错误为:
ANALYSIS NUMBER     32 /     37                FREQUENCY =    175.000 Hz
CPU Stats --- Delta:  0:00:00 (      0.00)  Total:  0:06:39 (    399.12)
LOADING POTENTIALS    FROM DATABASE at Frequency    175.000 Hz
ERROR - CANNOT FIND RECORD OF TYPE POT1
ERROR - COULD NOT FIND POTENTIALS AT     175.00 HZ
附件为模型文件和命令流。
    请大侠指教。:handshake
ATV.cmd
  1. New Model 1 File ATV_structure.sdb Return
  2. Option  FEM Frequency Structure Return
  3. Import Mesh Format Free File plate.fre Return
  4. Geometry Thickness 0.001
  5.     Elements All
  6.     Return
  7. Material Plate
  8.     Name 'steel'
  9.     Young 2.1e11  Poisson 0.3  Rho 7800
  10.     Elements all
  11.     Return
  12. Save Return
  13. Set Name  "Envelope" Envelope
  14.     Elements all
  15.     Return
  16. Boundary
  17.     UX Real 0 Imag 0 UY Real 0 Imag 0 UZ Real 0 Imag 0
  18.     Nodes Set 1
  19.     Return
  20. Save Return
  21. Modes
  22.     Vector 50 Tolerance 1.0000e-6 Iteration 100
  23.     BLanczos
  24.     Return
  25. Project Modes Structure Return
  26. Save Return
  27. Save Return
  28. New Model 2 File ATV_fluid.sdb Return
  29. Option  BEM Indirect Variational Uncoupled Unbaffled Frequency  Return
  30. Import Mesh Format Free File plate.fre Return
  31. Set 11 Name  "Envelope" Envelope
  32.     Elements All
  33.     Return
  34. Boundary Jump Pressure  Real 0 Imag 0
  35.     Nodes Set 11
  36.     Return
  37. Save Return
  38. Activate Model 1 Return
  39. Boundary
  40.       FZ Real 300 Imag 0
  41.     Nodes 50,60,73
  42.     Return
  43. Save Return
  44. Activate Model 2 Return
  45. Point Plane  0 0.5 1 To 1 0.5 1 Divide 5 To 0 0.5 0 Divide 5 Return
  46. Compute ATV
  47.     Frequency 20 To 300 LinStep 10
  48.     Near 2
  49.     Far 5
  50.     Quadrature 2 2 1
  51.     Return
  52. Save Return
  53. Link
  54.     Model 1
  55.     Elements All
  56.     To
  57.     Model 2
  58.     Elements All
  59.     Behavior FLUID-STRUCTURE-WEAK
  60.     Return
  61. Project ATV Return
  62. Save Return
  63. Parameter Model 2
  64.     MATV
  65.     FInterpolation Linear
  66.     Save Potentials none
  67.     Save Results Step 1
  68.     Store Results none
  69.     Return
  70.     Near 2
  71.     Far 5
  72.     Quadrature 2 2 1
  73.     Positive
  74.     Return
  75. Parameter Model 1
  76.     Vector 50
  77.     Save Displacements Step 1
  78.     Store Displacements none
  79.     Return
  80.     Return
  81. Solve
  82.     Frequency 20 To 200 LinStep 5
  83.     Return
  84. Save Return
  85. PostProcess
  86.     Points all
  87.     Frequency 20 To 200 LinStep 5
  88.     Near 2
  89.     Far 5
  90.     Quadrature 2 2 1
  91.     Save Results Step 1
  92.     Return
plate.fre
  1. SYSNOISE MESH FILE
  2.
  3.
  4.
