查看: 1429|回复: 0
[综合讨论] 求助:关于保存模型的问题!急~~~~~~~
发表于 2006-8-8 18:09 | 显示全部楼层 |阅读模式
我在装好了MATLAB7.0之后,建立了一个simulink模型,在保存的时候出现了问题。一直不能保存!它给的提示是这样的:
    The modle 'untitled' contains characters that cannot be encoded with the modle`scharacter encoding,'GBK'.Either:
1)change the character encoding setting of the modle,by using:set_param('untitled','SavedCharacterEncoding','GBK'),or
2)idengtify the characters that cannot be encoded and remove them from the modle.The first unsupported character occurs on line 55,byte offset 22 in the file
D:\MATLAB71\work\untitled.err
希望各位给帮帮忙呀~我以为是编码问题,把系统的编码改称简体编码'big5',还是不行。轻大家给看看!!!小弟在这里先谢谢了~:Q:Q:Q:'(
[ 本帖最后由 cdwxg 于 2006-8-8 19:41 编辑 ]
GMT+8, 2025-1-18 03:42 , Processed in 0.079256 second(s), 17 queries , Gzip On.
