查看: 2023|回复: 11
[转子动力学] 请问“三重点理论”是指什么
发表于 2006-11-16 23:43 | 显示全部楼层 |阅读模式
我经常听人提起,可不清楚具体内容是什么。何谓三重点理论,多谢!
发表于 2006-11-17 10:44 | 显示全部楼层
“三重点”调频理论——黄文虎提出,利用这种方法,设计出的长叶片既轻巧又安全,节省了大量合金材料。这一理论在当时是国内外首创,填补了我国汽轮机长叶片振动计算的空白,取得了巨大的经济效益和社会效益。这个理论在国际上也得到了公认,被选登在具有国际权威的美国《航空航天学报》上。
发表于 2006-11-17 13:52 | 显示全部楼层
具体点是什么啊,什么文献(著作)里提出的
发表于 2006-11-26 20:05 | 显示全部楼层
请自行到图书馆检索黄文虎先生的文章,未能提供更多帮助,非常抱歉!
 楼主| 发表于 2009-2-14 23:54 | 显示全部楼层
回复 楼主 escapist 的帖子
好像是,激励力的频率阶数与固有频率的阶数相同,且两个频率相等时,最危险.所以要避开三重点
发表于 2009-2-16 16:14 | 显示全部楼层
回复 楼主 escapist 的帖子
thank you!!!!!
发表于 2009-2-17 12:16 | 显示全部楼层
楼上的高人最好可以给本书的名字。好让我们后生有的放矢。
发表于 2009-2-17 19:07 | 显示全部楼层
三重点理论 你可以 google 一下。
http://scholar.google.cn/scholar?q=%E4%B8%89%E9%87%8D%E7%82%B9%E7%90%86%E8%AE%BA+%E9%BB%84%E6%96%87%E8%99%8E&hl=zh-CN&lr=&btnG=%E6%90%9C%E7%B4%A2&lr=
 楼主| 发表于 2009-2-17 23:52 | 显示全部楼层
Huang Wenhu.Free and forced vibrations of closely coupled turbo-machinery blades.AIAA Journal,1981,19(7).
这篇文献中好像提出了三重点理论.
发表于 2009-2-18 10:50 | 显示全部楼层
回复 9楼 escapist 的帖子
应该就是这篇文章吧!
Free and Forced Vibration of Closely
Coupled Turbomachinery Blades
Wen-hu Huang*
Harbin Institute of Technology, Harbin, China
This paper deals with the free and forced vibration of closely coupled turbomachinery blades on a disk which
are connected by elements forming a circumferentially continuous periodic structure that will be called a
rotationally periodic structure in this paper. A computational procedure for calculating the free vibration of
rotationally periodic structures with various types of connecting elements is obtained by a transfer matrix
method. The method of analysis for a packet formed by a finite number of blades is also discussed. The forced
vibration and the condition of resonance of a rotationally periodic structure under a time-varying periodic
excitation are studied, and a vibration design criterion is suggested.
As these three quantities must coincide with each other,
hence this condition of resonance may be called "the triplecoincidence
condition
," The condition of avoiding triple
coincidence may be suggested as a vibration design criterion
for blades of this type.
The above conclusion
发表于 2009-2-18 10:54 | 显示全部楼层
Vibration of Some Structures with Periodic Random Parameters
Wen-huHuang*
In a periodic structural system, such as blades in a closed packet of turbomachinery, the natural frequencies of
the individual blades can be randomly different from one another. This paper describes a solution for such a
periodic structure in which the distributions of blade frequencies are random processes with small standard
deviations. A spectral method is suggested to solve differential equations with random coefficients. The expressions
for vibration modes are given; the standard deviations of natural frequencies are estimated, and the
results of forced vibration are presented. Some special features of vibration characteristics of this system are
shown as well.
这篇AIAA文章也提到的“三重点理论”
发表于 2009-2-18 10:55 | 显示全部楼层
回复 沙发 supervb 的帖子
航空航天学报,你说AIAA就行了。
GMT+8, 2024-11-30 03:27 , Processed in 0.058928 second(s), 17 queries , Gzip On.
