查看: 2397|回复: 1
[编程技巧] 有关信息熵函数中pieces和j两个参数的取值问题?请各位大神讲...
发表于 2019-3-21 21:40 | 显示全部楼层 |阅读模式
%X是一个时间序列,是一个一维列向量
%Y是一个时间序列,是一个一维列向量
%pieces是将空间离散多少分,一般在数据量足够大的情况下分的越多,能够得到的信息越多
%j是一个真实想要用的时间长度大小
function [en_1_2,en_2_1]=transfer_entropy(X,Y,pieces,j)
%% parpare some data that use in reconstruction phase space
d_x=[];    sit=size(X);
templ=randperm((sit(1,1)-1));
select=templ(1:j);
d_x(:,1)=X(select+1,1);d_x(:,2)=X(select,1);d_x(:,3)=Y(select+1,1);d_x(:,4)=Y(select,1);
X_max=max(X(:,1));X_min=min(X(:,1));Y_max=max(Y(:,1));Y_min=min(Y(:,1));
delta1=(X_max-X_min)/(2*pieces);delta2=(Y_max-Y_min)/(2*pieces);
%% calculate the data disturbution p(x(t)),p(x(t+1)),P(x(t+1),x(t)),p(x(t+1),x(t),y(t)),p(x(t),y(t)),p(y(t)),p(y(t+1)),p(y(t+1))
L1=linspace(X_min+delta1,X_max-delta1,pieces);L2=linspace(Y_min+delta2,Y_max-delta2,pieces);
dist1=zeros(pieces(1,1),2);
count=0;
for q1=1:pieces
    k1=L1(q1);k2=L2(q1);
    count=count+1;
    count1=0;count2=0;
    for i=1:j
        if d_x(i,2)>=(k1-delta1) && d_x(i,2)<=(k1+delta1)
            count1=count1+1;
        if d_x(i,4)>=(k2-delta2) && d_x(i,4)<=(k2+delta2)
            count2=count2+1;
    dist1(count,1)=count1;dist1(count,2)=count2;
dist1(:,1)=dist1(:,1)/sum(dist1(:,1)); dist1(:,2)=dist1(:,2)/sum(dist1(:,2));
dist2=zeros(pieces(1,1),pieces(1,1),3);
for q1=1:pieces
    for q2=1:pieces
        k1=L1(q1);k2=L1(q2);
        k3=L2(q1);k4=L2(q2);
        count1=0;count2=0;count3=0;
        for i1=1:j
                if d_x(i1,1)>=(k1-delta1) && d_x(i1,1)<=(k1+delta1) && d_x(i1,2)>=(k2-delta1) && d_x(i1,2)<=(k2+delta1)
                    count1=count1+1;
                if d_x(i1,3)>=(k3-delta2) && d_x(i1,3)<=(k3+delta2) && d_x(i1,4)>=(k4-delta2) && d_x(i1,4)<=(k4+delta2)
                    count2=count2+1;
                if d_x(i1,2)>=(k1-delta1) && d_x(i1,2)<=(k1+delta1) && d_x(i1,4)>=(k4-delta2) && d_x(i1,4)<=(k4+delta2)
                    count3=count3+1;
        dist2(q1,q2,1)=count1;dist2(q1,q2,2)=count2;dist2(q1,q2,3)=count3;
dist2(:,:,1)=dist2(:,:,1)/sum(sum(dist2(:,:,1)));dist2(:,:,2)=dist2(:,:,2)/sum(sum(dist2(:,:,2)));dist2(:,:,3)=dist2(:,:,3)/sum(sum(dist2(:,:,3)));
dist3=zeros(pieces(1,1),pieces(1,1),pieces(1,1),2);
for q1=1:pieces
    for q2=1:pieces
        for q3=1:pieces
            k1=L1(q1);k2=L1(q2);k3=L1(q3);
            k4=L2(q1);k5=L2(q2);k6=L2(q3);
            count1=0;count2=0;
            for i1=1:j
                if d_x(i1,1)>=(k1-delta1) && d_x(i1,1)<=(k1+delta1) && d_x(i1,2)>=(k2-delta1) && d_x(i1,2)<=(k2+delta1) && d_x(i1,4)>=(k6-delta2) && d_x(i1,4)<=(k6+delta2)
                    count1=count1+1;
                if d_x(i1,3)>=(k4-delta2) && d_x(i1,3)<=(k4+delta2) && d_x(i1,4)>=(k5-delta2) && d_x(i1,4)<=(k5+delta2) && d_x(i1,2)>=(k3-delta1) && d_x(i1,2)<=(k3+delta1)
                    count2=count2+1;
            dist3(q1,q2,q3,1)=count1;dist3(q1,q2,q3,2)=count2;
dist3(:,:,:,1)=dist3(:,:,:,1)/sum(sum(sum(dist3(:,:,:,1))));dist3(:,:,:,2)=dist3(:,:,:,2)/sum(sum(sum(dist3(:,:,:,2))));
%% use the dosturbution calculate thansfer entropy
sum_f_1=0;sum_f_2=0;
for k1=1:pieces(1,1)
    for k2=1:pieces(1,1)
        if dist2(k1,k2,2)~=0 && dist1(k2,2)~=0
           sum_f_1=sum_f_1-dist2(k1,k2,2)*log2(dist2(k1,k2,2)/dist1(k2,2));
        if dist2(k1,k2,1)~=0 && dist1(k2,1)~=0
           sum_f_2=sum_f_2-dist2(k1,k2,1)*log2(dist2(k1,k2,1)/dist1(k2,1));
disp(sum_f_1);disp(sum_f_2)
sum_s_1=0;sum_s_2=0;
        for k3=1:pieces(1,1)
            if dist3(k1,k2,k3,2)~=0 && dist2(k3,k2,3)~=0
               sum_s_1=sum_s_1-dist3(k1,k2,k3,2)*log2(dist3(k1,k2,k3,2)/dist2(k3,k2,3));
            if dist3(k1,k2,k3,1)~=0 && dist2(k2,k3,3)~=0
               sum_s_2=sum_s_2-dist3(k1,k2,k3,1)*log2(dist3(k1,k2,k3,1)/dist2(k2,k3,3));
disp(sum_s_1);disp(sum_s_2)
en_1_2=sum_f_1-sum_s_1;
en_2_1=sum_f_2-sum_s_2;
GMT+8, 2025-1-30 01:25 , Processed in 0.071068 second(s), 18 queries , Gzip On.