  5.        121       100         4
  6. NODES
  7.          1         1       .00000000E+00       .00000000E+00       .00000000E+00
  8.          2         2       .10000000E+00       .00000000E+00       .00000000E+00
  9.          3         3       .20000000E+00       .00000000E+00       .00000000E+00
  10.          4         4       .30000000E+00       .00000000E+00       .00000000E+00
  11.          5         5       .40000000E+00       .00000000E+00       .00000000E+00
  12.          6         6       .50000000E+00       .00000000E+00       .00000000E+00
  13.          7         7       .60000000E+00       .00000000E+00       .00000000E+00
  14.          8         8       .70000000E+00       .00000000E+00       .00000000E+00
  15.          9         9       .80000000E+00       .00000000E+00       .00000000E+00
  16.         10        10       .90000000E+00       .00000000E+00       .00000000E+00
  17.         11        11       .10000000E+01       .00000000E+00       .00000000E+00
  18.         12        12       .00000000E+00       .10000000E+00       .00000000E+00
  19.         13        13       .10000000E+00       .10000000E+00       .00000000E+00
  20.         14        14       .20000000E+00       .10000000E+00       .00000000E+00
  21.         15        15       .30000000E+00       .10000000E+00       .00000000E+00
  22.         16        16       .40000000E+00       .10000000E+00       .00000000E+00
  23.         17        17       .50000000E+00       .10000000E+00       .00000000E+00
  24.         18        18       .60000000E+00       .10000000E+00       .00000000E+00
  25.         19        19       .70000000E+00       .10000000E+00       .00000000E+00
  26.         20        20       .80000000E+00       .10000000E+00       .00000000E+00
  27.         21        21       .90000000E+00       .10000000E+00       .00000000E+00
  28.         22        22       .10000000E+01       .10000000E+00       .00000000E+00
  29.         23        23       .00000000E+00       .20000000E+00       .00000000E+00
  30.         24        24       .10000000E+00       .20000000E+00       .00000000E+00
  31.         25        25       .20000000E+00       .20000000E+00       .00000000E+00
  32.         26        26       .30000000E+00       .20000000E+00       .00000000E+00
  33.         27        27       .40000000E+00       .20000000E+00       .00000000E+00
  34.         28        28       .50000000E+00       .20000000E+00       .00000000E+00
  35.         29        29       .60000000E+00       .20000000E+00       .00000000E+00
  36.         30        30       .70000000E+00       .20000000E+00       .00000000E+00
  37.         31        31       .80000000E+00       .20000000E+00       .00000000E+00
  38.         32        32       .90000000E+00       .20000000E+00       .00000000E+00
  39.         33        33       .10000000E+01       .20000000E+00       .00000000E+00
  40.         34        34       .00000000E+00       .30000000E+00       .00000000E+00
  41.         35        35       .10000000E+00       .30000000E+00       .00000000E+00
  42.         36        36       .20000000E+00       .30000000E+00       .00000000E+00
  43.         37        37       .30000000E+00       .30000000E+00       .00000000E+00
  44.         38        38       .40000000E+00       .30000000E+00       .00000000E+00
  45.         39        39       .50000000E+00       .30000000E+00       .00000000E+00
  46.         40        40       .60000000E+00       .30000000E+00       .00000000E+00
  47.         41        41       .70000000E+00       .30000000E+00       .00000000E+00
  48.         42        42       .80000000E+00       .30000000E+00       .00000000E+00
  49.         43        43       .90000000E+00       .30000000E+00       .00000000E+00
  50.         44        44       .10000000E+01       .30000000E+00       .00000000E+00
  51.         45        45       .00000000E+00       .40000000E+00       .00000000E+00
  52.         46        46       .10000000E+00       .40000000E+00       .00000000E+00
  53.         47        47       .20000000E+00       .40000000E+00       .00000000E+00
  54.         48        48       .30000000E+00       .40000000E+00       .00000000E+00
  55.         49        49       .40000000E+00       .40000000E+00       .00000000E+00
  56.         50        50       .50000000E+00       .40000000E+00       .00000000E+00
  57.         51        51       .60000000E+00       .40000000E+00       .00000000E+00
  58.         52        52       .70000000E+00       .40000000E+00       .00000000E+00
