查看: 3345|回复: 5
[优化设计] 进化优化方法(ESO)软件Evolve97简介
发表于 2006-12-8 08:43 | 显示全部楼层 |阅读模式
by O. M. Querin
Evolve97 is the first Evolutionary Structural Optimization program in the world which is developed in the environment of Windows 95 (Windows, Windows 95 and Windows NT are trademarks of Microsoft Corporation). Although relatively small in size (only 480kB), it will allow you to see how easy it is to use the ESO method to optimize structures.
System Requirements and Installation of Evolve97
    Evolve97 is a 32-bit application for Windows, so you should have Windows 95 or Windows NT installed in your computer to run Evolve97. You should also have at least 16 MB of RAM installed in your machine and no less than 50MB of free Hard-Disk space. Evolve97 may not run if your system is smaller than this. In Windows 95’s ‘Display Properties’ - Settings section, the ‘Color Palette’ must be set to ‘High Color (16bit)’. Evolve97 has been configured for this number of colours and may not work efficiently if lower colour settings are selected.
    This version of the program is limited in the number of elements that can be used in a model. The maximum mesh size is 55×88, totalling 4840 plate elements. As well this program can only optimize for one load case and one criterion (the von Mises stress). The full version of the program has no restrictions and can be used for all element types (beam, plates and bricks), multiple load cases and multiple criteria, as well as other solution types such as natural frequency and buckling optimization.
[ 本帖最后由 xinyuxf 于 2006-12-8 08:45 编辑 ]
发表于 2006-12-8 13:13 | 显示全部楼层
才480KB啊,这么小,Querin
确实厉害啊
 楼主| 发表于 2006-12-8 13:36 | 显示全部楼层
是啊,只是还没用过
发表于 2006-12-14 23:08 | 显示全部楼层
这种软件使用少,一般不好买到,很希望了解一下ESO
发表于 2013-1-24 14:19 | 显示全部楼层
请问哪里有这个软件呢
发表于 2013-2-22 23:58 | 显示全部楼层
是可以用的吗
GMT+8, 2024-12-28 14:20 , Processed in 0.090917 second(s), 17 queries , Gzip On.
