查看: 2638|回复: 3
[结构分析] 钢管混凝土梁柱节点分析问题(加combination39)?
发表于 2006-11-14 15:24 | 显示全部楼层 |阅读模式
我做钢管混凝土节点分析,命令流如下,计算承载力时出现类似下面的警告(挑了些),而且没有结果文件,请帮忙分析下,急啊!
*** ERROR ***                           CP=      6.609   TIME= 11:47:12
Last input displacement for element 7041 must be positive.
*** WARNING ***                         CP=     29.234   TIME= 12:26:51
Real constant 4 referenced by at least element types 3 and 2.
*** WARNING ***                         CP=     29.297   TIME= 12:26:51
Nodes I and J of element 6708 ( COMBIN39 ) are not coincident.   加弹簧单元加了法向、切向和横向的,是不是加的方法的问题?
*** ERROR ***     SUPPRESSED MESSAGE    CP=     50.141   TIME= 12:33:29
Nodes I and J have been defined as duplicate nodes
  for element 6787 ( COMBIN39).
*** WARNING ***   SUPPRESSED MESSAGE    CP=      7.031   TIME= 12:48:04
Element 1 has a diameter to thickness ratio less than 10.  Theory may
not be valid.
  Check real constant table 5.
[ 本帖最后由 andyqiujie 于 2006-11-17 17:39 编辑 ]
正式命令流.txt
25.61 KB, 下载次数: 41
 楼主| 发表于 2006-11-20 11:08 | 显示全部楼层
还是我来抛砖引玉吧,我觉得是keypoint的设置问题,必须旋转坐标使和单元坐标一致,不知道对错,请各位高手指正!
发表于 2010-11-19 14:40 | 显示全部楼层
怎么每人回复啊?
发表于 2011-3-4 21:41 | 显示全部楼层
不知道怎样解决的啊?
GMT+8, 2025-1-27 06:03 , Processed in 0.102853 second(s), 22 queries , Gzip On.
