查看: 2768|回复: 2
中途停止正在运算的JOB
发表于 2006-8-19 10:48 | 显示全部楼层 |阅读模式
If you run Abaqus with interactive mode, you can use Ctrl+C to kill it.
If you run in backgroud, you can use:
abaqus suspend job=jobname to suspend your job;
abaqus resume job=jobname to resume your suspended job;
abaqus terminate job=jobname to terminate your job.
来自:likuiming收集的资料
发表于 2008-7-31 13:33 | 显示全部楼层
請問這些指令都能夠直接打在DOS下嗎?? 還有如果我終止了運算,是否還能夠用resume接續計算?/
发表于 2008-7-31 16:42 | 显示全部楼层
可以,restart,但计算前必须生成了res
GMT+8, 2025-1-17 15:15 , Processed in 0.076803 second(s), 17 queries , Gzip On.
