查看: 8520|回复: 11
[综合讨论] matlab有进行洛伦兹拟合的函数吗?
发表于 2006-8-14 19:02 | 显示全部楼层 |阅读模式
我用过高斯拟合的函数,比如说:fit(d',b1','Gauss2','MaxIter',1000);进行洛伦兹拟合的话是不是把'Gauss2'换成相应的参数就行了?如果进行洛伦兹拟合的话应该用什么参数呢?
或者还有其它能进行洛伦兹拟合的函数吗?
发表于 2006-8-14 21:25 | 显示全部楼层
你可以用cflibhelp看一下有没有这种拟合模型
The Curve Fitting Library is a library of models for data fitting
with the FIT function.
These models are divided into groups according to the type of
equations being modeled.
The groups are
    GROUP           DESCRIPTION
    distribution  : distribution models such as Weibull
    exponential   : models involving exponential terms
    fourier       : initial terms of fourier series up to eighth order
    gaussian      : sum of gaussian models up to eighth order
    interpolant   : interpolants
    polynomial    : polynomial models up to ninth order
    power         : power function and sum of two power functions
    rational      : rational equation models
    sin           : sum of sin functions up to eighth order
    spline        : splines
To list only the model equations for a group, type CFLIBHELP
followed by the group name.
Example:
   cflibhelp polynomial
All models in the Curve Fitting Library:
  DISTRIBUTION MODELS
        MODELNAME             EQUATION
         weibull               Y = a*b*x^(b-1)*exp(-a*x^b)
  EXPONENTIAL MODELS
        MODELNAME             EQUATION
          exp1                 Y = a*exp(b*x)
          exp2                 Y = a*exp(b*x)+c*exp(d*x)
  FOURIER SERIES
        MODELNAME             EQUATION
        fourier1               Y = a0+a1*cos(x*p)+b1*sin(x*p)
        fourier2               Y = a0+a1*cos(x*p)+b1*sin(x*p)+a2*cos(2*x*p)+b2*sin(2*x*p)
        fourier3               Y = a0+a1*cos(x*p)+b1*sin(x*p)+...+a3*cos(3*x*p)+b3*sin(3*x*p)
        fourier8               Y = a0+a1*cos(x*p)+b1*sin(x*p)+...+a8*cos(8*x*p)+b8*sin(8*x*p)
      where p = 2*pi/(max(xdata)-min(xdata)).
  GAUSSIAN SUMS (Peak fitting)
        MODELNAME             EQUATION
         gauss1                Y = a1*exp(-((x-b1)/c1)^2)
         gauss2                Y = a1*exp(-((x-b1)/c1)^2)+a2*exp(-((x-b2)/c2)^2)
         gauss3                Y = a1*exp(-((x-b1)/c1)^2)+...+a3*exp(-((x-b3)/c3)^2)
         gauss8                Y = a1*exp(-((x-b1)/c1)^2)+...+a8*exp(-((x-b8)/c8)^2)
  INTERPOLANT
        INTERPTYPE            DESCRIPTION
        linearinterp           linear interpolation
        nearestinterp          nearest neighbor interpolation
        splineinterp           cubic spline interpolation
        pchipinterp            shape-preserving (pchip) interpolation
  POLYNOMIAL MODELS
        MODELNAME             EQUATION
          poly1                Y = p1*x+p2
          poly2                Y = p1*x^2+p2*x+p3
          poly3                Y = p1*x^3+p2*x^2+...+p4
          poly9                Y = p1*x^9+p2*x^8+...+p10
  POWER MODELS
        MODELNAME             EQUATION
         power1                Y = a*x^b
         power2                Y = a*x^b+c
  RATIONAL MODELS
     Rational Models are polynomials over polynomials with the leading coefficient
     of the denominator set to 1. Model names are ratij, where i is the order of the
     numerator and j is the order of the denominator. The orders go up to five for
     both the numerator and the denominator. For example:
        MODELNAME             EQUATION
          rat02                Y = (p1)/(x^2+q1*x+q2)
          rat21                Y = (p1*x^2+p2*x+p3)/(x+q1)
          rat55                Y = (p1*x^5+...+p6)/(x^5+...+q5)
  SUM OF SIN FUNCTIONS
        MODELNAME             EQUATION
          sin1                 Y = a1*sin(b1*x+c1)
          sin2                 Y = a1*sin(b1*x+c1)+a2*sin(b2*x+c2)
          sin3                 Y = a1*sin(b1*x+c1)+...+a3*sin(b3*x+c3)
          sin8                 Y = a1*sin(b1*x+c1)+...+a8*sin(b8*x+c8)
  SPLINES
        SPLINETYPE             DESCRIPTION
        cubicspline             cubic interpolating spline
        smoothingspline         smoothing spline
 楼主| 发表于 2006-8-14 21:38 | 显示全部楼层
原帖由 vibshare 于 2006-8-14 21:25 发表
这么看来是没有洛伦兹拟合啦?
