查看: 1736|回复: 1
[Virtual.Lab] 流固耦合问题汇总
发表于 2020-11-24 22:48 | 显示全部楼层 |阅读模式
萌新不懂就问,在做流固耦合仿真的时候,做完流体的模态分析后,想看下前面固体模态分析的图像。为什么看不了,而且出现这种结果?D:\Software_Practice\LMS\问题汇总
 楼主| 发表于 2020-11-24 22:53 | 显示全部楼层
You cannot edit the image because it is not in the current case.
--set the case that contains the image as the current one using the Set As Current Case command
--Or force the image activation using the Force Activate command
不知道怎么发图片,就手打了提示。 各位大哥大姐帮帮我吧
GMT+8, 2024-12-28 11:32 , Processed in 0.106388 second(s), 17 queries , Gzip On.
