查看: 2120|回复: 2
[结构分析] 有谁做过流固耦合传热吗
发表于 2006-6-20 10:37 | 显示全部楼层 |阅读模式
有谁做过流固耦合共轭传热吗
我想做一个固体在流体中转动的问题
想知道流体的对流传热系数
有谁做过类似问题吗
指点一二,不胜感谢
发表于 2006-6-21 06:50 | 显示全部楼层
一个共轭传热的例子
  1. /BATCH
  2. /units,si
  3. !*
  4. /NOPR
  5. /PMETH,OFF,0
  6. KEYW,PR_SET,1
  7. KEYW,PR_STRUC,0
  8. KEYW,PR_THERM,0
  9. KEYW,PR_FLUID,0
  10. KEYW,PR_ELMAG,0
  11. KEYW,MAGNOD,0
  12. KEYW,MAGEDG,0
  13. KEYW,MAGHFE,0
  14. KEYW,MAGELC,0
  15. KEYW,PR_MULTI,0
  16. KEYW,PR_CFD,1
  17. /GO
  18. !*
  19. /COM,
  20. /COM,Preferences for GUI filtering have been set to display:
  21. /COM, FLOTRAN CFD
  22. !*
  23. /PREP7
  24. !*
  25. ET,1,FLUID141
  26. !*
  27. !*
  28. MPTEMP,,,,,,,,
  29. MPTEMP,1,0
  30. MPDATA,KXX,2,,398
  31. MPTEMP,,,,,,,,
  32. MPTEMP,1,0
  33. MPDATA,VISC,2,,200
  34. MPTEMP,,,,,,,,
  35. MPTEMP,1,0
  36. MPDATA,KXX,3,,0.276
  37. MPTEMP,,,,,,,,
  38. MPTEMP,1,0
  39. MPDATA,VISC,3,,200
  40. RECTNG,0,0.2,0,0.2,
  41. RECTNG,0.05,0.15,0,0.2,
  42. RECTNG,0.07,0.13,0,0.2,
  43. RECTNG,0,0.2,0.05,0.15,
  44. RECTNG,0,0.2,0.07,0.13,
  45. FLST,2,5,5,ORDE,2
  46. FITEM,2,1
  47. FITEM,2,-5
  48. AOVLAP,P51X
  49. FLST,5,60,4,ORDE,5
  50. FITEM,5,9
  51. FITEM,5,11
  52. FITEM,5,18
  53. FITEM,5,20
  54. FITEM,5,-76
  55. CM,_Y,LINE
  56. LSEL, , , ,P51X
  57. CM,_Y1,LINE
  58. CMSEL,,_Y
  59. !*
  60. LESIZE,_Y1,0.01, , , , , , ,1
  61. !*
  62. MSHAPE,0,2D
  63. MSHKEY,1
  64. !*
  65. FLST,5,16,5,ORDE,2
  66. FITEM,5,6
  67. FITEM,5,-21
  68. CM,_Y,AREA
  69. ASEL, , , ,P51X
  70. CM,_Y1,AREA
  71. CHKMSH,'AREA'
  72. CMSEL,S,_Y
  73. !*
  74. AMESH,_Y1
  75. !*
  76. CMDELE,_Y
  77. CMDELE,_Y1
  78. CMDELE,_Y2
  79. !*
  80. APLOT
  81. mat,2
  82. CM,_Y,AREA
  83. ASEL, , , , 30
  84. CM,_Y1,AREA
  85. CHKMSH,'AREA'
  86. CMSEL,S,_Y
  87. !*
  88. AMESH,_Y1
  89. !*
  90. CMDELE,_Y
  91. CMDELE,_Y1
  92. CMDELE,_Y2
  93. !*
  94. mat,3
  95. FLST,5,8,5,ORDE,2
  96. FITEM,5,22
  97. FITEM,5,-29
  98. CM,_Y,AREA
  99. ASEL, , , ,P51X
  100. CM,_Y1,AREA
  101. CHKMSH,'AREA'
  102. CMSEL,S,_Y
  103. !*
  104. AMESH,_Y1
  105. !*
  106. CMDELE,_Y
  107. CMDELE,_Y1
  108. CMDELE,_Y2
  109. !*
  110. EPLOT
  111. FLST,2,80,1,ORDE,29
  112. FITEM,2,1
  113. FITEM,2,-7
  114. FITEM,2,43
  115. FITEM,2,49
  116. FITEM,2,-54
  117. FITEM,2,85
  118. FITEM,2,-91
  119. FITEM,2,127
  120. FITEM,2,-133
  121. FITEM,2,169
  122. FITEM,2,-174
  123. FITEM,2,180
  124. FITEM,2,185
  125. FITEM,2,-188
  126. FITEM,2,205
  127. FITEM,2,-215
  128. FITEM,2,241
  129. FITEM,2,-251
  130. FITEM,2,277
  131. FITEM,2,283
  132. FITEM,2,-292
  133. FITEM,2,313
  134. FITEM,2,319
  135. FITEM,2,325
  136. FITEM,2,331
  137. FITEM,2,337
  138. FITEM,2,343
  139. FITEM,2,349
  140. FITEM,2,356
  141. !*
  142. /GO
  143. D,P51X, ,20, , , ,TEMP, , , , ,
  144. FLST,2,1,5,ORDE,1
  145. FITEM,2,30
  146. /GO
  147. !*
  148. BFA,P51X,HGEN,100000
  149. FLST,5,80,1,ORDE,29
