查看: 1888|回复: 2
[工具箱] delphi能够怎样才能调用神经网络工具箱函数呢
发表于 2006-7-14 16:14 | 显示全部楼层 |阅读模式
大家好,我现在用神经网络和delphi结合作课题,现在只能实现delphi调用matlab中的命令,但是调用不了神经网络工具箱里的语句。是不是只有自己写神经网络的算法程序了呢?请各位朋友指点指点.谢谢了!
发表于 2006-7-14 18:32 | 显示全部楼层
我觉得你还是生成matlab的exe文件,然后通过文件进行数据交换好一些,这样简单,可行!
只不过感觉运行效率不高,不知道是不是通病!
 楼主| 发表于 2006-7-16 16:42 | 显示全部楼层
我已经试过这种方法,有问题:
     1. 我用mcc命令试过出现下面的错误:
         The MATLAB Compiler does not currently support MATLAB object-oriented programming.  References to the method "train" will produce a run-time error.
Warning: File: abcgai Line: 89 Column: 5
The MATLAB Compiler does not currently support MATLAB object-oriented programming.  References to the method "init" will produce a run-time error.
Warning: File: newff Line: 167 Column: 7
Warning: File: newff Line: 133 Column: 7
The MATLAB Compiler does not currently support MATLAB object-oriented programming.  References to the method "network" will produce a run-time error.
2.生成的执行文件打开的时候一闪而过,根本看不到什么
      神经网络工具箱的函数好像不太识别。
GMT+8, 2025-1-31 04:36 , Processed in 0.075153 second(s), 17 queries , Gzip On.