发表于 2006-8-14 21:39 | 显示全部楼层
好像是没有,需要自己写代码
 楼主| 发表于 2006-8-14 21:56 | 显示全部楼层
原帖由 vibshare 于 2006-8-14 21:39 发表
好像是没有,需要自己写代码
多谢!
发表于 2006-8-15 09:25 | 显示全部楼层
拟合方程什么样的?
如果拟合方程能够给出来,matlab实现起来也不困难
不过可能会碰到初值的选取问题
 楼主| 发表于 2006-8-15 21:26 | 显示全部楼层
原帖由 happy 于 2006-8-15 09:25 发表
拟合方程什么样的?
不过可能会碰到初值的选取问题
其实我就是对一组数据进行拟合,需要知道拟合出来的峰值(y)对应的横坐标(x),如:
X=[
1        2        3        4        5        6        7        8        9        10        11        12        13        14        15        16        17        18        19        20        21        22        23        24]
Y=[
22274        29600        41118        56346        83056        128804        187105        257344        322412        383516        416329        431047        433702        424422        398539        340765        270589        190081        123456        83148        59149        41192        29408        20589]
虽然用fit(d',b1','Gauss2','MaxIter',1000)这个函数可以拟合出来峰位约为12.6,但是觉得速度慢了一些。洛伦兹拟合也可以给出一个峰位,想试一下速度会不会快一些。
发表于 2006-8-16 09:34 | 显示全部楼层
不好意思,不知道洛伦兹的拟合函数表达式是什么样的
如果有表达式的话很多函数应该都能实现
发表于 2006-8-16 13:19 | 显示全部楼层
洛伦兹拟合函数: y = p1+2*p2/pi*p3/(4*(x-p4)^2+p3^2)
高斯拟合函数: y = p1+p2/(p3*sqrt(pi/2))*exp(-(2*(x-p4)^2/p3^2))
对于cauchenyu的数据:
洛伦兹拟合函数:
p1                 -124305.537715397
p2                 11032195.2501208
p3                 12.0844406736081
p4                 12.5755491636434
均方差(RMSE): 15882.2076659963
相关系数(R): 0.994700355729377
高斯拟合函数
p1                 6753.50914863686
p2                 -4629285.10441749
p3                 -8.2999354559485
p4                 12.574216703645
均方差(RMSE): 9668.32080744164
相关系数(R): 0.998039347117299
从结果看,高斯函数比洛伦兹函数更好一些。用1stOpt算的,用时不超过1秒
发表于 2006-8-16 14:24 | 显示全部楼层
客观的讲1stOpt在做拟合方面还是不错的
发表于 2012-5-28 11:57 | 显示全部楼层
来支持一下,刚来看得不太明白。
GMT+8, 2025-1-8 07:32 , Processed in 0.073967 second(s), 17 queries , Gzip On.