  59.         53        53       .80000000E+00       .40000000E+00       .00000000E+00
  60.         54        54       .90000000E+00       .40000000E+00       .00000000E+00
  61.         55        55       .10000000E+01       .40000000E+00       .00000000E+00
  62.         56        56       .00000000E+00       .50000000E+00       .00000000E+00
  63.         57        57       .10000000E+00       .50000000E+00       .00000000E+00
  64.         58        58       .20000000E+00       .50000000E+00       .00000000E+00
  65.         59        59       .30000000E+00       .50000000E+00       .00000000E+00
  66.         60        60       .40000000E+00       .50000000E+00       .00000000E+00
  67.         61        61       .50000000E+00       .50000000E+00       .00000000E+00
  68.         62        62       .60000000E+00       .50000000E+00       .00000000E+00
  69.         63        63       .70000000E+00       .50000000E+00       .00000000E+00
  70.         64        64       .80000000E+00       .50000000E+00       .00000000E+00
  71.         65        65       .90000000E+00       .50000000E+00       .00000000E+00
  72.         66        66       .10000000E+01       .50000000E+00       .00000000E+00
  73.         67        67       .00000000E+00       .60000000E+00       .00000000E+00
  74.         68        68       .10000000E+00       .60000000E+00       .00000000E+00
  75.         69        69       .20000000E+00       .60000000E+00       .00000000E+00
  76.         70        70       .30000000E+00       .60000000E+00       .00000000E+00
  77.         71        71       .40000000E+00       .60000000E+00       .00000000E+00
  78.         72        72       .50000000E+00       .60000000E+00       .00000000E+00
  79.         73        73       .60000000E+00       .60000000E+00       .00000000E+00
  80.         74        74       .70000000E+00       .60000000E+00       .00000000E+00
  81.         75        75       .80000000E+00       .60000000E+00       .00000000E+00
  82.         76        76       .90000000E+00       .60000000E+00       .00000000E+00
  83.         77        77       .10000000E+01       .60000000E+00       .00000000E+00
  84.         78        78       .00000000E+00       .70000000E+00       .00000000E+00
  85.         79        79       .10000000E+00       .70000000E+00       .00000000E+00
  86.         80        80       .20000000E+00       .70000000E+00       .00000000E+00
  87.         81        81       .30000000E+00       .70000000E+00       .00000000E+00
  88.         82        82       .40000000E+00       .70000000E+00       .00000000E+00
  89.         83        83       .50000000E+00       .70000000E+00       .00000000E+00
  90.         84        84       .60000000E+00       .70000000E+00       .00000000E+00
  91.         85        85       .70000000E+00       .70000000E+00       .00000000E+00
  92.         86        86       .80000000E+00       .70000000E+00       .00000000E+00
  93.         87        87       .90000000E+00       .70000000E+00       .00000000E+00
  94.         88        88       .10000000E+01       .70000000E+00       .00000000E+00
  95.         89        89       .00000000E+00       .80000000E+00       .00000000E+00
  96.         90        90       .10000000E+00       .80000000E+00       .00000000E+00
  97.         91        91       .20000000E+00       .80000000E+00       .00000000E+00
  98.         92        92       .30000000E+00       .80000000E+00       .00000000E+00
  99.         93        93       .40000000E+00       .80000000E+00       .00000000E+00
  100.         94        94       .50000000E+00       .80000000E+00       .00000000E+00
  101.         95        95       .60000000E+00       .80000000E+00       .00000000E+00
  102.         96        96       .70000000E+00       .80000000E+00       .00000000E+00
  103.         97        97       .80000000E+00       .80000000E+00       .00000000E+00
  104.         98        98       .90000000E+00       .80000000E+00       .00000000E+00
  105.         99        99       .10000000E+01       .80000000E+00       .00000000E+00
  106.        100       100       .00000000E+00       .90000000E+00       .00000000E+00
  107.        101       101       .10000000E+00       .90000000E+00       .00000000E+00
  108.        102       102       .20000000E+00       .90000000E+00       .00000000E+00
  109.        103       103       .30000000E+00       .90000000E+00       .00000000E+00
  110.        104       104       .40000000E+00       .90000000E+00       .00000000E+00
