查看: 3468|回复: 8
[计算力学] FORTRAN常见错误
发表于 2006-10-19 20:39 | 显示全部楼层 |阅读模式
41 Insufficient virtual memory 虚拟内存不足
70 Integer overflow 整数溢出错误
71 Integer divide by zero 整数除0错误
72 Floating overflow 浮点数溢出错误
73 Floating divide by zero 浮点数除0错误
74 Floating underflow 浮点数下溢错误
75 Floating point exception 浮点数异常错误
77 Subscript out of range 数组定义超出边界
95 Floating-point conversion failed 浮点数格式转换失败
146 Null pointer error 空指针错误
147 Stack overflow 堆栈溢出
148 String length error 字符串长度超出允许范围
149 Substring error 数组下标超出允许范围
150 Range error 整数值超出允许范围
151 Allocatable array is already allocated 数组重复定义
161 Program Exception - array bounds exceeded 引用数组下标超出允许范围
162 Program Exception - denormal floating-point operand 非法浮点数操作符
163 Program Exception - floating stack check 浮点数堆栈检查
164 Program Exception - integer divide by zero 整数除0错误
165 Program Exception - integer overflow 整数溢出
166 Program Exception - privileged instruction 非法执行特权指令
168 Program Exception - illegal instruction 非法指令
170 Program Exception - stack overflow 堆栈溢出
540 Array or substring subscript expression out of range 数组下标低下数组定义下界或高于数组定义上界
541 CHARACTER substring expression out of range 字符串非法表示
542 Label not found in assigned GOTO list 不属于GOTO语句引用的标号
543 INTEGER arithmetic overflow 整数运算结果出现溢出
544 INTEGER overflow on input 输入的整数值超出允许范围
545 Invalid INTEGER 非法整数值
546 REAL indefinite (uninitialized or previous error) 产生非法实数
547 Invalid REAL 非法实数
548 REAL math overflow 实数值溢出
549 No matching CASE found for SELECT CASE select case语句中缺少case项
550 INTEGER assignment overflow 整数定义超出允许范围
556 A edit descriptor expected for CHARACTER 字符型数据的格式化输入和输出需要A编辑符
557 E, F, D, or G edit descriptor expected for REAL 实数型数据的格式化输入和输出需要E,F,D,G编辑符
558 I edit descriptor expected for INTEGER 整数型数据的格式化输入和输出需要I编辑符
559 L edit descriptor expected for LOGICAL 逻辑型数据的格式化输入和输出需要L编辑符
568 Multiple radix specifiers 输入或输出语句重复说明
582 Array already allocated 数组已分配
583 Array size zero or negative 数组大小为0或负数
585 Array not allocated 没有被分配的数组
610 Invalid argument 非法参数
616 Invalid number in input 输入非法数字
617 Invalid string in input 输入非法字符串
618 Comma missing in COMPLEX input 输入的多个表达式之间缺少逗号
619 T or F expected in LOGICAL read 输入的逻辑值必须是T或F
622 Illegal character in hexadecimal input 输入非法的十六进制数
637 Integer expected in format 格式语句中要求的整数
638 Initial left parenthesis expected in format 格式语句中多余的左括号
639 Positive integer expected in format 格式语句中要求用正整数
641 Integer expected preceding H, X, or P edit descriptor 在H、X、P编辑符前要求用整数
644 '.' expected in format 在D、E、F、G编辑符中w和d域之间用'.'分隔
645 Unexpected end of format 格式语句没有结束
646 Unexpected character in format 格式语句中的非法字符
647 M field exceeds W field in I edit descriptor 在I编辑符中M域的值大于W域的值
648 Integer out of range in format 格式语句中的整数值超出允许范围
650 Separator expected in format 格式语句中需要分隔符
663 Out of range: substring starting position 'pos' is less than 1 子字符串的起始位置小于1
664 Out of range: substring ending position 'pos' is greater than string length 'len' 子字符串的终止位置大于字符串长度
672 Out of memory 内存不足
718 Cannot allocate temporary array -- out of memory 由于内存不足不能分配临时数组
727 Cannot ALLOCATE allocatable array -- out of memory 由于内存不足不能分配数组
729 DEALLOCATE failure: ALLOCATABLE array is not ALLOCATED 释放没有被分配的数组
[ 本帖最后由 yejet 于 2006-11-13 17:28 编辑 ]
发表于 2006-10-26 13:06 | 显示全部楼层
谢谢,只有这么多么?还有没有全一点的啊?
发表于 2006-11-5 14:32 | 显示全部楼层
最近正在重学FORTRAN,已经有五年多没接触了,呵呵,谢谢楼主的分享
发表于 2006-11-13 17:07 | 显示全部楼层
我也准备重新学习一下这门语言,计算方面它还是很强啊
发表于 2006-11-13 22:25 | 显示全部楼层
谢谢楼主啊,这个实在
发表于 2006-11-14 10:59 | 显示全部楼层
好东西啊
强烈推荐
发表于 2006-11-15 18:50 | 显示全部楼层
好贴
有没有具体的电子板的教材可以下载阿
发表于 2006-11-23 18:46 | 显示全部楼层
太厉害了,顺道问一下计算出来结果全是nan是什么错误?
发表于 2006-12-18 23:04 | 显示全部楼层
谢谢,很有用,建议多发点类似的东西上来
GMT+8, 2024-11-29 09:41 , Processed in 0.092839 second(s), 18 queries , Gzip On.
