查看: 21670|回复: 7
[编程技巧] matlab中load命令的用法是什么的?
发表于 2006-9-7 08:32 | 显示全部楼层 |阅读模式
发表于 2006-9-7 09:01 | 显示全部楼层
LOAD Load workspace variables from disk.
   LOAD FILENAME retrieves all variables from a file given a full pathname
   or a MATLABPATH relative partial pathname (see PARTIALPATH).  If FILENAME
   has no extension LOAD looks for FILENAME and FILENAME.mat and treats it
   as a binary "MAT-file". If FILENAME has an extension other than .mat, it
   is treated as ASCII.
   LOAD, by itself, uses the binary "MAT-file" named 'matlab.mat'.  It is
   an error if 'matlab.mat' is not found.
   LOAD FILENAME X loads only X.
   LOAD FILENAME X Y Z ... loads just the specified variables.  The
   wildcard '*' loads variables that match a pattern (MAT-file only).
   LOAD -ASCII FILENAME or LOAD -MAT FILENAME forces LOAD to treat the file
   as either an ASCII file or a MAT file regardless of file extension.  With
   -ASCII, LOAD will error if the file is not numeric text.  With -MAT, LOAD
   will error if the file is not a MAT file generated by SAVE -MAT.
   If FILENAME is a MAT file, requested variables from FILENAME are created
   in the workspace. If FILENAME is not a MAT file, a double precision array
   is created with name based on FILENAME.  Leading underscores or digits in
   FILENAME are replaced with X.  Other non-alpha chars in FILENAME are
   replaced with underscores.
   S = LOAD(...) returns the contents of FILENAME in variable S.  If
   FILENAME is a MAT file, S is a struct containing fields matching the
   variables retrieved.  If FILENAME is an ASCII file, S is a double
   precision array.
   Use the functional form of LOAD, such as LOAD('filename'), when the
   file name is stored in a string, when an output argument is requested,
   or if FILENAME contains spaces.
   See also SAVE, WHOS, UILOAD, SPCONVERT, PARTIALPATH, IOFUN, FILEFORMATS.
  Overloaded methods
   help activex/load.m
Overloaded methods
    help ccshelp/load.m
    help mdevproject/load.m
    help cgproject/load.m
    help xpc/load.m
发表于 2006-9-7 09:05 | 显示全部楼层
如果数据格式是XXXX.mat ,可以直接 load XXXX;
如果文本格式XXXX.txt,也可以用load载入,load 'XXXX.txt';
另外文本格式也可以通过Import data转换成.mat格式,matlab默认处理.mat格式数据!
发表于 2006-9-7 09:06 | 显示全部楼层
例:a=load('filename.txt');
filename.txt 存数据的文本文件,在当前路径/一般指在work文件夹下.
运行后a中的数据即为文件中的数据.
上面的英文帮助是最全的.
 楼主| 发表于 2006-9-7 16:00 | 显示全部楼层
谢谢!
发表于 2007-12-27 10:53 | 显示全部楼层
我的mat 文件是一个矩阵,load 进去后,怎么不是矩阵格式
是个struct格式.
这是怎么回事啊??
如图
发表于 2007-12-27 10:56 | 显示全部楼层
看 写给学习 matlab 的新手们 这个精华帖
发表于 2007-12-27 11:40 | 显示全部楼层
回复 #7 eight 的帖子
刚刚没搜到:@L
GMT+8, 2025-1-13 22:43 , Processed in 0.100865 second(s), 21 queries , Gzip On.
