查看: 2367|回复: 6
[FFT] [求助]求分数阶傅立叶变换程序
发表于 2006-6-12 15:59 | 显示全部楼层 |阅读模式
谢谢!
发表于 2006-6-17 22:13 | 显示全部楼层
回复:(xcsyb)[求助]求分数阶傅立叶变换程序
  function Faf = frft(f, a)
  % The fast Fractional Fourier Transform
  % input: f = samples of the signal
  % a = fractional power
  % output: Faf = fast Fractional Fourier transform
  error(nargchk(2, 2, nargin));
  f = f(:);
  N = length(f);
  shft = rem((0:N-1)+fix(N/2),N)+1;
  sN = sqrt(N);
  a = mod(a,4);
  % do special cases
  if (a==0), Faf = f; return; end;
  if (a==2), Faf = flipud(f); return; end;
  if (a==1), Faf(shft,1) = fft(f(shft))/sN; return; end
  if (a==3), Faf(shft,1) = ifft(f(shft))*sN; return; end
  % reduce to interval 0.5 < a < 1.5
  if (a>2.0), a = a-2; f = flipud(f); end
  if (a>1.5), a = a-1; f(shft,1) = fft(f(shft))/sN; end
  if (a<0.5), a = a+1; f(shft,1) = ifft(f(shft))*sN; end
  % the general case for 0.5 < a < 1.5
  alpha = a*pi/2;
  tana2 = tan(alpha/2);
  sina = sin(alpha);
  f = [zeros(N-1,1) ; interp(f) ; zeros(N-1,1)];
  % chirp premultiplication
  chrp = exp(-i*pi/N*tana2/4*(-2*N+2:2*N-2)'.^2);
  f = chrp.*f;
  % chirp convolution
  c = pi/N/sina/4;
  Faf = fconv(exp(i*c*(-(4*N-4):4*N-4)'.^2),f);
  Faf = Faf(4*N-3:8*N-7)*sqrt(c/pi);
  % chirp post multiplication
  Faf = chrp.*Faf;
  % normalizing constant
  Faf = exp(-i*(1-a)*pi/4)*Faf(N:2:end-N+1);
  function xint=interp(x)
  % sinc interpolation
  N = length(x);
  y = zeros(2*N-1,1);
  y(1:2:2*N-1) = x;
  xint = fconv(y(1:2*N-1), sinc([-(2*N-3):(2*N-3)]'/2));
  xint = xint(2*N-2:end-2*N+3);
  function z = fconv(x,y)
  % convolution by fft
  N = length([x(:);y(:)])-1;
  P = 2^nextpow2(N);
  z = ifft( fft(x,P) .* fft(y,P));
  z = z(1:N);
发表于 2006-6-21 14:28 | 显示全部楼层
什么是分数阶傅立叶变换,作甚么用?
楼上的,什么是分数阶傅立叶变换,有什么特殊的用途吗?
发表于 2006-11-22 15:14 | 显示全部楼层
simon21可以留一下你的QQ号码或者邮箱吗?想和你交流一下FRFT,
我的QQ是45157494
邮箱是qingfeng506@yahoo.com.cn
发表于 2007-4-26 20:26 | 显示全部楼层
原帖由 bls 于 2006-6-21 14:28 发表
分数阶傅立叶变换是经典傅立叶变换的推广形式
它同时从时间域和频率域(或空间域)分析信号特征
发表于 2007-6-9 12:52 | 显示全部楼层
一块交流以下吧 我也对这方面感兴趣 QQ:290695558 邮箱:huangxh1985@tom.com
发表于 2008-9-11 21:59 | 显示全部楼层
simon21  请教下你,分数阶傅立叶变换,能不能应用到模态参数识别方面?我还没有找到相关的文献。
谢谢啦~~
GMT+8, 2025-1-11 20:04 , Processed in 0.055202 second(s), 18 queries , Gzip On.
