查看: 1930|回复: 0
[Fluent应用] [求助]求教heat-exchanger模块如何输出结果
发表于 2006-6-8 13:13 | 显示全部楼层 |阅读模式
参考帮助文件,对于heat-exchanger模块的后处理有如下提示<BR>
<P>To view the computed values of total heat rejection, outlet temperature, and inlet temperature for your heat exchanger, you can use the following text command: <BR><FONT color=forestgreen><TT>define</TT> <IMG> <TT>user-defined</TT> <IMG> <TT>heat-exchanger</TT> <IMG> <TT>heat-exchanger-report</TT></FONT> <BR>但是在我的fluent中有<FONT face=新宋体 color=#228b22>heat-exchanger模块,但是没有找到heat-exchanger <IMG> <TT>heat-exchanger-report</TT><FONT color=#000000> 。希望大家帮忙看看,谢谢了</FONT></FONT></P>
GMT+8, 2024-11-26 06:54 , Processed in 0.069240 second(s), 17 queries , Gzip On.
