查看: 3254|回复: 6
[Fortran] 由AR模型参数得到功率谱
发表于 2006-8-6 07:23 | 显示全部楼层 |阅读模式
  1.       subroutine ar1psd(a,ip,mfre,ep,ts)
  2. c-----------------------------------------------------------------------
  3. c   Routine AR1PSD: To compute the power spectum by AR-model parameters.
  4. c   Input parameters:
  5. c          IP   : AR model order (integer)
  6. c          EP   : White noise variance of model input (real)
  7. c          Ts   : Sampling interval in seconds (real)
  8. c          A    : Complex array of AR  parameters, A(0) to A(IP)
  9. c   Output parameters:
  10. c          PSDR : Real array of power spectral density values
  11. c          PSDI : Real work array
  12. c                                       in chapter 12
  13. c-----------------------------------------------------------------------
  14.         complex a(0:ip)
  15.         dimension psdr(0:4095),psdi(0:4095)
  16.         do 10 k=0,ip
  17.            psdr(k)=real(a(k))
  18.            psdi(k)=aimag(a(k))
  19. 10      continue
  20.         do 20 k=ip+1,mfre-1
  21.            psdr(k)=0.
  22.            psdi(k)=0.
  23. 20      continue
  24.         call relfft(psdr,psdi,mfre,-1)
  25.         do 30 k=0,mfre-1
  26.            p=psdr(k)**2+psdi(k)**2
  27.            psdr(k)=ep*ts/p
  28. 30      continue
  29.         call psplot(psdr,psdi,mfre,ts)
  30.         return
  31.         end
发表于 2006-11-13 16:00 | 显示全部楼层
PS:
是两个子程序吧,请问我可以在哪里找到?
发表于 2006-11-14 19:31 | 显示全部楼层
  1.         subroutine relfft(xr,xi,n,isign)
  3. c  routinue RELFFT: To perform  the split-radix DIF fft algorithm.
  4. c  input parameters:
  5. c   xr,xi:real and image part of complex data for DFT/IDFT,n=0,...,N-1
  6. c      n : the dimension of xr and xi ;
  7. cISIGN=-1: For Forward Transform;
  8. c     =+1: For Inverse Transform.
  9. c  output parameters:
  10. c   xr,xi:real and image part  of DFT/IDFT's result,n=0,...,N-1
  11. c  Note  : N  must be a power of 2 .
  12. c  From Ref. [7] of chapter 5, Modified by Lao Changan
  13. c                                       in chapter 5
  14. c----------------------------------------------------------------------
  15.         dimension xr(0:n-1),xi(0:n-1)
  16.         do 5 m=1,16
  17.            n2=2**m
  18.            if(n.eq.n2) go to 8
  19. 5       continue
  20.         write(*,*)'  N is not a power of 2'
  21.         return
  22. 8       n2=n*2
  23.         es=-isign*atan(1.0)*8.0
  24.         do 10 k=1,m-1
  25.            n2=n2/2
  26.            n4=n2/4
  27.            e=es/n2
  28.            a=0
  29.            do 20 j=0,n4-1
  30.               a3=3*a
  31.               cc1=cos(a)
  32.               ss1=sin(a)
  33.               cc3=cos(a3)
  34.               ss3=sin(a3)
  35.               a=(j+1)*e
  36.               is=j
  37.               id=2*n2
  38. 40            do 30 i0=is,n-1,id
  39.               i1=i0+n4
  40.               i2=i1+n4
  41.               i3=i2+n4
  42.               r1=xr(i0)-xr(i2)
  43.               s1=xi(i0)-xi(i2)
  44.               r2=xr(i1)-xr(i3)
  45.               s2=xi(i1)-xi(i3)
  46.               xr(i0)=xr(i0)+xr(i2)
  47.               xi(i0)=xi(i0)+xi(i2)
  48.               xr(i1)=xr(i1)+xr(i3)
  49.               xi(i1)=xi(i1)+xi(i3)
  50.               if(isign.eq.1)goto 41
  51.               s3=r1-s2
