查看: 2113|回复: 3
[Virtual.Lab] abaqus导入到virtual lab中计算出现了问题,求助怎么解决
发表于 2019-1-18 16:34 | 显示全部楼层 |阅读模式
Import 7800 nodes
Import 5528 elements
Import 39828 nodes
Import 24592 elements
Import 26205 nodes
Import 16345 elements
Some nodes have more than one result of the same type for the selected subcase and step.
The extra results were found in 'ODB analysis result'.
  If this is an ASCII file, you could try to introduce a new step or subcase ID for this data set.
发表于 2019-2-23 09:56 | 显示全部楼层
我使用odb导入和数据转换的时候也遇到很多的报错,有空可以多交流一下
GMT+8, 2024-12-29 19:13 , Processed in 0.063269 second(s), 17 queries , Gzip On.
