查看: 992|回复: 3
[编程技巧] 程序错误什么意思?(在线等 谢谢)
发表于 2006-11-17 19:51 | 显示全部楼层 |阅读模式
function x=naivgauss(A,b);
n=length(b); x=zeros(n,1);
for k=1:n-1
    for i=k+1:n
        xmult=A(i,j)/A(k,k);
        for j=k+1:n
            A(i,j)=A(i,j)-xmult*A(i,j);
        b(i)=b(i)-xmult*b(k);
% back substitution
x(n)=b(n)/A(n,n);
for i=n-1:-1:1
    sum=b(i);
    for j=i+1:n
        sum=sum-A(i,j)*x(j);
    x(i)=sum/A(i,j);
>> A=[0.001 2.000 3.000;-1.000 3.712 4.623;-2.000 1.072 5.643];
b=[1.000;2.000;3.000];
>> naivgauss(A,b)
??? Error: File: naivgauss.m Line: 6 Column: 13
"j" previously appeared to be used as a function, conflicting with its use here as the name of a variable.
A possible cause of this error is that you forgot to initialize the
variable, or you have initialized it implicitly using load or eval.
不知道上面的程序错误什么意思?请各位大侠帮忙解释一下!!!谢了先!
发表于 2006-11-17 20:04 | 显示全部楼层
原帖由 cannor 于 2006-11-17 19:51 发表
for k=1:n-1
    for i=k+1:n
        for j=k+1:n
这里的j是何值?
这么明显的错误应该自己多注意了.
提示:你的指标写错了.
 楼主| 发表于 2006-11-17 20:38 | 显示全部楼层
哦   非常谢谢   都晕了   呵呵    谢谢了
GMT+8, 2025-1-17 03:17 , Processed in 0.068390 second(s), 17 queries , Gzip On.
