查看: 6870|回复: 8
[CFX应用] A folded mesh ( ansys 和cfx耦合)
发表于 2006-9-3 14:05 | 显示全部楼层 |阅读模式
ansys 和cfx耦合出现如下问题:
Fatal error notification received The reported error is A folded mesh
has occurred.  This process will shut down after the current stagger
iteration.
通过调整时间步可以解决这个问题,有人知道这是为什么吗?
发表于 2006-9-6 22:37 | 显示全部楼层
folded mesh字面翻译是网格交错的意思,应该是CFX网格动态变化过大造成的。
减小时间步长之后,网格变化量减小,这样发生网格交错的可能性就小了。
 楼主| 发表于 2006-9-8 16:30 | 显示全部楼层
to FSI (在线)
如果把时间步长设置的太小也会出现这种情况,为什么呢?
FSI (在线)能解释一下吗?
  谢谢
www.bxwx.la/b/2/2726/ 造化之门  发表于 2014-12-26 04:13
发表于 2006-9-9 14:38 | 显示全部楼层
因为我没有用CFX做过,具体不清楚是什么问题。
如果folded mesh指的是动态网格变化造成的,那么时间步长很小应该不是问题所在。你还是查一下CFX看看有没有相应的错误信息说明。
 楼主| 发表于 2006-9-10 09:56 | 显示全部楼层
谢谢
发表于 2011-11-16 09:35 | 显示全部楼层
回复 4 # FSI 的帖子
你好,请问我调小后依然报错,/COM,ANSYS RELEASE 13.0    UP20101012       21:54:21    11/15/2011
*** WARNING ***                         CP =       2.219   TIME= 21:54:38
ANSYS results must be written into the database for Multifield
analysis.  The /CONFIG,NOELDB,1 command is ignored.
*** WARNING ***                         CP =      12.703   TIME= 21:56:39
The component MFLC_1_1_DISP_2 was created for MFLC,1,1,DISP,2 command
to display improperly mapped nodes.  Set /debug,,2 for more
information on improperly mapped nodes.
*** WARNING ***                         CP =      43.641   TIME= 21:57:23
Element shape checking is currently inactive.  Issue SHPP,ON or
SHPP,WARN to reactivate, if desired.
*** WARNING ***                         CP =     356.234   TIME= 22:17:24
The maximum number of stagger iterations has been reached for
multifield solver but the interface quantities have not yet converged.
  The analysis will proceeds to the next time step.  Increase number of
stagger iterations using the MFITER command for converged interface
solution.
*** WARNING ***                         CP =     670.906   TIME= 22:39:06
solution.
*** WARNING ***                         CP =     928.500   TIME= 22:59:26
solution.
*** WARNING ***                         CP =    1173.578   TIME= 23:18:47
solution.
*** WARNING ***                         CP =    1417.625   TIME= 23:37:21
solution.
*** WARNING ***                         CP =    1662.609   TIME= 23:55:58
solution.
*** WARNING ***                         CP =    1906.234   TIME= 00:14:05
solution.
*** WARNING ***                         CP =    2151.781   TIME= 00:32:12
solution.
*** WARNING ***                         CP =    2396.391   TIME= 00:50:18
solution.
*** WARNING ***                         CP =    2644.609   TIME= 01:08:21
solution.
*** WARNING ***                         CP =    2891.375   TIME= 01:26:20
solution.
*** WARNING ***                         CP =    3137.812   TIME= 01:44:24
solution.
*** WARNING ***                         CP =    3387.734   TIME= 02:02:33
solution.
*** FATAL ***                           CP =    3414.500   TIME= 02:03:39
Fatal error notification received from field solver: CFX.  The message
received is: CFX encountered the error: 0. A folded mesh has
occurred.  This process will shut down as soon as possible.
The above error is non-recoverable by ANSYS
  ANSYS run terminated by the indicated error
  Current data base saved if possible.
发表于 2014-10-21 14:08 | 显示全部楼层
tsw20031117 发表于 2011-11-16 09:35
回复 4 # FSI 的帖子
你好,请问我调小后依然报错,/COM,ANSYS RELEASE 13.0    UP20101012       21:54:2 ...
你好,“ANSYS results must be written into the database for Multifield
analysis.  The /CONFIG,NOELDB,1 command is ignored.”这个警告,会对计算带来影响吗?
发表于 2017-6-19 09:24 | 显示全部楼层
**** 作者被禁止或删除 内容自动屏蔽 ****
不知道你的问题解决了没有??
GMT+8, 2024-11-24 21:49 , Processed in 0.054599 second(s), 19 queries , Gzip On.
