查看: 3161|回复: 14
[CFD及热分析] 求助(流固耦合传热问题)
发表于 2006-6-23 21:32 | 显示全部楼层 |阅读模式
计算时出现警告:A total of 2136 heat fluxes and film coefficients were defined. Only 0
film coefficients and 0 heat fluxes were found. Please check model
for these boundary conditions defined on internal or unselected nodes.
命令流如下:
esel,s,elem,,12121 选择12121单元
nsel,r,ext 选择单元表面节点
sf,all,conv,3,293
发表于 2006-6-24 07:27 | 显示全部楼层
试试对每个单元进行加载,而不是节点
 楼主| 发表于 2006-6-25 12:57 | 显示全部楼层
AaronSpark你好,我尝试了向每个单元加载,命令流如下:
*do,i,0,100
esel,s,elem,,12121+i
sfe,all,,conv,0,3
sfe,all,,conv,2,293
*end do
可是还是那个错误,为什么啊?谢谢
 楼主| 发表于 2006-6-27 14:09 | 显示全部楼层
自己顶一下
发表于 2006-6-27 14:51 | 显示全部楼层
好象学习也挺深入了啊帮你顶一下。。。呵呵
 楼主| 发表于 2006-6-27 16:42 | 显示全部楼层
这是我用多场耦合求解器的程序
  1. /prep7
  2. ! fluid model
  3. toffst,0et,1,fluid142
  4. CYL4,0,0,0,0,2,360,20
  5. /pnum,line,1 显示实体编号
  6. /pnum,area,1
  7. /replot
  8. vsel,s,volu,,1
  9. smrtsiz,8
  10. mshape,1,3D
  11. mshkey,0
  12. vatt,1,,1
  13. vmesh,allasel,s,,,3,4
  14. NSLa,S,1
  15. d,all,vx,0
  16. d,all,vy,0
  17. d,all,vz,0
  18. sf,all,fsin,1 ! Define Surface interfaceasel,s,,,1
  19. NSLa,S,1
  20. d,all,temp,310
  21. d,all,vx,0.2
  22. d,all,vy,0
  23. d,all,vz,0asel,s,,,2
  24. NSLa,S,1
  25. d,all,pres,0
  26. ALLSEL,ALL
  27. FLDA,SOLU,TEMP,T
  28. FLDA2,ITER,EXEC,10
  29. FLDATA8,NOMI,DENS,1060
  30. FLDATA8,NOMI,VISC,0.0424
  31. FLDATA8,NOMI,COND,1
  32. FLDATA8,NOMI,SPHT,4
  33. FLDATA34,mir,MOME,0.5
  34. ! thermal model
  35. mp,kxx,2,0.67 定义固体材料
  36. et,2,solid70
  37. CYL4,0,0,2,0,10,360,20
  38. /pnum,line,1 显示实体编号
  39. /pnum,area,1
  40. /replot
  41. vsel,s,volu,,2
  42. smrtsiz,7
  43. mshape,1,3D
  44. mshkey,0
  45. vatt,2,,2
  46. vmesh,allasel,s,,,9,10
  47. NSLa,S,1
  48. sf,all,fsin,1 ! Define Surface interfaceasel,s,,,5,8
  49. NSLa,S,1
  50. sf,all,conv,3,293allsel,allfini/solu
  51. mfan,on ! Activate ANSYS Multi-field solver analysismfel,1,1 ! fluid field
  52. mfel,2,2 ! thermal field
  53. mfor,2,1 ! Order for field solution
  54. mfco,all,1.0e-2 ! Convergence settings
  55. antyp,stat
  56. eqslv,iccg
  57. deltim,10
  58. kbc,1
  59. mfcm,2, ! thermal field analysis optionsfldata,time,step,10 ! Field loop time increment within a stagger
  60. kbc,1mfcm,1 ! fluid field analysis options
  61. mfti,10 ! End time
  62. mfou,1 ! Write solution every time step
  63. mfdt,10 ! Stagger time increment
  64. mfit,10 ! Max staggers
  65. mfint,cons ! Conservative load transfer
  66. mfsu,1,2,temp,1 ! Transfer heat flow to solid field
  67. mfsu,1,1,temp,2 ! Transfer heat flow to fluid field
  68. solve ! Solve the ANSYS Multi-field solver problem
  69. save
  70. finish
 楼主| 发表于 2006-6-27 16:47 | 显示全部楼层
这是用流固耦合方式求解
