查看: 3293|回复: 0
[综合讨论] DYMORE USER'S MANUAL zz
发表于 2005-8-10 13:28 | 显示全部楼层 |阅读模式
  http://www.ae.gatech.edu/people/obauchau/manual/manual.html
  next up previous contents
  Next: Contents Contents
  Olivier A. Bauchau
  School of Aerospace Engineering,
  Georgia Institute of Technology
  * Contents
  * ActuatorElements: Actuator Elements
  o Hac: hydraulic device definition
  + NOTES
  + Graphical parameters
  o HydChmb: hydraulic chamber definition
  + NOTES
  o HydModl: hydraulic device model definition
  + NOTES
  + Linear hydraulic actuator
  + Simple hydraulic damper
  + Hydraulic damper with pressure relief valves
  + Examples
  + Sensors
  o HydOrfc: hydraulic orifice definition
  + NOTES
  o HydPrvl: hydraulic pressure relief valve
  + NOTES
  o LubModl: lubrication model definition
  + NOTES
  o OilProp: Oil property definition
  + NOTES
  * AerodynamicElements: Aerodynamic Elements
  o AeroInt: aerodynamic interface definition
  + Introduction
  + NOTES
  + Control parameters
  + Kinematics interface
  + Loads interface
  + File names
  + COPTER interface
  + RDYNE interface
  + CHARM interface
  + Fourier transform parameters
  + Inflow definition
  + Axis systems
  + Frame definition
  # The fuselage frame
  # The shaft frame
  # The rotor frame
  # The hub frame
  Details of the kinematics interface
  # Relative airstation position in hub frame
  # Relative airstation displacement in hub frame
  # Relative airstation orientation in hub frame
  # Relative airstation orientation change in hub frame
  # The airstation lag, flap and pitch angles
  # The azimuthal angle $ \Psi $
  o Inflow: inflow definition
  + NOTES
  + Sensors
  o LfnLine: lifting line definition
  + NOTES
  + Airstation location
  + Sensors
  + Maps
  * AerodynamicProperties: Aerodynamic Properties
  o AirProp: air property definition
  + NOTES
  o AirTable: airtable definition
  + NOTES
  o LfnProp: lifting line property definition
  + NOTES
  * AnalysisControls: Analysis Control Parameters
  o FemCtrl: finite element control parameters
  + NOTES
  o StpCtrl: step control parameters
  + NOTES
  + Convergence criterion
  + Time adaptivity
  + Constraint equation scaling
  Algorithmic numerical dissipation
  + Archival rate
  + Eigen Analysis
  o GrfCtrl: graphics control parameters
  + NOTES
  o PltCtrl: plotting control parameters
  + NOTES
  + Examples
  o IConditions: initial condition definition
  + NOTES
  * ConstraintElements: Constraint Elements
  o Arb: associated rigid body definition
  + NOTES
  + Examples
  + Sensors
  o Csj: curve sliding joint definition
  + NOTES
  o Csu: curve sliding joint motion definition
  + NOTES
  o Cyj: cylindrical joint definition
  + NOTES
  + Sensors
  o Lnc: linear constraint definition
  + NOTES
  o Pcj: planar contact joint
  + NOTES
  o Plj: planar joint definition
  + NOTES
  + Sensors
  o Prd: prescribed displacement definition
  + NOTES
  + Sensors
  o Prj: prismatic joint definition
  + NOTES
  + Sensors
  o Pru: relative displacement definition
  + NOTES
  + Examples
  + Sensors
  o Rvj: revolute joint definition
  + NOTES
  + Sensors
  o Rvr: relative rotation definition
  + NOTES
  + Examples
  + Sensors
  o Sce: spatial clearance element definition
  + NOTES
  o Scj: spatial contact joint
  + NOTES
  o Shj: spherical joint definition
  + NOTES
  + Sensors
  o Unj: universal joint definition
  + NOTES
  + Sensors
  o Whl: wheel definition
  + NOTES
  * ControllerElements: Controller Elements
  o AutoPlt: auto-pilot definition
  + NOTES
  o Contrlr: controller definition
  + NOTES
  + Sensors
  * ExternalLoading: External Loading
