查看: 2130|回复: 3
[流致振动] 请教;振动膜的周期运动udf
发表于 2006-12-15 11:05 | 显示全部楼层 |阅读模式
/* moving_arc.c                                                          */
#include "udf.h"
#define omega 1.0 /* rotational speed, rad/sec */
#define R 0.109 /* radius of the arc, meters */
DEFINE_GRID_MOTION(moving_arc, domain, dt, time, dtime)
Thread *tf = DT_THREAD (dt);
face_t f;
Node *node_p;
real alpha, theta, x, ymag, yfull, y;
int n;
SET_DEFORMING_THREAD_FLAG (THREAD_T0 (tf));
alpha = omega * CURRENT_TIME;
theta = 2.0 * alpha + 3.0 * M_PI / 2.0;
begin_f_loop (f, tf)
f_node_loop (f, tf, n)
node_p = F_NODE (f, tf, n);
if (NODE_POS_NEED_UPDATE (node_p))
NODE_POS_UPDATED (node_p);
x = NODE_X (node_p);
ymag = sqrt (R*R - x*x) + 0.03;
yfull = ymag - 0.1;
y = - 0.1 + yfull * sin(theta);
NODE_Y (node_p) = y;
end_f_loop (f, tf);
Error: F:\Fluent.Inc\fluent6.2.16\src\moving_arc.c: line 10: structure reference not implemented
我不知道怎么改,高手请教了
发表于 2008-6-3 17:46 | 显示全部楼层
换成fluent6.3.16试试:@)
发表于 2008-7-1 11:07 | 显示全部楼层
我用的fluent6.3可以通过的 ,用compiled。
发表于 2008-7-1 11:08 | 显示全部楼层
我做的动网格和这个相似,可是网格一会动一会不动,那位高手可否给点意见!先谢过!
GMT+8, 2024-11-25 16:30 , Processed in 0.055068 second(s), 18 queries , Gzip On.
