查看: 1878|回复: 2
[结构分析] 用QR阻尼法分析固有频率,中间突然出现几阶零,是怎么回事?
发表于 2006-7-17 11:30 | 显示全部楼层 |阅读模式
如题,结果如下,
  *****  INDEX OF DATA SETS ON RESULTS FILE  *****
   SET    TIME/FREQ(Damped)   TIME/FREQ(Undamped)   LOAD STEP  SUBSTEP  CUMULATIVE
     1  0.0000     0.87601E-03j      0.87601E-03         1         1         1
        0.0000    -0.87601E-03j
     2-0.99481      176.03    j       166.39             1         2         2
      -0.99481     -176.03    j
     3 -6.6455      398.26    j       387.90             1         3         3
       -6.6455     -398.26    j
     4 -3.5851      471.78    j       431.36             1         4         4
       -3.5851     -471.78    j
     5  93.844      547.86    j       462.87             1         5         5
        93.844     -547.86    j
     6  111.83      639.00    j       539.80             1         6         6
        111.83     -639.00    j
     7  118.75      647.44    j       559.41             1         7         7
        118.75     -647.44    j
     8  115.98      652.09    j       578.01             1         8         8
        115.98     -652.09    j
     9  91.739      671.27    j       590.32             1         9         9
        91.739     -671.27    j
    10  48.595      684.00    j       607.12             1        10        10
        48.595     -684.00    j
    11 -48.703      853.61    j       633.18             1        11        11
       -48.703     -853.61    j
    12 -88.035      906.26    j       640.53             1        12        12
       -88.035     -906.26    j
    13 -132.42      1008.0    j       654.70             1        13        13
       -132.42     -1008.0    j
    14 -1073.6      0.0000    j       691.32             1        14        14
       -1073.6      0.0000    j
    15 -1099.2      0.0000    j       731.67             1        15        15
       -1099.2      0.0000    j
    16 -1143.4      0.0000    j       770.30             1        16        16
       -1143.4      0.0000    j
    17 -94.980      1141.3    j       1005.3             1        17        17
       -94.980     -1141.3    j
    18 -1214.1      0.0000    j       1030.0             1        18        18
       -1214.1      0.0000    j
    19 -1246.5      0.0000    j       1183.4             1        19        19
       -1246.5      0.0000    j
    20 -88.681      1264.0    j       1281.0             1        20        20
       -88.681     -1264.0    j
    21 -1285.0      0.0000    j       1425.0             1        21        21
       -1285.0      0.0000    j
    22 -166.54      1409.7    j       1503.5             1        22        22
       -166.54     -1409.7    j
    23 -645.31      1408.4    j       1552.9             1        23        23
       -645.31     -1408.4    j
    24 -1551.9      0.0000    j       1651.2             1        24        24
       -1551.9      0.0000    j
    25 -95.210      1575.9    j       1787.6             1        25        25
       -95.210     -1575.9    j
    26 -121.03      1664.5    j       1833.4             1        26        26
       -121.03     -1664.5    j
    27 -89.852      1692.9    j       1887.9             1        27        27
       -89.852     -1692.9    j
    28 -75.075      1905.6    j       1959.6             1        28        28
       -75.075     -1905.6    j
    29 -111.77      1946.5    j       2115.3             1        29        29
       -111.77     -1946.5    j
    30 -95.822      2116.1    j       2246.5             1        30        30
       -95.822     -2116.1    j
    31 -2325.1      0.0000    j       2473.8             1        31        31
       -2325.1      0.0000    j
    32 -71.240      2364.8    j       2550.0             1        32        32
       -71.240     -2364.8    j
    33 -97.207      2403.0    j       2623.8             1        33        33
       -97.207     -2403.0    j
    34 -58.966      2537.0    j       2685.5             1        34        34
       -58.966     -2537.0    j
    35 -45.153      2596.6    j       2830.4             1        35        35
       -45.153     -2596.6    j
    36 -2670.1      0.0000    j       2954.1             1        36        36
       -2670.1      0.0000    j
    37 -44.071      2783.0    j       2995.6             1        37        37
       -44.071     -2783.0    j
    38 -49.736      2910.2    j       3233.2             1        38        38
       -49.736     -2910.2    j
    39 -36.178      2978.9    j       3433.7             1        39        39
       -36.178     -2978.9    j
    40 -3164.9      0.0000    j       3515.5             1        40        40
       -3164.9      0.0000    j
    41 -3202.6      0.0000    j       3558.9             1        41        41
       -3202.6      0.0000    j
    42 -11.244      3221.7    j       3575.3             1        42        42
       -11.244     -3221.7    j
    43 -42.853      3378.8    j       3968.6             1        43        43
       -42.853     -3378.8    j
    44 -3386.3      0.0000    j       4090.4             1        44        44
       -3386.3      0.0000    j
    45 -45.937      3462.2    j       4152.3             1        45        45
       -45.937     -3462.2    j
    46 -29.327      3530.4    j       4251.3             1        46        46
       -29.327     -3530.4    j
    47 -29.112      3542.5    j       4488.6             1        47        47
       -29.112     -3542.5    j
    48 -36.254      3933.3    j       4578.3             1        48        48
       -36.254     -3933.3    j
    49 -3989.6      0.0000    j       4643.0             1        49        49
       -3989.6      0.0000    j
    50 -4018.8      0.0000    j       4666.4             1        50        50
       -4018.8      0.0000    j
比如说14~16,出现了虚部,即固有频率为零,这是怎么回事呢?
发表于 2007-5-23 20:57 | 显示全部楼层
回复 #1 sheman2001 的帖子
出现虚部可能有下面的原因:
k矩阵不是对称矩阵;
阻尼的影响;
没有消除刚体自由度;
没有消除自由度相等的情况;
发表于 2009-12-20 13:58 | 显示全部楼层
如果计算后结果,频率突然降低,然后又增大,这是什么原因呢?如
1    320Hz
2   280Hz
3  400Hz
GMT+8, 2025-1-27 08:07 , Processed in 0.134923 second(s), 18 queries , Gzip On.
