查看: 2175|回复: 2
[混合编程] 安装Compaq Visual Fortran 6.6,Matlab的mex指令不能正常编译fortran文件.
发表于 2006-9-8 17:30 | 显示全部楼层 |阅读模式
在这里,先设置 mex环境,选1(Compaq Visual Fortran 6.6)。
然后mex yprimef.f包错。yprimef.f是Matlab 6.5自带的mex例程。
请教各位是为什么?
注:mex本身应该没有问题,如果mex -setup,可以正常编译C语言的程序。
>> mex -setup
Please choose your compiler for building external interface (MEX) files:
Would you like mex to locate installed compilers [y]/n? y
Select a compiler:
[1] Compaq Visual Fortran version 6.6 in D:\Program Files\Microsoft Visual Studio
[2] Lcc C version 2.4 in D:\MATLAB6P5\sys\lcc
[3] Microsoft Visual C/C++ version 6.0 in D:\Program Files\Microsoft Visual Studio
[0] None
Compiler: 1
Please verify your choices:
Compiler: Compaq Visual Fortran 6.6
Are these correct?([y]/n): y
The default options file:
"C:\Documents and Settings\ljian\Application Data\MathWorks\MATLAB\R13\mexopts.bat"
is being updated from D:\MATLAB6P5\BIN\WIN32\mexopts\df66opts.bat...
>> mex -g yprimef.f
   Creating library _lib3128.lib and object _lib3128.exp
_lib3128.exp : error LNK2001: unresolved external symbol _MEXFUNCTION@16
yprimef.dll : fatal error LNK1120: 1 unresolved externals
  D:\MATLAB6P5\BIN\WIN32\MEX.PL: Error: Link of 'yprimef.dll' failed.
??? Error using ==> mex
Unable to complete successfully
 楼主| 发表于 2006-9-8 17:35 | 显示全部楼层
不知道是不是Matlab的设置问题?
发表于 2006-11-15 12:34 | 显示全部楼层
我也遇到同样的问题,不知怎么办?
GMT+8, 2025-1-17 03:05 , Processed in 0.056714 second(s), 18 queries , Gzip On.