  111.        105       105       .50000000E+00       .90000000E+00       .00000000E+00
  112.        106       106       .60000000E+00       .90000000E+00       .00000000E+00
  113.        107       107       .70000000E+00       .90000000E+00       .00000000E+00
  114.        108       108       .80000000E+00       .90000000E+00       .00000000E+00
  115.        109       109       .90000000E+00       .90000000E+00       .00000000E+00
  116.        110       110       .10000000E+01       .90000000E+00       .00000000E+00
  117.        111       111       .00000000E+00       .10000000E+01       .00000000E+00
  118.        112       112       .10000000E+00       .10000000E+01       .00000000E+00
  119.        113       113       .20000000E+00       .10000000E+01       .00000000E+00
  120.        114       114       .30000000E+00       .10000000E+01       .00000000E+00
  121.        115       115       .40000000E+00       .10000000E+01       .00000000E+00
  122.        116       116       .50000000E+00       .10000000E+01       .00000000E+00
  123.        117       117       .60000000E+00       .10000000E+01       .00000000E+00
  124.        118       118       .70000000E+00       .10000000E+01       .00000000E+00
  125.        119       119       .80000000E+00       .10000000E+01       .00000000E+00
  126.        120       120       .90000000E+00       .10000000E+01       .00000000E+00
  127.        121       121       .10000000E+01       .10000000E+01       .00000000E+00
  128. ELEMENTS
  129.          1         1         6         4         1         2        13        12
  130.          2         2         6         4         2         3        14        13
  131.          3         3         6         4         3         4        15        14
  132.          4         4         6         4         4         5        16        15
  133.          5         5         6         4         5         6        17        16
  134.          6         6         6         4         6         7        18        17
  135.          7         7         6         4         7         8        19        18
  136.          8         8         6         4         8         9        20        19
  137.          9         9         6         4         9        10        21        20
  138.         10        10         6         4        10        11        22        21
  139.         11        11         6         4        12        13        24        23
  140.         12        12         6         4        13        14        25        24
  141.         13        13         6         4        14        15        26        25
  142.         14        14         6         4        15        16        27        26
  143.         15        15         6         4        16        17        28        27
  144.         16        16         6         4        17        18        29        28
  145.         17        17         6         4        18        19        30        29
  146.         18        18         6         4        19        20        31        30
  147.         19        19         6         4        20        21        32        31
  148.         20        20         6         4        21        22        33        32
  149.         21        21         6         4        23        24        35        34
  150.         22        22         6         4        24        25        36        35
  151.         23        23         6         4        25        26        37        36
  152.         24        24         6         4        26        27        38        37
  153.         25        25         6         4        27        28        39        38
  154.         26        26         6         4        28        29        40        39
  155.         27        27         6         4        29        30        41        40
  156.         28        28         6         4        30        31        42        41
  157.         29        29         6         4        31        32        43        42
  158.         30        30         6         4        32        33        44        43
  159.         31        31         6         4        34        35        46        45
  160.         32        32         6         4        35        36        47        46
  161.         33        33         6         4        36        37        48        47
  162.         34        34         6         4        37        38        49        48
  163.         35        35         6         4        38        39        50        49