  o DeadLoad: dead load definition
  + NOTES
  o EdgeLoad: load distribution definition
  + NOTES
  o FaceLoad: pressure distribution definition
  + NOTES
  o Gravity: gravity definition
  + NOTES
  o LoadTable: loading table definition
  + NOTES
  o RigRot: rigid rotation definition
  + NOTES
  o PresTable: pressure table definition
  + NOTES
  * GeometricElements: Geometric Elements
  o Boundary: boundary condition definition
  + NOTES
  o Curve: curve definition
  + NOTES
  + Cubic Spline
  + Examples
  o FxdFrame: fixed frame definition
  + NOTES
  + Examples
  o MeshCurv: curve mesh parameters definition
  + NOTES
  o MvgFrame: moving frame definition
  + NOTES
  o OriDist: orientation distribution
  + NOTES
  o Point: point definition
  + NOTES
  o Surface: surface definition
  + NOTES
  + Examples
  o Triad: triad definition
  + NOTES
  * GraphicalObjects: Graphical Objects
  o GrfParam: graphical parameters definition
  + NOTES
  o Shape: shape definition
  + NOTES
  o ViewParm: view parameters definition
  + NOTES
  * StructuralElements: Structural Elements
  o Asc: associated connection definition
  + NOTES
  + Sensors
  o Bld: beam definition
  + NOTES
  + Sensors
  + Maps
  o Cbl: cable definition
  + NOTES
  + Sensors
  o Flx: flexible joint definition
  + NOTES
  + Sensors
  o Mbn: membrane definition
  + NOTES
  + Sensors
  o Mse: modal super-element definition
  + NOTES
  + Sensors
  o Rgb: rigid body definition
  + NOTES
  + Sensors
  o Shl: shell definition
  + NOTES
  + Sensors
  * StructuralProperties: Structural Properties
  o BklModl: backlash model definition
  + NOTES
  o BldProp: beam property definition
  + NOTES
  + Centroid
  + Shear center
  o CblProp: cable property definition
  + NOTES
  o ClrModl: clearance model definition
  + NOTES
  o CntModl: contact model definition
  + NOTES
  + Sensors
  o Damper: damper definition
  + NOTES
  o FctModl: friction model definition
  + NOTES
  + The Coulomb model
  + The LuGre model
  + Sensors
  o FlxProp: flexible joint property definition
  + NOTES
  o MassProp: mass property definition
  + NOTES
  o MbnProp: membrane property definition
  + NOTES
  o ShlProp: shell property definition
  + NOTES
  o Spring: spring definition
  + NOTES
  o ThickProp: thickness property definition
  + NOTES
  * UtilityObjects: Utility Objects
  o Copy: copy command
  + NOTES
  + Examples
  o Include: include command
  + NOTES
  o Map: map definition
  + NOTES
  o Sensor: sensor definition
  + NOTES
  o SigCon: signal conditioning definition
  + NOTES
  o SigPost: signal post processing
  + NOTES
  o TimFun: time function definition
  + NOTES
  + Examples
  * Appendices
  o Chebychev: Chebychev polynomials
  + Examples
  o Comments: comments
  + NOTES
  o Connections: multibody system connectivity
  o Orientations: definition of orientations
  + Two vectors
  + A single vector
  Euler angles with 3-1-3 sequence
  Euler angles with 3-2-3 sequence
  Euler angles with 3-2-1 sequence
  Euler angles with 3-1-2 sequence
  o Herting: Herting's transformation
  + NOTES
  o Installation: Installation notice
  o Rotations: the Wiener-Milenkovic parameters
  + The rotation tensor
  + The angular velocity vector
  + Composition of rotations
  + Extended Wiener-Milenkovic parameters
  + Examples
  o Table: data tables
  + Single entry table
  + Discrete single entry table
  + Double entry table
  * Bibliography
  * About this document ...
  U-WOTAN\Olivier A. Bauchau 2005-08-01
[此贴子已经被作者于2005-8-10 13:28:57编辑过]
GMT+8, 2025-1-6 12:41 , Processed in 0.053293 second(s), 17 queries , Gzip On.
