查看: 3122|回复: 1
[Patran专区] patran的气动弹性模块flightloads安装后,无法使用,求指教。
发表于 2019-6-27 14:33 | 显示全部楼层 |阅读模式
运行patran Flds2011(气弹模块)时,提示一下信息:Error initializing Flightloads. The Nastran command [ c:\MSC.Software\MSC.Nastran\bin\nastran.exe ] does not exist. This is normally defined with the [ Alocalcommand2010 ] environment variable defined in the [ P3_TRANS.INI ] file in [ p3_home ] and is used as the Nastran Server invocation.
请问各路大神应该怎么解决这个问题啊
发表于 2020-3-11 17:50 | 显示全部楼层
一个菜鸟弱弱的问一下,请问哪里能找到Flds模块并下载
GMT+8, 2025-1-14 08:34 , Processed in 0.057406 second(s), 22 queries , Gzip On.