  164.         36        36         6         4        39        40        51        50
  165.         37        37         6         4        40        41        52        51
  166.         38        38         6         4        41        42        53        52
  167.         39        39         6         4        42        43        54        53
  168.         40        40         6         4        43        44        55        54
  169.         41        41         6         4        45        46        57        56
  170.         42        42         6         4        46        47        58        57
  171.         43        43         6         4        47        48        59        58
  172.         44        44         6         4        48        49        60        59
  173.         45        45         6         4        49        50        61        60
  174.         46        46         6         4        50        51        62        61
  175.         47        47         6         4        51        52        63        62
  176.         48        48         6         4        52        53        64        63
  177.         49        49         6         4        53        54        65        64
  178.         50        50         6         4        54        55        66        65
  179.         51        51         6         4        56        57        68        67
  180.         52        52         6         4        57        58        69        68
  181.         53        53         6         4        58        59        70        69
  182.         54        54         6         4        59        60        71        70
  183.         55        55         6         4        60        61        72        71
  184.         56        56         6         4        61        62        73        72
  185.         57        57         6         4        62        63        74        73
  186.         58        58         6         4        63        64        75        74
  187.         59        59         6         4        64        65        76        75
  188.         60        60         6         4        65        66        77        76
  189.         61        61         6         4        67        68        79        78
  190.         62        62         6         4        68        69        80        79
  191.         63        63         6         4        69        70        81        80
  192.         64        64         6         4        70        71        82        81
  193.         65        65         6         4        71        72        83        82
  194.         66        66         6         4        72        73        84        83
  195.         67        67         6         4        73        74        85        84
  196.         68        68         6         4        74        75        86        85
  197.         69        69         6         4        75        76        87        86
  198.         70        70         6         4        76        77        88        87
  199.         71        71         6         4        78        79        90        89
  200.         72        72         6         4        79        80        91        90
  201.         73        73         6         4        80        81        92        91
  202.         74        74         6         4        81        82        93        92
  203.         75        75         6         4        82        83        94        93
  204.         76        76         6         4        83        84        95        94
  205.         77        77         6         4        84        85        96        95
  206.         78        78         6         4        85        86        97        96
  207.         79        79         6         4        86        87        98        97
  208.         80        80         6         4        87        88        99        98
  209.         81        81         6         4        89        90       101       100
  210.         82        82         6         4        90        91       102       101
  211.         83        83         6         4        91        92       103       102
  212.         84        84         6         4        92        93       104       103
  213.         85        85         6         4        93        94       105       104
  214.         86        86         6         4        94        95       106       105
