查看: 1102|回复: 2
[编程技巧] 求助高手
发表于 2006-11-22 09:43 | 显示全部楼层 |阅读模式
clear all
syms z0 z1 x1 x2 y0 n
n=0;
z0=[1 1]
f=x1^2+4*x2^2;
v=[x1,x2];
df=jacobian(f,v);
Q=jacobian(df,v);
g=-df;
eps1=1e-4;
eps2=1e-5;
f0=subs(f, {x1,x2},{z0(1,1),z0(1,2)});
g0=subs(g, {x1,x2},{z0(1,1),z0(1,2)});
h0=[1,0;0,1];
p0=-g0;
z1=z0-((g0*g0')/(g0*Q*g0'))*g0;
f1=subs(f, {x1,x2},{z1(1,1),z1(1,2)});
g1=subs(g, {x1,x2},{z1(1,1),z1(1,2)});
while(f1<0.1)
x1;
f1;
g1
运行后出现 ??? Function 'lt' is not defined for values of class 'sym'.
怎么解决!!!!!!!!
发表于 2006-11-22 10:00 | 显示全部楼层
while(f1<0.1)
中间什么都没有,怎会不出错?
 楼主| 发表于 2006-11-22 10:43 | 显示全部楼层
这个也是这样
function [a,b,z]=lsliu(f,z0,h)
syms x1 x2 y1 y2 z1 z2
y0=subs(f,[x1,x2],z0);
%n=0
z2=z0+h;
y2=subs(f,[x1,x2],z2);
if(y2>=y0)
z1=z2;
y1=y2;
h=-h;
else
z1=z0;
y1=y0;
z0=z2;
y0=y2;
h=2*h;
z2=z0+h;
while(y2<=y0)
  z1=z0;
  y1=y0;
  z0=z2;
  y0=y2;
  h=2*h;
  z2=z0+h;
z1=z0;
a=min(z1,z2);
b=max(z1,z2);
eps=0.05;
z1=a+0.382*(b-a);
y1=subs(f,[x1,x2],z1);
z2=a+0.618*(b-a);
while (abs(b-a)>eps);
   if (y1>=y2)
      a=z1;
      b=b;
      z1=a+0.382*(b-a);
      z2=a+0.618*(b-a);
   elseif y2>y1
      a=a;
      b=z2;
      x1=a+0.382*(b-a);
       z2=a+0.618*(b-a);
z=(z1+z2)/2;
??? Function 'ge' is not defined for values of class 'sym'.
Error in ==> lsliu at 38
   if (y1>=y2)
GMT+8, 2025-1-17 02:52 , Processed in 0.063920 second(s), 17 queries , Gzip On.
