查看: 2323|回复: 2
[求助]请教一下SIMULINK中电力系统模块饱和变压器的问题
发表于 2006-6-15 00:19 | 显示全部楼层 |阅读模式
where the base flux linkage (<v:shapetype> 磁通<v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><v:path connecttype="rect" gradientshapeok="t" extrusionok="f"></v:path><lock aspectratio="t" v:ext="edit"></lock></v:shapetype>base) and base current (Ibase) are the peak values obtained at nominal voltage power and frequency:<BR>The base flux is defined as the peak value of the sinusoidal flux (in webers) when winding 1 is connected to a 1 p.u. sinusoidal voltage source (nominal voltage). The 磁通 value defined above represents the base flux linkage (in volt-seconds). It is related to the base flux by the following equation<BR><BR>大概能读懂,但是却理解不了,这个是电力系统模块库PSB里面的饱和变压器中一段帮助说明,他里面磁通和电流的基准公式中的V1代表什么意思啊,我一直搞不明白,希望做过变压器暂态的高手,帮个忙啊!!!
 楼主| 发表于 2006-6-15 00:31 | 显示全部楼层
<P>唉,晕哦,我在论坛上的求助,一次都没有得到解决。</P>
发表于 2006-6-15 09:58 | 显示全部楼层
希望各位在这方面有经验的网友都来帮忙啊!<BR>
GMT+8, 2024-11-29 11:34 , Processed in 0.060574 second(s), 19 queries , Gzip On.
