查看: 2803|回复: 6
[求助]加速寿命试验
发表于 2005-9-4 08:00 | 显示全部楼层 |阅读模式
谁有加速寿命试验相关方面的理论资料以及标准?急需
发表于 2005-9-5 00:30 | 显示全部楼层
回复:(bibikey)[求助]加速寿命试验
  What is Accelerated Life Testing?
  Traditional life data analysis involves analyzing times-to-failure data (of a product, system or component) obtained under normal operating conditions in order to quantify the life characteristics of the product, system or component. In many situations, and for many reasons, such life data (or times-to-failure data) is very difficult, if not impossible, to obtain. The reasons for this difficulty can include the long life times of today's products, the small time period between design and release and the challenge of testing products that are used continuously under normal conditions. Given this difficulty, and the need to observe failures of products to better understand their failure modes and their life characteristics, reliability practitioners have attempted to devise methods to force these products to fail more quickly than they would under normal use conditions. In other words, they have attempted to accelerate their failures. Over the years, the term accelerated life testing has been used to describe all such practices.
  A variety of methods that serve different purposes have been termed "accelerated life testing." As we use the term in this reference, accelerated life testing involves acceleration of failures with the single purpose of quantification of the life characteristics of the product at normal use conditions.
  More specifically, accelerated life testing can be divided into two areas: qualitative accelerated testing and quantitative accelerated life testing. In qualitative accelerated testing, the engineer is mostly interested in identifying failures and failure modes without attempting to make any predictions as to the product抯 life under normal use conditions. In quantitative accelerated life testing, the engineer is interested in predicting the life of the product (or, more specifically, life characteristics such as MTTF, B(10) life, etc.) at normal use conditions, from data obtained in an accelerated life test.
发表于 2005-9-5 00:31 | 显示全部楼层
  Types of Accelerated Tests
  Each type of test that has been called an accelerated test provides different information about the product and its failure mechanisms. These tests can be divided into two types: qualitative tests (HALT, HAST, torture tests, shake and bake tests, etc.) and quantitative accelerated life tests. This reference addresses and quantifies the models and procedures associated with quantitative accelerated life tests.
  Qualitative Accelerated Life Testing
  Qualitative tests are tests that yield failure information (or failure modes) only. They have been referred to by many names including:
  elephant tests
  torture tests
  HALT tests
  Qualitative tests are performed on small samples with the specimens subjected to a single severe level of stress, to a number of stresses or to a time-varying stress (i.e. stress cycling, cold to hot, etc.). If the specimen survives, it passes the test. Otherwise, appropriate actions will be taken to improve the product's design in order to eliminate the cause(s) of failure.
  Qualitative tests are used primarily to reveal probable failure modes. However, if not designed properly, they may cause the product to fail due to modes that would have never been encountered in real life. A good qualitative test is one that quickly reveals those failure modes that will occur during the life of the product under normal use conditions. In general, qualitative tests are not designed to yield life data that can be used in subsequent quantitative accelerated life data analysis as described in this reference. In general, qualitative tests do not quantify the life (or reliability) characteristics of the product under normal use conditions, however, they provide valuable information as to the types and level of stresses one may wish to employ during a subsequent quantitative test.
  Benefits and Drawbacks of Qualitative Tests
  Benefit: Increase reliability by revealing probable failure modes.
  Provide valuable feedbackin designing quantitative tests and in may cases they are a precursor to a quantitative test.
  Unanswered question: What is the reliability of the product at normal use conditions?
  Quantitative Accelerated Life Testing
  Quantitative accelerated life testing (QALT) unlike the qualitative testing methods described previously, consists of tests designed to quantify the life characteristics of the product, component or system under normal use conditions and thereby provide reliability information. Reliability information can include the determination of the probability of failure of the product under use conditions, mean life under use conditions and projected returns and warranty costs. It can also be used to assist in the performance of risk assessments, design comparisons, etc.
  Quantitative accelerated life testing can take the form of usage rate acceleration or overstress acceleration. Both accelerated life test methods are described next. Because usage rate acceleration test data can be analyzed with typical life data analysis methods, the overstress acceleration method is the testing method relevant to both ALTA and the remainder of this reference.
发表于 2005-9-5 00:33 | 显示全部楼层
  Quantitative Accelerated Life Tests
  For all life tests, some time-to-failure information (or time-to-an-event) for the product is required since the failure of the product is the event we want to understand. In other words, if we wish to understand, measure and predict any event, we must observe the event!
