查看: 1362|回复: 2
[混合编程] 请教matlab与Fortran混合编程设置问题
发表于 2006-11-16 23:59 | 显示全部楼层 |阅读模式
我在D盘装得Fortran 6.5,以下是环境设置,但 编译matlab自带的yprimef.f有问题,不知怎么回事??
是环境没设置好吧??请高手指教,在此谢过!!
mex -setup
Please choose your compiler for building external interface (MEX) files:
Would you like mex to locate installed compilers [y]/n? n
Select a compiler:
[1] Borland C++Builder version 6.0
[2] Borland C++Builder version 5.0
[3] Borland C++Builder version 4.0
[4] Borland C++Builder version 3.0
[5] Borland C/C++ version 5.02
[6] Borland C/C++ version 5.0
[7] Borland C/C++ (free command line tools) version 5.5
[8] Compaq Visual Fortran version 6.1
[9] Compaq Visual Fortran version 6.6
[10] Digital Visual Fortran version 6.0
[11] Digital Visual Fortran version 5.0
[12] Lcc C version 2.4
[13] Microsoft Visual C/C++ version 7.0
[14] Microsoft Visual C/C++ version 6.0
[15] Microsoft Visual C/C++ version 5.0
[16] WATCOM C/C++ version 11
[17] WATCOM C/C++ version 10.6
[0] None
Compiler: 9
The default location for Compaq Visual Fortran compilers is C:\Program Files\Microsoft Visual Studio,
but that directory does not exist on this machine.
Use C:\Program Files\Microsoft Visual Studio anyway [y]/n? y
Please verify your choices:
Compiler: Compaq Visual Fortran 6.6
Are these correct?([y]/n): y
The default options file:
"C:\Documents and Settings\xinfengxian\Application Data\MathWorks\MATLAB\R13\mexopts.bat"
is being updated from D:\MATLAB6.5\BIN\WIN32\mexopts\df66opts.bat...
>> mex yprimef.f
   Creating library _lib6643.lib and object _lib6643.exp
_lib6643.exp : error LNK2001: unresolved external symbol _MEXFUNCTION@16
yprimef.dll : fatal error LNK1120: 1 unresolved externals
  D:\MATLAB6.5\BIN\WIN32\MEX.PL: Error: Link of 'yprimef.dll' failed.
??? Error using ==> mex
Unable to complete successfully
[ 本帖最后由 xinyuxf 于 2007-7-22 16:13 编辑 ]
发表于 2006-11-17 09:31 | 显示全部楼层
估计是版本支持问题,不知道你的matlab是什么版本的
你选择9 Compaq Visual Fortran version 6.6看看
 楼主| 发表于 2006-11-17 15:55 | 显示全部楼层
版本:matlab 6.5 和Fortran 6.5
GMT+8, 2025-1-17 02:52 , Processed in 0.089225 second(s), 18 queries , Gzip On.
