查看: 3742|回复: 1
[Fortran] 用Burg算法求AR模型的参数
发表于 2006-8-6 07:25 | 显示全部楼层 |阅读模式
主程序:
  1. c----------------------------------------------------------------------
  2. c   main program harburg : to test subroutine ARBURG
  3. c   To compute the AR model coefficients by Burg algorithm ,IP=10
  4. c   Please  link subroutine ARBURG,AR1PSD RELFFT,PSPLOT
  5. c----------------------------------------------------------------------
  6.         complex x(0:127),a(0:10),ef(0:127),eb(0:127)
  7.         data n/128/,ip/10/,mfre/4096/,ts/1./
  8.         open(3,file='test.dat',status='old')
  9.         do 20 k=0,n-1
  10.            read(3,*)x(k)
  11. 20      continue
  12.         close(3)
  13.         call arburg(x,a,ef,eb,n,ip,ep,ierror)
  14.         if(ierror.eq.0) goto 30
  15.         write(*,*)'   stop at rotine aryuwa,    ierror=',ierror
  16.         stop
  17. 30      write(*,*)'   white noise variance=',ep
  18.         write(*,*)'              k               a(k)'
  19.         do 40 k=0,ip-1
  20. 40      write(*,41)k,a(k)
  21. 41      format('      ',i10,2f14.6)
  22.         call ar1psd(a,ip,mfre,ep,ts)
  23.         stop
  24.         end
子程序:
  1.         subroutine arburg(x,a,ef,eb,n,ip,ep,ierror)
  2. c----------------------------------------------------------------------
  3. c   Routine ARBURG: To estimate the AR parameters by Burg algorithm.
  4. c   Input Parameters:
  5. c          N  : Number of data samples;
  6. c          IP : Order of autoregressive model;
  7. c          X  : Array of complex data samples, X(0) through X(N-1);
  8. c   Output Parameters:
  9. c         EP  : Real variable representing driving noise variance;
  10. c          A  : Array of complex AR parameters A(0) to A(IP);
  11. c    IERROR=0 : No error
  12. c          =1 : Ep<=0 .
  13. c                                      in chapter 12
  14. c----------------------------------------------------------------------
  15.         complex x(0:n-1),a(0:ip),ef(0:n-1),eb(0:n-1),sum
  16.         ierror=1
  17.         a(0)=1.
  18.         r0=0.
  19.         do 10 i=0,n-1
  20.            r0=r0+x(i)*conjg(x(i))
  21.            ef(i)=x(i)
  22.            eb(i)=x(i)
  23. 10      continue
  24.         den=0.0
  25.         r0=r0/float(n)
  26.         sum=0.0
  27.         do 20 i=1,n-1
  28.            den=den+ef(i)*conjg(ef(i))+eb(i-1)*conjg(eb(i-1))
  29.            sum=sum+ef(i)*conjg(eb(i-1))
  30. 20      continue
  31.         sum=-2.*sum
  32.         a(1)=sum/den
  33.         ep=r0*(1.-a(1)*conjg(a(1)))
  34.         do 30 i=n-1,1,-1
  35.            sum=ef(i)
  36.            ef(i)=sum+a(1)*eb(i-1)
  37.            eb(i)=eb(i-1)+conjg(a(1))*sum
  38. 30      continue
  39. c--------------------------------------------------------------------
  40.         do 80 m=2,ip
  41.            sum=0.0
  42.            do 40 i=m,n-1
  43.               sum=sum+ef(i)*conjg(eb(i-1))
  44. 40         continue
  45.            sum=-2.*sum
  46.            den=(1.-a(m-1)*conjg(a(m-1)))*den-ef(m-1)*conjg(ef(m-1))
  47.      *         -eb(n-1)*conjg(eb(n-1))
  48.            a(m)=sum/den
  49.            ep=ep*(1.-a(m)*conjg(a(m)))
  50.            if(ep.le.0) return
  51.            do 50 i=1,m-1
  52.               x(i)=a(i)+a(m)*conjg(a(m-i))
  53. 50         continue
  54.            do 60 i=1,m-1
  55.               a(i)=x(i)
  56. 60         continue
  57.            do 70 i=n-1,m,-1
  58.               sum=ef(i)
  59.               ef(i)=sum+a(m)*eb(i-1)
  60.               eb(i)=eb(i-1)+conjg(a(m))*sum
  61. 70         continue
  62. 80      continue
  63.         ierror=0
  64.         return
  65.         end
发表于 2006-10-12 11:11 | 显示全部楼层
请教
第一次算变量den的值用公式
后面的用式子:
这个式子是怎么推出来的?
GMT+8, 2025-1-6 16:38 , Processed in 0.056298 second(s), 17 queries , Gzip On.