  150. FITEM,5,1
  151. FITEM,5,-7
  152. FITEM,5,43
  153. FITEM,5,49
  154. FITEM,5,-54
  155. FITEM,5,85
  156. FITEM,5,-91
  157. FITEM,5,127
  158. FITEM,5,-133
  159. FITEM,5,169
  160. FITEM,5,-174
  161. FITEM,5,180
  162. FITEM,5,185
  163. FITEM,5,-188
  164. FITEM,5,205
  165. FITEM,5,-215
  166. FITEM,5,241
  167. FITEM,5,-251
  168. FITEM,5,277
  169. FITEM,5,283
  170. FITEM,5,-292
  171. FITEM,5,313
  172. FITEM,5,319
  173. FITEM,5,325
  174. FITEM,5,331
  175. FITEM,5,337
  176. FITEM,5,343
  177. FITEM,5,349
  178. FITEM,5,356
  179. CM,_Y,NODE
  180. NSEL,R, , ,P51X
  181. CM,_Y1,NODE
  182. CMSEL,S,_Y
  183. CMDELE,_Y
  184. !*
  185. !*
  186. !*
  187. D,_Y1,VX,0
  188. D,_Y1,VY,0
  189. !*
  190. CMDELE,_Y1
  191. !*
  192. FLDATA1,SOLU,TRAN,0
  193. FLDATA1,SOLU,FLOW,1
  194. FLDATA1,SOLU,TEMP,1
  195. FLDATA1,SOLU,TURB,0
  196. FLDATA1,SOLU,COMP,0
  197. FLDATA1,SOLU,VOF,0
  198. FLDATA1,SOLU,SFTS,0
  199. FLDATA1,SOLU,IVSH,0
  200. FLDATA1,SOLU,SWRL,0
  201. FLDATA1,SOLU,SPEC,0
  202. FLDATA1,SOLU,ALE,0
  203. FLDATA1,SOLU,RDSF,1
  204. !*
  205. /COM,,Steady State Analysis,0
  206. FLDATA2,ITER,EXEC,200,
  207. FLDATA2,ITER,OVER,50,
  208. FLDATA2,ITER,APPE,50,
  209. FLDATA3,TERM,VX,0.01,
  210. FLDATA3,TERM,VY,0.01,
  211. FLDATA3,TERM,VZ,0.01,
  212. FLDATA3,TERM,PRES,0.01,
  213. FLDATA3,TERM,TEMP,0.01,
  214. FLDATA3,TERM,ENKE,0.01,
  215. FLDATA3,TERM,ENDS,0.01,
  216. FLDATA5,OUTP,SUMF,10,
  217. !*
  218. FLDATA12,PROP,DENS,4
  219. FLDATA13,VARY,DENS,1
  220. FLDATA12,PROP,VISC,4
  221. FLDATA13,VARY,VISC,0
  222. FLDATA12,PROP,COND,4
  223. FLDATA13,VARY,COND,0
  224. FLDATA12,PROP,SPHT,4
  225. FLDATA13,VARY,SPHT,0
  226. !*
  227. FLDATA7,PROT,DENS,AIR-SI
  228. FLDATA8,NOMI,DENS,-1
  229. FLDATA9,COF1,DENS,0
  230. FLDATA10,COF2,DENS,0
  231. FLDATA11,COF3,DENS,0
  232. FLDATA7,PROT,VISC,AIR-SI
  233. FLDATA8,NOMI,VISC,-1
  234. FLDATA9,COF1,VISC,0
  235. FLDATA10,COF2,VISC,0
  236. FLDATA11,COF3,VISC,0
  237. FLDATA12,PROP,IVIS
  238. FLDATA7,PROT,COND,AIR-SI
  239. FLDATA8,NOMI,COND,-1
  240. FLDATA9,COF1,COND,0
  241. FLDATA10,COF2,COND,0
  242. FLDATA11,COF3,COND,0
  243. FLDATA7,PROT,SPHT,AIR-SI
  244. FLDATA8,NOMI,SPHT,-1
  245. FLDATA9,COF1,SPHT,0
  246. FLDATA10,COF2,SPHT,0
  247. FLDATA11,COF3,SPHT,0
  248. !*
  249. ACEL,0,9.81,0,
  250. FLDATA26,STAB,MOME,1e-5,
  251. FLDATA26,STAB,PRES,1e-5,
  252. FLDATA26,STAB,TEMP,1e-5,
  253. FLDATA26,STAB,TURB,1e+015,
  254. FLDATA26,STAB,VISC,0,
  255. !*
  256. FLDATA34,MIR,MOME,1,
  257. FLDATA34,MIR,TEMP,1,
  258. FLDATA34,MIR,TURB,0,
  259. !*
  260. FLDATA31,CAPP,VELO,0
  261. FLDATA31,CAPP,TEMP,1
  262. FLDATA31,CAPP,PRES,0
  263. !*
  264. FLDATA31,CAPP,TMIN,20,
  265. FLDATA31,CAPP,TMAX,1e+020,
  266. !*
  267. FINISH
发表于 2011-5-2 16:43 | 显示全部楼层
楼上是个高手,灰常v5,鉴定完毕
GMT+8, 2025-1-27 05:28 , Processed in 0.080696 second(s), 19 queries , Gzip On.
