查看: 2266|回复: 0
crystal系列连续激光器
发表于 2019-6-13 16:40 | 显示全部楼层 |阅读模式
其它产品
产品名称: crystal系列连续激光器
型号规格: crystal系列
生产单位: Crystalaser
主要功能: 应用:
拉曼光谱、激光雷达、荧光光谱、共聚焦显微分析、种子激光、干涉、神经生物学、光镊、流式细胞学
核心特点: 特点:
波长473nm-1342nm,功率高达3W
低噪音、单纵模、超稳定
优异的光束指向稳定性与功率稳定性
风冷
TTL调制
自由空间出射、光纤耦合出射
主要指标: 波长473nm-1342nm,功率高达3W
473 nm Blue Laser
Wavelength
CW output, mW
      Low noise option
Transverse mode
Beam diameter (1/e2)
Beam divergence
Output stability, rms
Beam point stability
Polarization ratio
Longitudinal mode
    SLM available
Spectrum linewidth
Operating temperature
Operating voltage
Warm-up time
Power consumption
Size of laser head
Size of power supply
473 nm
150, 100, 75, 40, 25, 10, 5; Noise <3%(1Hz-5kHz)
70, 50, 25 mW; Noise <0.5%(1Hz-50MHz)
TEMoo, M2<1.2
0.25 mm
3 mrad
<2% over 8 hrs; Ultra-stable option: <0.25% over 24 hrs
+/-0.005 mrad/C
> 50 : 1
2-4 longitudinal modes
Single longitudinal mode with >100m coherence length
0.1 nm, nominal;         SLM version: < 10-5 nm
10 to 35 degree C
90-250 VAC or 9-20 VDC
1 minute
15 W
3 x 3 x 12 cm with a fixed 6 mm thick base plate
AC: 5x14x15 cm (2x5x6 inch) DC: 3.5x8.5x12.7 cm
CW Green Laser
Laser wavelength, nm
Laser Crystal
Output power, mW
Noise, rms
Transverse mode
Beam divergence
Polarization
Operating voltage
Warm-up time
Power consumption
Size of laser head
Expected laser life time
532 nm   (515 nm 523, 527, 542, 555, 561, 593 nm available)
Nd:YAG, Nd:YVO4
1000, 500, 300, 200, 150, 100, 75, 50, 25, 10, 5
<2% over 8 hrs;  Ultra stable option: <0.25% over 24 hrs
<0.5%, 10Hz - 50MHz, for S- and L-version lasers
TEMoo, M2<1.1
0.36 mm (2X beam expander, beam size 0.7 mm)
2 mrad (with a 2X beam expander, divergence 1 mrad)
+/-0.005 mrad/C
Linear; Polarization ratio > 50:1; or >100:1 option
10 to 35 degree C
90-250 VAC or 9-24 VDC
1 minute
15 W
>10,000 hours (MTBF)
Model numberGCL532-xxx-S
SLM-version
GCL532-xxx-L
Low noise version
GCL532-xxx
Standard-version
Longitudinal mode
Spectrum linewidth
Coherence length
Amplitude noise, rms
Single (SLM)
<0.00001 nm
>300 meters
<0.5%
Several
0.1 nm
1-5 mm
<0.5%
Several
0.2 nm
1-3 mm
~20% at 500kHz
  CW Infrared Laser
Wavelength, nm
Max TEMoo output
Max SLM output option
Available output option
Transverse mode
Beam divergence
Polarization plane
Polarization ratio
Wavefront distortion
Longitudinal mode
      SLM version
Spectrum linewidth
      SLM version
Operating voltage
Warm-up time
Power consumption
Size of laser head
Expected life time
1064       1053 / 1047       1342      1313 / 1319 / 946      1030
3 W              2.5 W               1.5 W                 1 W               300 mW
1 W          200 mW           300 mW           200 mW          200 mW
3W, 2.5W, 2W, 1.5W, 1W, 700, 500, 300, 100, to <20 mW
TEMoo, M2<1.1
0.45 mm; 2x-9x beam expander option available
3.6 mrad; Option: a 4x beam expander reduced to <1 mrad
<1% over 2 hrs; Ultra-stable option: <0.25% over 24 hrs
+/-0.005 mrad/deg C
1064,1047,1342 nm horizontal; 1053,1313,1319,946 nm vertical
>100:1
< 1%, 10Hz - 1MHz
< l/10
Several longitudinal modes with coherence length 1 - 5 mm
Single longitudinal mode with >300 meters coherence length
0.3 nm, nominal; 0.1nm / 0.05nm narrow linewidth option
< 10-5 nm
10 to 35 deg C
1 minute
15 W, typical
3 x 3 x 12 cm with a fixed 6 mm thick base plate, or
3.6x5x18 cm / 3.6x7x20 cm (HxWxL) for high output lasers
> 10,000 hours
GMT+8, 2024-12-27 21:55 , Processed in 0.110270 second(s), 22 queries , Gzip On.