  Most products, components or systems are expected to perform their functions successfully for long periods of time, such as years. Obviously, for a company to remain competitive the time required to obtain times-to-failure data must be considerably less than the expected life of the product.
  Two methods of acceleration, usage rate acceleration and overstress acceleration, have been devised to obtain times-to-failure data at an accelerated pace. For products that do not operate continuously, one can accelerate the time it takes to induce failures by continuously testing these products. This is called usage rate acceleration. For products for which usage rate acceleration is impractical, one can apply stress(es) at levels which exceed the levels that a product will encounter under normal use conditions and use the times-to-failure data obtained in this manner to extrapolate to use conditions. This is called overstress acceleration.
  Usage Rate Acceleration
  For products that do not operate continuously under normal conditions, if the test units are operated continuously, failures are encountered earlier than if the units were tested at normal usage. For example, a microwave oven operates for small periods of time every day. One can accelerate a test on microwave ovens by operating them more frequently until failure. The same could be said of washers. If we assume an average washer use of 6 hours a week, one could conceivably reduce the testing time 28-fold by testing these washers continuously.
  To simplify the example, other stresses or secondary effects that might be encountered, such as turning the unit on and off, or overheating due to continuous usage, are not mentioned. The practitioner should take these effects into account when the test is formulated. For example, to overcome this challenge, the test washers could run their cycles with 30 minute rest periods to take other stresses into account.
  Data obtained through usage acceleration can be analyzed with the same methods used to analyze regular times-to-failure data. These typical life data analysis techniques are thoroughly described in ReliaSoft's Life Data Analysis Reference [= 4) BSPSPopupOnMouseOver(event);;" href="javascript:BSSCPopup('reference_31.htm');">31] and facilitated by ReliaSoft's Weibull++ software package (http://Weibull.ReliaSoft.com).
  The limitation of usage rate acceleration arises when products, such as computer servers and peripherals, maintain a very high or even continuous usage. In such cases, usage acceleration, even though desirable, is not a feasible alternative. In these cases the practitioner must stimulate, usually through the application of stress(es), the product to fail. This method of accelerated life testing is called overstress acceleration and is described next.
  Overstress Acceleration
  For products with very high or continuous usage, the accelerated life testing practitioner must stimulate the product to fail in a life test. This is accomplished by applying stress(es) that exceed the stress(es) that a product will encounter under normal use conditions. The times-to-failure data obtained under these conditions is then used to extrapolate to use conditions. Accelerated life tests can be performed at high or low temperature, humidity, voltage, pressure, vibration, etc. in order to accelerate or stimulate the failure mechanisms. They can also be performed at a combination of these stresses.
  Stresses and Stress Levels
  Accelerated life test stresses and stress levels should be chosen so that they accelerate the failure modes under consideration but do not introduce failure modes that would never occur under use conditions. Normally, these stress levels will fall outside the product specification limits but inside the design limits as illustrated next:
  Fig. 1: Typical stress range for a component, product or system.
  This choice of stresses and stress levels and the process of setting up the experiment is of the utmost importance. Consult your design engineer(s) and material scientist(s) to determine what stimuli (stress) is appropriate as well as to identify the appropriate limits (or stress levels). If these stresses or limits are unknown, multiple tests with small sample sizes can be performed in order to ascertain the appropriate stress(es) and stress levels. Proper use of Design of Experiments (DOE) methodology is also crucial at this step. In addition to proper stress selection, the application of the stresses must be accomplished in some logical, controlled and quantifiable fashion. Accurate data on the stresses applied as well as the observed behavior of the test specimens must be maintained.
  It is clear that as the stress used in an accelerated test becomes higher the required test duration decreases. However, as the stress level moves farther away from the use conditions, the uncertainty in the extrapolation increases. Confidence intervals provide a measure of the uncertainty in extrapolation. Confidence intervals are presented in Appendix A: A Brief Statistical Background.
  详细资料请看
  http://www.chinarel.com/acceltestwebcontents.asp
发表于 2005-9-7 09:29 | 显示全部楼层
不错,收藏仔细看看
发表于 2006-7-19 11:20 | 显示全部楼层
推荐
庆声科技股份有限公司
网址WWW.KSON.COM.TW
  联系人:徐大忠
    电话;021-52550125-816
   手机:13788960073-6816
  邮箱:XUDAZHONG2008@126.COM
GMT+8, 2025-1-12 06:49 , Processed in 0.067123 second(s), 17 queries , Gzip On.
