查看: 6706|回复: 2
[CFX应用] [讨论]CFX5.7计算是出现的问题
发表于 2005-9-7 23:06 | 显示全部楼层 |阅读模式
| ****** Notice ****** |
| Newtons method failed to converge in 100 iterations. This |
| occured while computing the following variable: |
| Variable Name : Temperature |
| Location Name : liutiyu |
| Mesh location : VERTICES |
| Mesh entity : |
| Last 3 Changes : 1.34525E+00 1.34525E+00 1.34525E+00 |
| Tolerance : 1.0000E-02 |
| The Newton iteration was either slowly converging or has stalled. |
| The solver will continue with the variable set as it was on the |
| final iteration. If this situation continues you might try |
| increasing the number of iterations allowed for Newtons method. |
| This can be changed by setting one of the parameters: |
| Temperature : "Constitutive Relation Iteration Limit" |
| Pressure : "Newton Pressure Iteration Limit" |
| for your mixture using the definition file editor. |
| ERROR #004100018 has occurred in subroutine FINMES. |
| Message: |
| Fatal overflow in linear solver. |
大家看看该怎么解决?
发表于 2005-9-8 15:01 | 显示全部楼层
回复:(Frank)[讨论]CFX5.7计算是出现的问题
Q: " I am getting finmes errors and the linear solver is failing. " <BR>A: Linear solver errors (or failures) such as this are usually caused by 'unphysical' boundary or initial conditions, especially if they occur on the first loop. We suggest that you check through your boundary conditions for any errors and consider using 'Automatic with Value' for the initial conditions. Sensible values can then be used to start the simulation, or ideally CEL expressions that approximate the expected solution field.
发表于 2005-9-10 13:46 | 显示全部楼层
看看是不是初值的问题
GMT+8, 2024-11-26 09:35 , Processed in 0.072195 second(s), 17 queries , Gzip On.