  1. /prep7
  2. et,1,fluid142
  3. et,2,solid70
  4. et,3,fluid141
  5. et,4,plane55
  6. ! 定义了五种单元类型cyl4,0,0,0,0,10 !建立几何形状
  7. cyl4,0,0,0,0,80 ! 画了一个圆面和一个圆环
  9. /pnum,area,1
  10. /replot
  11. aovlap,1,2 !面搭接
  12. aplot !画面
  13. numcmp,all !压缩编号
  14. allsellsel,s,,,1,8 选择线
  15. lesize,all,6 对于所选线段进行网格划分设置asel,s,,,1 选择面
  16. aatt,,,3 设置所选面的单元类型为(用于未划分网格的面)
  17. asel,inve 选择除以外的所有面
  18. aatt,,,4mshape,1 使用三角形网格
  19. mshkey,0 使用自由网格划分
  20. alls
  21. amesh,allagen,2,1 !通过复制原有的圆面,产生一个新的重合的圆面
  22. aclear,1 ! 清除网格
  23. adel,1,,,1 !删除未划分的面积区域allseltype,2 !为随后生成的单元设置单元号和材料号
  24. esize,,10 !设置线分段数
  25. asel,s,,,2
  26. vext,all,,,0,0,80 !对于选择的面拉伸生成实体type,1
  27. esize,,10
  28. asel,s,,,3
  29. vext,all,,,0,0,80allsel
  30. aclear,all !删除所有面上的节点和网格
  31. etdel,3 !删除单元类型
  32. etdel,4
  33. numcmp,all
  34. asel,s,,,13,16
  35. nsla,s,1
  36. d,all,vx,0
  37. d,all,vy,0
  38. d,all,vz,0 !设置边界的无滑移边界条件
  39. SF,ALL,FSIN,1 !设置流固中流体的界面asel,s,,,12
  40. nsla,s,1
  41. d,all,temp,310 !设置入口温度
  42. d,all,vx,0.2 !设置入口速度
  43. d,all,vy,0
  44. d,all,vz,0
  45. asel,s,,,3
  46. nsla,s,1
  47. d,all,pres,0 !设置出口压力asel,s,,,8,11
  48. nsla,s,1
  49. SF,ALL,FSIN,1 !设置流固中固体的界面asel,s,,,1
  50. nsla,s,1
  51. d,all,temp,293
  52. asel,s,,,4,7
  53. nsla,s,1
  54. sf,all,conv,3,293
  55. allselfini
  56. /solutoffst,0
  57. mp,kxx,1,0.67 定义固体材料FLDA,SOLU,TEMP,T
  58. FLDA2,ITER,EXEC,10
  59. FLDATA8,NOMI,DENS,1060
  60. FLDATA8,NOMI,VISC,0.0424
  61. FLDATA8,NOMI,COND,1
  62. FLDATA8,NOMI,SPHT,4
  63. FLDATA34,mir,MOME,0.5fsan,on !流固耦合求解设置
  64. fsor,solid
  65. fstr,solid,stat
  66. fstr,fluid,stat
  67. fsin,CONS
  68. fsit,1
  69. fsdt,0.1
  70. fsco,all,0.1
  71. fsre,all,0.5
  72. fsou,last
  73. fldata,time,step,0.1
  74. deltim,0.1SAVESOLVE
 楼主| 发表于 2006-6-27 16:53 | 显示全部楼层
具体出错情况为:加载后可以显示所加的对流换热,但到求解是则显示出警告:A total of 2136 heat fluxes and film coefficients were defined.  Only 0 film coefficients and 0 heat fluxes were found.  Please check model
曾尝试过以下方法:加对流换热负荷到节点;加对流换热负荷到面;加负荷到单元;在外表面覆盖表面单元,通过表面单元加对流换热负荷,但都出现相同的错误。
 楼主| 发表于 2006-6-28 20:04 | 显示全部楼层
自己顶[em05]
发表于 2006-6-29 10:14 | 显示全部楼层
我是作结构的,对热可是不懂,不过我还是顶一下,希望你的问题尽快得到解决!
发表于 2006-7-2 03:19 | 显示全部楼层
别用all,用sfe,i 的形式看看
发表于 2006-7-4 16:07 | 显示全部楼层
现在也是初学,帮你顶拉~
 楼主| 发表于 2006-7-5 15:12 | 显示全部楼层
AaronSpark你好,你是说这样修改吗?
*do,i,0,100
sfe,12121+i,,conv,0,3
sfe,12121+i,,conv,2,293
*end do
可是这样还是出现那个错误
发表于 2006-7-16 00:18 | 显示全部楼层
俺也想问个问题啊:
俺想分析用电磁场对一杯水进行加热,在水进行自然对流情况下,怎样对其进行耦合啊?如果不加电磁场,只算一杯水在一定初始温度的情况下(有自然对流),其温度场分布俺已经分析出来,但不知道怎样将电磁场耦合进去,求高手进行指点!
俺的qq:104167323
发表于 2012-12-9 21:16 | 显示全部楼层
请问楼主做过ansys流固传热吗
GMT+8, 2025-1-10 01:31 , Processed in 0.066287 second(s), 18 queries , Gzip On.
