查看: 2532|回复: 3
[Patran专区] 求助:PATRAN在提交计算后不能读取XDB文件!!
发表于 2006-12-2 20:02 | 显示全部楼层 |阅读模式
在读取XDB文件时出现如下的错误信息:
          Error reported from application Results
         The Direct Results Access file specified is invalid. Possible reasons: (i) the file is not in XDB format, or (ii) the XDB file was generated on another Machine type. For case (ii), please use the TRANS and RECEIVE utilities, or the DDLADD utility. File: "F:\software_study\Patran_Study\tuoluo_11_27_transient.xdb"
各位高手救命啊!!!万分感谢!!
 楼主| 发表于 2006-12-3 16:40 | 显示全部楼层
问题已解决,谢谢关注
发表于 2006-12-3 22:10 | 显示全部楼层
楼主怎么解决的?
 楼主| 发表于 2006-12-4 16:01 | 显示全部楼层
此问题是计算时硬盘空间不足导致的,各位如果遇到类似的问题可往这方面考虑下~~~
[ 本帖最后由 skyboyliu 于 2006-12-4 16:02 编辑 ]
GMT+8, 2025-1-8 01:26 , Processed in 0.058344 second(s), 17 queries , Gzip On.
