查看: 1965|回复: 0
[线性振动] 欧拉法求解多自由系统响应的MATLAB程序
发表于 2006-11-21 19:03 | 显示全部楼层 |阅读模式
function [x,xd]=vbr(n,dt,x0,xd0,a,b,c,u)
%  vbr
%  Solves the forced multiples degree of freedom system using Euler's method.
%  x=vbr(n,dt,x0,a,u)
%  Solves the system given the initial state vector 'x0',
%                          the state matrix 'a',
%                          the time step to be used 'dt',
%                          and the number of steps to take 'n'.
%    The force matrix u is ordered such that the nth column of u is the force vector u evaluated at time n*dt.
%  [x,xd]=vbr(n,dt,x0,v0,m,d,k,u)
%  Solves the system given the initial displacement vector 'x0',
%                          the mass matrix 'm',
%                          the stiffness matrix 'k',
%                          and the damping matrix 'd'.
%    The remaining parameters are as described above.
%  The outputs are in the form of a matrix where each column represents the
%  states a one time step and the rows represent a state as a function of time.
if nargin==8
   la=length(a);
   x0=[x0;xd0];
   a=[zeros(la) eye(la);-a\c -a\b];
   u=[u*0;u];
  else
   u=a;
   a=xd0;
%             Where the action is.
x(:,1)=x0;
for i=2:1:n+1
  x(:,i)=a*dt*x(:,i-1)+x(:,i-1)+dt*u(:,i-1);
%             Where the action is finished.
lx=length(a);
if lx/2==floor(lx/2)
  xd=x(lx/2+1:lx,:);
  x=x(1:lx/2,:);
else
  xd=x;
GMT+8, 2024-12-2 22:49 , Processed in 0.082651 second(s), 24 queries , Gzip On.
