查看: 2181|回复: 1
[经典算法] 在1——500中,找出能同时满足用3除余2,用5除余3,用7除余2的所有整数;
发表于 2006-11-5 14:57 | 显示全部楼层 |阅读模式
在做一个吧
#include <iostream>
#include <list>
using namespace std;
int main()
        list <int> answer;
        int i;
        for(i=1;i<=500;i++)
                if((i%3==2)&&(i%5==3)&&(i%7==2))
                        answer.push_back(i);
        list <int> ::iterator p=answer.begin();
        while(p!=answer.end())
                cout<<*p<<" ";
                p++;
        return 0;
发表于 2006-11-6 22:00 | 显示全部楼层
好玩:@D
  1. #!/usr/bin/env python
  2. def mod(x,y,z):
  3.     return divmod(x,y)[1] == z
  4. print [i for i in xrange(1,501) if mod(i,3,2) and mod(i,5,3) and mod(i,7,2)]
GMT+8, 2025-1-6 16:27 , Processed in 0.060512 second(s), 18 queries , Gzip On.
