查看: 1114|回复: 0
[混合编程] 求助!
发表于 2006-10-29 23:48 | 显示全部楼层 |阅读模式
我编写了如下的一个方程组
function [a,b,c,d]=fch()
[a,b,c,d]=solve('-(a+250)/b-(b-d)/(a-c)=0','(a+250)^2+b^2-125^2=0','-c/d-(b-d)/(a-c)=0','c^2+d^2-62500=0');
a=double(vpa(a))
b=double(vpa(b))
c=double(vpa(c))
d=double(vpa(d))
在matlab里运行没有问题,结果也对
运行
mcc -m fch
出现警告:
Warning: File: solve Line: 97 Column: 16
The MATLAB Compiler does not currently support MATLAB object-oriented programming.  References to the method "findsym" will produce a run-time error.
Warning: File: solve Line: 87 Column: 19
The MATLAB Compiler does not currently support MATLAB object-oriented programming.  References to the method "sym" will produce a run-time error.
Warning: File: vpa Line: 28 Column: 9
Warning: File: maple Line: 94 Column: 19
这是为什么,怎么处理?
请高人指点
GMT+8, 2025-1-30 18:21 , Processed in 0.079235 second(s), 18 queries , Gzip On.
