查看: 3845|回复: 11
[声学基础] [转帖]振动噪声常用名词术语解释
发表于 2005-8-15 15:30 | 显示全部楼层 |阅读模式
振动:The oscillatory (back and forth) motion of a physical object.
噪声:Any component of a transducer signal which does not represent the variable intended to be measured.
固有频率(振动中最重要的概念):The frequency of free vibration of a mechanical system at which a specific natural mode of the system elements assumes its maximum amplitude.
强迫振动:The response vibration of a mechanical system due to a forcing function (exciting force). Typically, forced vibration has the same frequency as that of the exciting force.
自由振动:Vibration response of a mechanical system following an impulse-like initial perturbation (change of position, velocity or external force). Depending on the kind of perturbation, the mechanical system responds with free vibrations at one or more of its natural frequencies.
绝对振动:Vibration of an object as measured relative to an inertial (fixed) reference frame. Accelerometers and velocity transducers measure absolute vibration typically of machine housings or structures; thus they are referred to as seismic transducers or inertial transducers.
简谐振动:Sinusoidal vibration with a single frequency component.
赫兹:(Hz) Unit of frequency measurement in cycles per second.
频率:The repetition rate of a periodic vibration per unit of time. Vibration frequency is typically expressed in units of cycles per second (Hertz) or cycles per minute (to more easily relate to shaft rotative speed frequency). In fact, since many common machine malfunctions produce vibration which has a fixed relationship to shaft rotative speed, vibration frequency is often expressed as a function of shaft rotative speed. 1X is a vibration with a frequency equal to shaft rpm, 2X vibration is at twice shaft rpm, 0.5X vibration with a frequency equal to one-half shaft rpm, etc.
振幅:The magnitude of periodic dynamic motion (vibration). Amplitude is typically expressed in terms of signal level, e.g., millivolts or milliamps, or the engineering units of the measured variable, e.g., mils, micrometres (for displacement), inches per second (for velocity), etc. The amplitude of a signal can be measured in terms of peak to peak, zero to peak, root mean square, or average.
相位角:The timing relationship, in degrees, between two vibration signals, such as a Keyphasor® pulse and a vibration signal; also, the phase difference between two signals, such as the input force signal and output response signal. The "lag" corresponds to "minus" in mathematical formulations.
加速度:The time rate of change of velocity. For harmonic motion, this is often expressed as g or a. Typical units for acceleration are feet per second per second (ft/s2) pk, meters per second per second (m/s2) pk, or more commonly g pk (= acceleration of earths gravity = 386.1 in/s2 = 32.17 ft/s2 = 9.81 m/s2). Acceleration measurements are generally made with an accelerometer and are typically used to evaluate high frequency vibration of a machine casing or bearing housing due to blade passing, gear mesh, cavitation, rolling element bearing defects, etc.
速度:The time rate of change of displacement. Typical units for velocity are inches/second or millimetres/second, zero to peak. Velocity measurements are used to evaluate machine housing and other structural response characteristics. Electronic integration of a velocity signal yields displacement, but not position.
位移:The change in distance or position of an object relative to a reference. Machinery vibration displacement is typically a peak to peak measurement of the observed vibrational motion or position, and is usually expressed in units of mils or micrometres. Proximity probes measure displacement directly. Signal integration is required to convert a velocity signal to displacement, but does not provide the initial displacement (distance from a reference) measurement.
分贝:A numerical expression of the ratio of the power or voltage levels of electrical signals.
dB = 10 log P1/P2 = 20 log V1/V2.
共振:The condition in which the frequency of an external force coincides with a natural frequency of the system. A resonance typically is identified by an amplitude peak, accompanied by a maximum rate of change of phase lag angle.
频谱:Commonly a presentation of the amplitudes of a signal's frequency components versus their frequencies. Or the frequency content of a signal.
信噪比:The number formed by dividing the magnitude of the signal by the magnitude of the noise present in the signal. A low noise signal has a high Signal-to-Noise Ratio, while a high noise signal has a low Signal-to-Noise Ratio. The noise can originate from many different sources and is considered to be any part of the signal which does not represent the parameter being measured.
发表于 2005-10-22 15:45 | 显示全部楼层
回复:(empty)[转帖]振动噪声常用名词术语解释
比例阻尼:proportional damping
传递矩阵法:transfer matrix method
颤振:flutter 喘振:surge
功率谱密度函数:power spectral density function
功率谱密度矩阵:power spectral density matrix
互谱密度函数:cross-spectral density function
互谱密度函数:cross-spectral density matrix
互相关函数:cross-correlation function
混沌振动:chaotic vibration
简正模态函数:normal modal function
简正模态矩阵:normal modal matrix
模态截断法:mode truncation method
模态综合法:component modal synthesis method
均值Mean value
方差 Variance
机械阻抗 Mechanical impedance
位移阻抗 Displacement impedance
速度阻抗 Speed impedance
加速度阻抗Acceleration impedance
发表于 2006-7-14 11:23 | 显示全部楼层
好资料!我正需要!
发表于 2006-9-5 20:34 | 显示全部楼层
不错啊
发表于 2006-9-15 00:37 | 显示全部楼层
thanks
发表于 2006-9-15 20:53 | 显示全部楼层
不错,好贴,
发表于 2006-12-8 11:54 | 显示全部楼层
谢谢了啊
英语太菜
正是我需
发表于 2006-12-8 14:26 | 显示全部楼层
都看中文的了,看来也要搞搞英文的看看了,走向国际水平嘛,呵呵
发表于 2008-6-16 10:09 | 显示全部楼层
不错。这样再看英文资料时,能更方便些了。
发表于 2009-8-22 23:26 | 显示全部楼层
收藏了,谢谢楼主分享!
发表于 2009-8-25 09:49 | 显示全部楼层
谢谢
:lol ,呵呵,太谢谢了
发表于 2009-10-9 21:20 | 显示全部楼层
:victory: :victory: :victory:
GMT+8, 2025-1-26 11:57 , Processed in 0.077774 second(s), 17 queries , Gzip On.
