查看: 1377|回复: 3
[综合讨论] fnder是个什么函数?
发表于 2006-11-23 09:38 | 显示全部楼层 |阅读模式
fnder是matlab中的函数吗?是什么函数?在哪个工具箱里?
发表于 2006-11-23 10:18 | 显示全部楼层
用help 查一下就查出来了
发表于 2006-11-23 10:32 | 显示全部楼层
splines工具箱里的
发表于 2006-11-23 10:40 | 显示全部楼层
FNDER Differentiate a function.
    FNDER(F) returns the (representation of the) first derivative of the
    univariate function contained in F (and in the same form).
    FNDER(F,DORDER) returns the DORDER-th derivative, with DORDER expected
    to be of the form [d1,...,dm] in case the function in F is m-variate,
    and, for each i=1,..,m,  di  an integer to indicate that the function
    in F is to be differentiated di-fold with respect to its i-th argument.
    Here, di may be negative, resulting in di-fold integration with respect
    to the i-th argument.
    FNDER(...) does not work for rational splines; for them, use FNTLR instead.
    FNDER(...) works for functions in stform only in a very limited way, namely
    only for type tp00, and, for that, DORDER can only be [1 0] or [0 1].
    Examples:
       fnval( fnder( sp, 2), 3.14 );
    gives the value at 3.14 of the function in sp, while
       sp0 = fnint( fnder( sp ) );
    gives a function that differs from sp by some constant only (namely, by
    its value at 0).
GMT+8, 2025-1-17 01:12 , Processed in 0.074801 second(s), 17 queries , Gzip On.
