查看: 22841|回复: 31
[共享资源] 一种有效的包络线算法
发表于 2006-11-23 16:26 | 显示全部楼层 |阅读模式
  1. function [up,down] = envelope(x,y,interpMethod)
  2. %ENVELOPE gets the data of upper and down envelope of the known input (x,y).
  3. %
  4. %   Input parameters:
  5. %    x               the abscissa of the given data
  6. %    y               the ordinate of the given data
  7. %    interpMethod    the interpolation method
  8. %
  9. %   Output parameters:
  10. %    up      the upper envelope, which has the same length as x.
  11. %    down    the down envelope, which has the same length as x.
  12. %
  13. %   See also DIFF INTERP1
  14. %   Designed by: Lei Wang, <[email]WangLeiBox@hotmail.com[/email]>, 11-Mar-2003.
  15. %   Last Revision: 21-Mar-2003.
  16. %   Dept. Mechanical & Aerospace Engineering, NC State University.
  17. % $Revision: 1.1 $  $Date: 3/21/2003 10:33 AM $
  18. if length(x) ~= length(y)
  19.     error('Two input data should have the same length.');
  20. end
  21. if (nargin < 2)|(nargin > 3), error('Please see help for INPUT DATA.');
  22. elseif (nargin == 2),  interpMethod = 'linear'; end
  23.
  24. % Find the extreme maxim values and the corresponding indexes
  25. %----------------------------------------------------
  26. extrMaxValue = y(find(diff(sign(diff(y)))==-2)+1);
  27. extrMaxIndex =   find(diff(sign(diff(y)))==-2)+1;
  28. % Find the extreme minim values and the corresponding indexes
  29. %----------------------------------------------------
  30. extrMinValue = y(find(diff(sign(diff(y)))==+2)+1);
  31. extrMinIndex =   find(diff(sign(diff(y)))==+2)+1;
  32. up = extrMaxValue; up_x = x(extrMaxIndex);
  33. down = extrMinValue; down_x = x(extrMinIndex);
  34. % Interpolation of the upper/down envelope data
  35. %----------------------------------------------------
  36. up = interp1(up_x,up,x,interpMethod);
  37. down = interp1(down_x,down,x,interpMethod);
 楼主| 发表于 2006-11-23 16:27 | 显示全部楼层
使用例子:
  1. %DEMOENVELOPE shows how to use function envelope to obtain the
  2. %   upper/down envelope of a given data and plot the envelope.
  3. %
  4. %   See also EVELOPE
  5. %   Designed by: Lei Wang, <[email]WangLeiBox@hotmail.com[/email]>, 11-Mar-2003.
  6. %   Last Revision: 21-Mar-2003.
  7. %   Dept. Mechanical & Aerospace Engineering, NC State University.
  8. % $Revision: 1.1 $  $Date: 3/21/2003 10:38 AM $
  9. clc;
  10. % Load a signal waveform
  11. %--------------------------------------------
  12. load data.txt data;
  13. t = data(:,1); % time series
  14. y = data(:,2); % signal data
  15. figure(1); plot(t,y,'b-');  title('The original signal waveform','FontSize',18);
  16. % Call function envelope to obtain the envelope data
  17. %--------------------------------------------
  18. [up,down] = envelope(t,y,'linear');
  19. % Show the envelope alone
  20. %--------------------------------------------
  21. figure(2); plot(t,up); hold on;
  22. plot(t,down); title('The envelope of the given signal data','FontSize',18); hold off;
  23. % Show the original signal and its envelope
  24. %--------------------------------------------
  25. figure(3); plot(t,y,'g-'); hold on; plot(t,up,'r-.'); plot(t,down,'r-.');
  26. title('The envelope vs the given signal data','FontSize',18); hold off;
例子所需的数据.txt
22.59 KB, 下载次数: 489
data.txt
发表于 2007-1-9 10:35 | 显示全部楼层
interpMethod 包含几种?
  除了 linear
发表于 2007-1-9 10:50 | 显示全部楼层
“help interp1”, and you will find it
[ 本帖最后由 ChaChing 于 2010-5-3 00:33 编辑 ]
发表于 2007-1-10 11:10 | 显示全部楼层
我贴
'nearest'Nearest neighbor interpolation
'linear'Linear interpolation (default)
'spline'Cubic spline interpolation
'pchip'Piecewise cubic Hermite interpolation
'cubic'(Same as 'pchip')
'v5cubic'Cubic interpolation used in MATLAB 5. This method does not extrapolate. Also, if x is not equally spaced, 'spline' is used
发表于 2008-1-22 22:52 | 显示全部楼层
采用hilbert变换也可以
abs(hilbert(x));就可以
不过问题的重点好像不在这里
发表于 2008-4-24 23:16 | 显示全部楼层
有点问题想请教一下
如果x不是单调的怎么办?
我用extrMaxValue = y(find(diff(sign(diff(y)))==-2)+1);
提取了一下y值,然后再和x一一对应画出的图不是外轮廓线啊
我把图传了一下,请帮我看看。我试着用下轮廓那个做了一下,得到的是一样的图。
上轮廓
extrMaxValue = U2(find(diff(sign(diff(U2(1,:)')))==+2)+1);
extrMaxIndex = find(diff(sign(diff(U2(1,:)')))==+2)+1;
下轮廓
extrMaxValue = U2(find(diff(sign(diff(U2(2,:)')))==-2)+1);
extrMaxIndex = find(diff(sign(diff(U2(2,:)')))==-2)+1;
U2是一个二行1840列的数据
我是这样画图的
for i=1:1840
for j=1:245
if i == extrMaxIndex(j)
plot(Stick(i),extrMaxIndex(j),'.')
发表于 2008-4-25 10:37 | 显示全部楼层
回复 9楼 的帖子
那就先排序,再做嘛。
doc sort
发表于 2008-4-25 15:24 | 显示全部楼层
谢谢,是我没看懂才会出现问题。 已经搞定。
好像用smooth函数也可以达到类似的效果。(5/12)
发表于 2008-7-2 10:44 | 显示全部楼层
首先感谢 Happy教授 !
使用find(diff(sign(diff(y)))==-2)求取极大值的确绝妙
但使用上若有重复点即发生一些小问题如附图
各位大大对如何解决是否有好意见?
发表于 2008-12-31 15:00 | 显示全部楼层
你的包络线太精确了,呵呵,有没有一种模糊的啊,画包络线一般就是为了好看,比如区分波包啊之类的,你的有点过头了啊。呵呵
发表于 2010-9-1 10:47 | 显示全部楼层
matlab好像有个自带的啊 效果看上去还要好~~有没有那代码????
发表于 2010-9-1 20:21 | 显示全部楼层
matlab很容易实现,但一般在做包络时先要对信号进行滤波,最近研究LabVIEW声学振动包时才知道的。
发表于 2010-9-5 12:29 | 显示全部楼层
回复 sspitty 的帖子
"matlab好像有个自带的", 那个函数?:@)
回复 junzifei 的帖子
"abs(hilbert(x));就可以", 建议说清楚些! :@)
发表于 2010-11-17 00:16 | 显示全部楼层
这程序如果是曲线上升的,得到的包络线就不对了呀
GMT+8, 2025-1-1 16:09 , Processed in 0.073058 second(s), 23 queries , Gzip On.