  215.         87        87         6         4        95        96       107       106
  216.         88        88         6         4        96        97       108       107
  217.         89        89         6         4        97        98       109       108
  218.         90        90         6         4        98        99       110       109
  219.         91        91         6         4       100       101       112       111
  220.         92        92         6         4       101       102       113       112
  221.         93        93         6         4       102       103       114       113
  222.         94        94         6         4       103       104       115       114
  223.         95        95         6         4       104       105       116       115
  224.         96        96         6         4       105       106       117       116
  225.         97        97         6         4       106       107       118       117
  226.         98        98         6         4       107       108       119       118
  227.         99        99         6         4       108       109       120       119
  228.        100       100         6         4       109       110       121       120
 楼主| 发表于 2006-12-16 19:02 | 显示全部楼层
经过 confer指点已经解决了。这里特别感谢!
主要问题:
  1.在定义耦合面时要将结构和流体分别定义成不同的SET。否则在耦合时分不清楚。
  2.受到5.6详解这本书的误导(可能不适合5.5版本),其实不需要求解场点,因为在计算ATV时已经计算了。
     只需要提取就可以了,具体用store命令。
附件是修改后的命令流。
  5.     Elements All
  6.     Return
  7. Material Plate
  8.     Name 'steel'
  10.     Elements all
  11.     Return
  12. Save Return
  14.     Elements all
  15.     Return
  16. Set 20 Name  "plate"
  17.     Elements All
  18.     Return
  19. Boundary
  20.     UX Real 0 Imag 0 UY Real 0 Imag 0 UZ Real 0 Imag 0
  21.     Nodes Set 1
  22.     Return
  23. Save Return
  24. Modes
  25.     Vector 50 Tolerance 1.0000e-6 Iteration 100
  26.     BLanczos
  27.     Return
  28. Project Modes Structure Return
  29. Save Return
  30. Save Return
  31. New Model 2 File ATV_fluid.sdb Return
  32. Option  BEM Indirect Variational Uncoupled Unbaffled Frequency  Return
  33. Import Mesh Format Free File plate.fre Return
  34. Set 11 Name  "Envelope" Envelope
  35.     Elements All
  36.     Return
  37. Set 30 Name  "fluid"
  38.     Elements All
  39.     Return
  40. Boundary Jump Pressure  Real 0 Imag 0
  41.     Nodes Set 11
  42.     Return
  43. Save Return
  44. Activate Model 1 Return
  45. Boundary
  46.       FZ Real 300 Imag 0
  47.     Nodes 50,60,73
  48.     Return
  49. Save Return
  50. Activate Model 2 Return
  51. Point Plane  0 0.5 1 To 1 0.5 1 Divide 5 To 0 0.5 0 Divide 5 Return
  52. Compute ATV
  53.     Frequency 20 To 300 LinStep 10
  54.     Near 2
  55.     Far 5
  56.     Quadrature 2 2 1
  57.     Return
  58. Save Return
  59. Link
  60.     Model 1
  61.     Elements Set 20
  62.     To
  63.     Model 2
  64.     Elements Set 30
  65.     Behavior FLUID-STRUCTURE-WEAK
  66.     Return
  67. Project ATV Return
  68. Save Return
  69. Parameter Model 2
  70.     MATV
  71.     FInterpolation Linear
  72.     Save Potentials none
  73.     Save Results Step 1
  74.     Store Results none
  75.     Return
  76.     Near 2
  77.     Far 5
  78.     Quadrature 2 2 1
  79.     Positive
  80.     Return
  81. Parameter Model 1
  82.     Vector 50
  83.     Save Displacements Step 1
  84.     Store Displacements none
  85.     Return
  86.     Return
  87. Solve
  88.     Frequency 20 To 200 LinStep 5
  89.     Return
  90. Save Return
  91. Store
  92. Case Active
  93. Results
  94.     Frequency 20 To 300 LinStep 10
  95.     Points all
  96.   Return
  97. Return
 楼主| 发表于 2006-12-16 19:51 | 显示全部楼层
我随后进行了 贡献量的分析 貌似有结果,但不知道是否正确。
   而且在计算过程中同样出现了第一个帖子的提示,但有结果。
    不知道有谁遇到过没有?
发表于 2006-12-16 21:52 | 显示全部楼层
能否获得单元贡献量结果,即某个单元而不是节点对声场的贡献量?
 楼主| 发表于 2006-12-17 13:14 | 显示全部楼层
我今天又算了一次,发现2个很奇怪的问题:
1.不管我选那个场点,最后还是全部都算出来了。
2.不管我选那个单元,最后算的只有那几个施加了速度边界条件的几个单元有。这点我不是很明白。
希望有人能指点一下。
发表于 2006-12-18 13:37 | 显示全部楼层
会不会是以前的结果保留的?
 楼主| 发表于 2006-12-18 13:47 | 显示全部楼层
我也觉得奇怪,我重新算过2次,不会是软件的问题吧!
发表于 2006-12-18 15:16 | 显示全部楼层
我不太清楚你的问题,不过我用ATV分析后,再用单个节点施加法向振动(Parameters: Physical)可以验证加权矩阵中的对应元素。
发表于 2009-9-6 14:34 | 显示全部楼层
回复 楼主 pengweicai 的帖子
真复杂。。。
请问楼主,是不是要得到声压值,就得计算ATV啊?
我对sysnoise的步骤还是不怎么清楚。
 楼主| 发表于 2009-9-6 21:29 | 显示全部楼层
不要,ATV只是其中的一种算法。。
发表于 2009-9-10 17:03 | 显示全部楼层
ATV是计算某个/集合单元或某个/集合节点的声贡献量,
发表于 2010-12-11 16:20 | 显示全部楼层
回复 5 # pengweicai 的帖子
是声学传递向量这种算法,只计算有振动速度的板之贡献,不振动,无贡献。所以只有加速度边界条件的单元有贡献结果
GMT+8, 2025-1-12 05:58 , Processed in 0.126145 second(s), 19 queries , Gzip On.
