查看: 2443|回复: 1
[FFT] 转贴:fft的vb实现
发表于 2006-6-14 15:05 | 显示全部楼层 |阅读模式
  FFT的VB实现- -Tag: FFT VB
  'FFT0 数组下标以0开始 FFT1 数组下标以1开始
  'AR() 数据实部 AI() 数据虚部
  'N 数据点数,为2的整数次幂
  'NI 变换方向 1为正变换,-1为反变换
  Public Const Pi = 3.1415926
  Public Sub FFT0(AR() As Double, AI() As Double, N As Integer, NI As Integer)
  Dim I As Integer, J As Integer, K As Integer, L As Integer, M As Integer
  Dim IP As Integer, LE As Integer
  Dim L1 As Integer, N1 As Integer, N2 As Integer
  Dim SN As Double, TR As Double, TI As Double, WR As Double, WI As Double
  Dim UR As Double, UI As Double, US As Double
  M = NTOM(N)
  N2 = N / 2
  N1 = N - 1
  SN = NI
  J = 1
  For I = 1 To N1
  If I < J Then
  TR = AR(J - 1)
  AR(J - 1) = AR(I - 1)
  AR(I - 1) = TR
  TI = AI(J - 1)
  AI(J - 1) = AI(I - 1)
  AI(I - 1) = TI
  End If
  K = N2
  While (K < J)
  J = J - K
  K = K / 2
  Wend
  J = J + K
  Next I
  For L = 1 To M
  LE = 2 ^ L
  L1 = LE / 2
  UR = 1#
  UI = 0#
  WR = Cos(Pi / L1)
  WI = SN * Sin(Pi / L1)
  For J = 1 To L1
  For I = J To N Step LE
  IP = I + L1
  TR = AR(IP - 1) * UR - AI(IP - 1) * UI
  TI = AI(IP - 1) * UR + AR(IP - 1) * UI
  AR(IP - 1) = AR(I - 1) - TR
  AI(IP - 1) = AI(I - 1) - TI
  AR(I - 1) = AR(I - 1) + TR
  AI(I - 1) = AI(I - 1) + TI
  Next I
  US = UR
  UR = US * WR - UI * WI
  UI = UI * WR + US * WI
  Next J
  Next L
  If SN <> -1 Then
  For I = 1 To N
  AR(I - 1) = AR(I - 1) / N
  AI(I - 1) = AI(I - 1) / N
  Next I
  End If
  End Sub
  Public Sub FFT1(AR() As Double, AI() As Double, N As Integer, NI As Integer)
  M = NTOM(N)
  N2 = N / 2
  N1 = N - 1
  SN = NI
  J = 1
  For I = 1 To N1
  If I < J Then
  TR = AR(J)
  AR(J) = AR(I)
  AR(I) = TR
  TI = AI(J)
  AI(J) = AI(I)
  AI(I) = TI
  End If
  K = N2
  While (K < J)
  J = J - K
  K = K / 2
  Wend
  J = J + K
  Next I
  For L = 1 To M
  LE = 2 ^ L
  L1 = LE / 2
  UR = 1#
  UI = 0#
  WR = Cos(Pi / L1)
  For J = 1 To L1
  IP = I + L1
  TR = AR(IP) * UR - AI(IP) * UI
  TI = AI(IP) * UR + AR(IP) * UI
  AR(IP) = AR(I) - TR
  AI(IP) = AI(I) - TI
  AR(I) = AR(I) + TR
  AI(I) = AI(I) + TI
  Next I
  US = UR
  Next J
  Next L
  If SN <> -1 Then
  For I = 1 To N
  AR(I) = AR(I) / N
  AI(I) = AI(I) / N
  Next I
  End If
  End Sub
  Private Function NTOM(N As Integer) As Integer
  Dim ND As Double
  ND = N
  NTOM = 0
  While (ND > 1)
  ND = ND / 2
  NTOM = NTOM + 1
  Wend
  End Function
  Public Sub FFT(INr#(), INi#(), n%, Mm%, TT#, NPP%)
  Dim FFTn1%, FFTn2%, FFTsn%, FFTj%, FFTi%, FFTip%, tmpR#, tmpI#, FFTk%, FFTL%, FFTLE#, FFTL1#, FFTus#, FFTur#, FFTui#, FFTwr#, FFTwi#
  FFTn2 = n / 2
  FFTn1 = n - 1
  FFTsn = NPP
  FFTj = 1
  For FFTi = 1 To FFTn1
  If (FFTi >= FFTj) Then GoTo X25
  tmpR = INr(FFTj)
  INr(FFTj) = INr(FFTi)
  INr(FFTi) = tmpR
  tmpI = INi(FFTj)
  INi(FFTj) = INi(FFTi)
  INi(FFTi) = tmpI
  X25: FFTk = FFTn2
  X45: If (FFTk >= FFTj) Then GoTo X35
  FFTj = FFTj - FFTk
  FFTk = FFTk / 2
  GoTo X45
  X35: FFTj = FFTj + FFTk
  Next FFTi
  For FFTL = 1 To Mm
  FFTLE = 2 ^ FFTL
  FFTL1 = FFTLE / 2
  FFTur = 1
  FFTui = 0
  FFTwr = Cos(3.1415926 / FFTL1)
  FFTwi = FFTsn * Sin(3.1415926 / FFTL1)
  For FFTj = 1 To FFTL1
  For FFTi = FFTj To n Step FFTLE
  FFTip = FFTi + FFTL1
  tmpR = INr(FFTip) * FFTur - INi(FFTip) * FFTui
  tmpI = INi(FFTip) * FFTur + INr(FFTip) * FFTui
  INr(FFTip) = INr(FFTi) - tmpR
  INi(FFTip) = INi(FFTi) - tmpI
  INr(FFTi) = INr(FFTi) + tmpR
  INi(FFTi) = INi(FFTi) + tmpI
  Next FFTi
  FFTus = FFTur
  FFTur = FFTus * FFTwr - FFTui * FFTwi
  FFTui = FFTui * FFTwr + FFTus * FFTwi
  Next FFTj
  Next FFTL
  If (FFTsn = -1) Then
  For FFTi = 1 To n
  INr(FFTi) = INr(FFTi) * TT
  INi(FFTi) = INi(FFTi) * TT
  Next FFTi
  Else
  For FFTi = 1 To n
  INr(FFTi) = INr(FFTi) / n / TT
  INi(FFTi) = INi(FFTi) / n / TT
  Next FFTi
  End If
  End Sub
  [ 本帖最后由 zhlong 于 2007-6-4 21:50 编辑 ]
发表于 2013-2-8 22:30 | 显示全部楼层
请问:这个fft代码有人用过吗?能在VB中实现吗?
GMT+8, 2025-1-8 23:36 , Processed in 0.077838 second(s), 17 queries , Gzip On.
