查看: 5003|回复: 13
【分享】abaqus中梁的分析!
发表于 2006-10-24 00:04 | 显示全部楼层 |阅读模式
这个例子好像很多地方都有
发表于 2006-10-24 00:15 | 显示全部楼层
真是个好版主,这么晚了还在上传资料为大家服务,精神可嘉,狂鼓一把
 楼主| 发表于 2006-10-24 00:26 | 显示全部楼层
哪里哪里,楼上夸奖了,这就睡了!
发表于 2006-10-24 08:50 | 显示全部楼层
算例的inp有点问题,
需要作些修改,
手边没有help keyword,只有solver,
ps:error and warning
  *BEAM GENERAL SECTION, ELSET=FRAME
***ERROR: SECTION PROPERTIES ARE UNREALISTIC. I(11)*I(22)-I(12)**2 MUST BE
           POSITIVE.
***NOTE: DUE TO AN INPUT ERROR THE ANALYSIS PRE-PROCESSOR HAS BEEN UNABLE TO
          INTERPRET SOME DATA.  SUBSEQUENT ERRORS MAY BE CAUSED BY THIS OMISSION
***WARNING: SHEAR MODULI GIVEN AS ZERO FOR BEAM GENERAL SECTION ARE RESET TO
             0.39 * YOUNG'S MODULUS
  *SOLID SECTION, ELSET=TRUSS1, MATERIAL=STEEL
  *SOLID SECTION, ELSET=TRUSS2, MATERIAL=STEEL
  *TRANSFORM,NSET=NSET1
  *BOUNDARY
***ERROR: NODE 101 HAS BEEN ASSOCIATED WITH MORE THAN ONE COORDINATE
           TRANSFORMATION
***ERROR: NODE 103 HAS BEEN ASSOCIATED WITH MORE THAN ONE COORDINATE
           TRANSFORMATION
***WARNING: ONLY A SOLID SECTION PROPERTY OPTION MAY BE USED WITH ELEMENT 11.
             CHECK THAT NO OTHER PROPERTY REFERS TO THIS ELEMENT.
***ERROR: ELEMENT 11 IS LACKING A PROPERTY DEFINITION; CHECK ELEMENT SET AND
           ELEMENT DEFINITIONS
***WARNING: ONLY A SOLID SECTION PROPERTY OPTION MAY BE USED WITH ELEMENT 12.
***ERROR: ELEMENT 12 IS LACKING A PROPERTY DEFINITION; CHECK ELEMENT SET AND
           ELEMENT DEFINITIONS
***WARNING: ONLY A SOLID SECTION PROPERTY OPTION MAY BE USED WITH ELEMENT 13.
***ERROR: ELEMENT 13 IS LACKING A PROPERTY DEFINITION; CHECK ELEMENT SET AND
           ELEMENT DEFINITIONS
***ERROR: 3 elements have missing property definitions. The elements have been
           identified in element set ErrElemMissingSection.
***WARNING: 3 elements have incorrect property definitions. The elements have
             been identified in element set WarnElemIncorrectProperty.
  *STEP,PERTURBATION
  *STEP,PERTURBATION
  *STEP,PERTURBATION
  Distributed load on Beams 11 and 12
  *STATIC
  *BOUNDARY
  *DLOAD
  *EL PRINT
***WARNING: OUTPUT VARIABLE SF HAS NO COMPONENTS IN THIS ANALYSIS FOR ELEMENT
             TYPE T2D2
             TYPE T2D2
***ERROR: UNIDENTIFIED OR INVALID OUTPUT REQUEST SM
  *END STEP
  *STEP,PERTURBATION
  *STATIC
  *BOUNDARY
  *NODE PRINT
  *END STEP
***ERROR: INVALID LOAD TYPE ON ELEMENT 11. LOAD TYPE P2 IS NOT VALID FOR
           ELEMENT TYPE T2D2
***ERROR: INVALID LOAD TYPE ON ELEMENT 12. LOAD TYPE P2 IS NOT VALID FOR
           ELEMENT TYPE T2D2
           ELEMENT TYPE T2D2
           ELEMENT TYPE T2D2
 楼主| 发表于 2006-10-24 10:36 | 显示全部楼层
问题还真不少啊,真失败,大家就别下载了,多谢linqus
发表于 2006-10-24 11:52 | 显示全部楼层
其实是个不错的算例,
有关beam的输出等等方面以及node坐标等问题的使用都涉及到了,
前面相关的introduce 都不错了,
等有空我修改一下inp再放上来。
发表于 2006-10-24 13:00 | 显示全部楼层
对原inp作了些修改,基本可以运行了
下载了个pdf的help,
对原inp作了些修改,基本可以运行了。
*HEADING
Non-Global Supports Example
Lengths are in inches, forces in kips
** ======== Model Definition ========
*NODE
101, -600., 0., 0.
102, 600., 0., 0.
103, -900., 1080., 0.
104, 0., 1440., 0.
105, 900., 1080., 0.
*NSET,NSET=NSET1
101, 103
*NSET,NSET=NSET2
102, 105
25., -90., 0., 90., 25., 0.
**        *TRANSFORM,NSET=NSET1
**        25., 90., 0., -90., 25., 0.
*ELEMENT, TYPE=T2D2, ELSET=TRUSS1
14, 103, 101
17, 102, 105
*ELEMENT, TYPE=T2D2, ELSET=TRUSS2
15, 101, 104
16, 104, 102
*ELEMENT, TYPE=B21, ELSET=FRAME
11, 103, 104
12, 104, 105
13, 101, 102
2.0
4.0
*MATERIAL, NAME=STEEL
*ELASTIC
30000., 0.3
10.0, 1000,0,0.
0.0,0.0,-1.0
30000.0,1.17e4
** ======== History definition ==============
*STEP,PERTURBATION
*STATIC
*BOUNDARY
101, 2
102, 2
103, 2
105, 2
*DLOAD
11, P2, -1.0
12, P2, -1.0
*RESTART, WRITE
*NODE PRINT
U,
RF,
*EL PRINT,elset=frame
SF,
SM1,
*END STEP
发表于 2006-10-24 13:24 | 显示全部楼层
发帖真困难,
一个贴要发好几次,:@L
发表于 2008-2-4 06:26 | 显示全部楼层
正在找这个,支持一下,谢谢
发表于 2009-6-18 01:17 | 显示全部楼层
支持一下,谢谢
发表于 2009-10-11 11:04 | 显示全部楼层
顶一下!!!
发表于 2009-10-27 00:33 | 显示全部楼层
怎么这么多问题
发表于 2010-7-18 21:59 | 显示全部楼层
dfdf
hao dong xi
发表于 2010-8-24 21:06 | 显示全部楼层
具体 那个inp  怎么导入呢
GMT+8, 2024-12-29 18:06 , Processed in 0.076355 second(s), 19 queries , Gzip On.
