查看: 2535|回复: 1
求教一个用ansys做随机振动分析的问题
发表于 2006-6-19 14:57 | 显示全部楼层 |阅读模式
<P>我用ansys做随机振动分析,请问如何在post 26中提取协方差,就是covariance, <BR>我每次提取时他都说:“store, psd command has previously been issued, cvar command can not be used in the same session, Please reset, redifine variables and then reissue CVAR"<BR>可是我reset了也redefine了,可是还是弹出同样的错误,请问如何解决?</P>
发表于 2006-6-26 12:50 | 显示全部楼层
ANSYS使用手则是这样的
<P 0cm 0cm 0pt">在<FONT face="Times New Roman">ANSYS 5.7</FONT>中用<FONT face="Times New Roman">post 26</FONT>后处理器来计算协方差:</P>
<P 0cm 0cm 0pt"><FONT face="Times New Roman">1 </FONT>选择菜单途径<FONT face="Times New Roman">Main Menu&gt;TimeHist Postpro&gt;Define Variable</FONT>,弹出<FONT face="Times New Roman">Define Time-History Variables</FONT>对话框。单击<FONT face="Times New Roman">Add</FONT>,弹出<FONT face="Times New Roman">Add time-History Variable</FONT>对话框。<p></p></P>
<P 0cm 0cm 0pt"><FONT face="Times New Roman">2 </FONT>选择<FONT face="Times New Roman">Nodal DOF result</FONT>,然后单击<FONT face="Times New Roman">OK</FONT>,弹出<FONT face="Times New Roman">Define Nodal Data</FONT>对话框。<p></p></P>
<P 0cm 0cm 0pt"><FONT face="Times New Roman">3 </FONT>指定<FONT face="Times New Roman">Ref. Number of variable</FONT>为<FONT face="Times New Roman">2</FONT>,<FONT face="Times New Roman">Nodal number</FONT>为<FONT face="Times New Roman">245</FONT>,<FONT face="Times New Roman">User-specified label</FONT>为<FONT face="Times New Roman">UZ245</FONT>,在<FONT face="Times New Roman">Data item</FONT>的右边窗口选择<FONT face="Times New Roman"> Translation UZ</FONT>。单击<FONT face="Times New Roman">OK</FONT>,关闭<FONT face="Times New Roman">define Nodal Data</FONT>对话框。<p></p></P>
<P 0cm 0cm 0pt"><FONT face="Times New Roman">4 </FONT>单击<FONT face="Times New Roman">Add</FONT>,弹出<FONT face="Times New Roman">Add Time-history Variable</FONT>对话框。<p></p></P>
<P 0cm 0cm 0pt"><FONT face="Times New Roman">5 Ref. Number of variable</FONT>为<FONT face="Times New Roman">3</FONT>,<FONT face="Times New Roman">Nodal number</FONT>为<FONT face="Times New Roman">240</FONT>,<FONT face="Times New Roman">User-specified label</FONT>为<FONT face="Times New Roman">UY240</FONT>,在<FONT face="Times New Roman">Data item</FONT>的右边窗口选择<FONT face="Times New Roman">Translation UZ</FONT>。单击<FONT face="Times New Roman">OK</FONT>,关闭<FONT face="Times New Roman">Define Nodal Data</FONT>对话框。<p></p></P>
<P 0cm 0cm 0pt"><FONT face="Times New Roman">6 </FONT>单击<FONT face="Times New Roman">Close</FONT>,关闭<FONT face="Times New Roman">Define Time-History Variables</FONT>对话框。<p></p></P>
<P 0cm 0cm 0pt"><FONT face="Times New Roman">7 </FONT>选择菜单途径<FONT face="Times New Roman">Main Menu&gt;TimeHist Postpro&gt;Calc Covariance</FONT>,弹出<FONT face="Times New Roman">Calculate Covariance</FONT>对话框,给<FONT face="Times New Roman">Reference number of resulting variables</FONT>输入<FONT face="Times New Roman">4</FONT>,给<FONT face="Times New Roman">Ref. no. of variables to be operated on</FONT>分别输入<FONT face="Times New Roman">2</FONT>和<FONT face="Times New Roman">3</FONT>。<p></p></P>
<P 0cm 0cm 0pt"><FONT face="Times New Roman">8 </FONT>单击<FONT face="Times New Roman">OK</FONT>,协方差计算结果输出到<FONT face="Times New Roman">Output window</FONT>窗口中。<p></p></P>
GMT+8, 2025-1-6 15:55 , Processed in 0.073530 second(s), 18 queries , Gzip On.
