查看: 3965|回复: 3
[Fortran] [请教]在fortran中读取ASCII码数据文件时...
发表于 2006-9-20 09:43 | 显示全部楼层 |阅读模式
在fortran中读取ASCII码数据文件时,如何让程序从文件的指定行开始读?
发表于 2006-9-20 10:11 | 显示全部楼层
查fortran书
发表于 2007-1-1 22:45 | 显示全部楼层
原帖由 abcdefg100 于 2006-9-20 09:43 发表
遇到同样问题,不知道该如何实现?
每行的字符数不一样多,不知道如何实现从行首读到行尾?(预先定义字符长度为定值的方法除外,这种方法先暂时用着,应付着...)
能不能让程序自动判断每行的行尾所在的列数,然后返回一个数值,之后才定义字符变量的长度,读入数组?貌似难度大了一些..... :D
发表于 2007-1-2 13:09 | 显示全部楼层
(建议版主把这个帖子移动到编程版fortran专题下)
下面的方法虽然解决不了我的问题,不过也是很有价值的。
From:    http://www.tek-tips.com/viewthread.cfm?qid=1315394&page=1
How to read data from specific line in a file
sougandh (TechnicalUser)
21 Dec 06 12:11
Hi,
    Here is my problem. My file is in the following format.
    It has 5 columns with first two being integers and 3-5 are  floating values.
   file format (similar format with different values)
      col 1     col 2       col 3    col 4     col 5
     5001       1001        12.34   11.34    43.454
     5001       1002        11.54   65.43    65.234
     5001       1003        12.54   54.64    65.778
     5001       1099        14.65   16.53    12.568
     5001       1100        13.65   13.54    12.545
     5002       1001        12.34   11.34    43.454
     5002       1002        11.54   65.43    65.234
     5002       1003        12.54   54.64    65.778
     5002       1099        13.45   51.15    61.542
     5002       1100        13.65   13.54    12.545
     so on...
     That means, for each number in column 1 i have 100 values. Or i should say the column 1 number doesnt change for for 100 rows and then it increases. Infact  my original file has (5760 x 4633) rows.
    Now here is how i need to read it:
There is a variable 'crhr' which returns a value which corresponds to any of the values in column 1. For example it may be 5002 or 5050 or anything. So when this variable has a value of 5002 what i need is i should be able to read the rows corresponding to the number 5002 and store it in an array.
  My problem now is how do i make Fortran start reading the file from a particular line based on the value returned by the variable 'crhr'
thanks
sougandh
Helpful Member!xwb (Programmer)
21 Dec 06 16:30
Are all the lines the same size (in characters).  If so, then you can use formatted reads on direct access files
CODE
program main
   integer FHAND, TMAX, RMAX
   parameter (TMAX=10, RMAX=5, FHAND=88)
   real t(TMAX)
   integer reqd(RMAX)
   data reqd/ 1, 2, 16, 8, 4 /
   ! file - the data file
   ! status - always old
   ! form - formatted for human readable data
   !      - unformatted for binary data
   ! access - always direct.  The alternative is sequential
   ! recl - number of characters incl LF
   open (FHAND, &
      file='data.txt', &
      status='old', &
      form='FORMATTED', &
      access='direct', &
      recl=51)
   do i = 1, RMAX
      ! Read record reqd(i)
      read (FHAND, '(10F5.1)', rec=reqd(i)) (t(j), j = 1, TMAX)
      write (*, '(10F5.1)') (t(j), j = 1, TMAX)
   enddo
   close (FHAND)
   stop
end program
GMT+8, 2025-1-6 15:43 , Processed in 0.075732 second(s), 17 queries , Gzip On.