  52.               r1=r1+s2
  53.               s2=r2-s1
  54.               r2=r2+s1
  55.               goto 42
  56. 41            s3=r1+s2
  57.               r1=r1-s2
  58.               s2=-r2-s1
  59.               r2=-r2+s1
  60. 42            xr(i2)=r1*cc1-s2*ss1
  61.               xi(i2)=-s2*cc1-r1*ss1
  62.               xr(i3)=s3*cc3+r2*ss3
  63.               xi(i3)=r2*cc3-s3*ss3
  64. 30            continue
  65.               is=2*id-n2+j
  66.               id=4*id
  67.               if(is.lt.n-1) goto 40
  68. 20         continue
  69. 10      continue
  70. c
  71. c       ------------ special last stage -------------------------
  72.         is=0
  73.         id=4
  74. 50      do 60 i0=is,n-1,id
  75.            i1=i0+1
  76.            xtr=xr(i0)
  77.            xti=xi(i0)
  78.            xr(i0)=xtr+xr(i1)
  79.            xi(i0)=xti+xi(i1)
  80.            xr(i1)=xtr-xr(i1)
  81.            xi(i1)=xti-xi(i1)
  82. 60      continue
  83.            is=2*id-2
  84.            id=4*id
  85.            if(is.lt.n-1) goto 50
  86. 100     j=1
  87.         n1=n-1
  88.         do 104 i=1,n1
  89.            if(i.ge.j) goto 101
  90.            xtr=xr(j-1)
  91.            xti=xi(j-1)
  92.            xr(j-1)=xr(i-1)
  93.            xi(j-1)=xi(i-1)
  94.            xr(i-1)=xtr
  95.            xi(i-1)=xti
  96. 101        k=n/2
  97. 102        if(k.ge.j) goto 103
  98.                 j=j-k
  99.                 k=k/2
  100.                 goto 102
  101. 103        j=j+k
  102. 104     continue
  103.         if(isign.eq.-1)return
  104.         do 105 i=0,n-1
  105.         xr(i)=xr(i)/n
  106.         xi(i)=xi(i)/n
  107. 105     continue
  108.         return
  109.         end
  1.       subroutine psplot(psdr,psdi,mfre,ts)
  3. c   Routine PSPLOT: To plot the normalized power spectum curve on the
  4. c                      normalized frequency axis from -.5 to  +.5 .
  5. c        mfre : Points in frequency axis and must be the power of 2.
  6. c        ts    : Sampling interval in seconds (real).
  7. c        psdr : Real array of power spectral density values.
  8. c        psdi : Real work array.
  9. c                                            in Chapter 11
  10. c-----------------------------------------------------------------------
  11.         dimension psdr(0:mfre-1),psdi(0:mfre-1)
  12.         m2=mfre/2
  13.         do 40 k=0,m2-1
  14.            psdi(k)=psdr(k)
  15.            psdr(k)=psdr(k+m2)
  16.            psdr(k+m2)=psdi(k)
  17. 40      continue
  18.         pmax=psdr(0)
  19.         do 50 k=1,mfre-1
  20.            if(psdr(k).gt.pmax) pmax=psdr(k)
  21. 50      continue
  22.         do 60 k=0,mfre-1
  23.            psdr(k)=psdr(k)/pmax
  24.            if(psdr(k).le.0.0)psdr(k)=.000001
  25. 60      continue
  26.         fs=1./ts
  27.         fs=fs/float(mfre)
  28.         open(3,file='psd.dat',status='new')
  29.         do 100 k=0,mfre-1
  30.            faxis=fs*(k-m2)
  31.            write(3,*)faxis,10.*alog10(psdr(k))
  32. 100      continue
  33.         close(3)
  34.         return
  35.         end
原帖由 dxjuan115 于 2006-11-13 16:00 发表
PS:
是两个子程序吧,请问我可以在哪里找到?
你看一下是否是上面给的两个程序
发表于 2007-7-21 16:56 | 显示全部楼层
收藏了,谢谢
发表于 2007-7-31 21:20 | 显示全部楼层
好东西,收藏,谢谢
GMT+8, 2025-1-4 12:51 , Processed in 0.066054 second(s), 18 queries , Gzip On.
