查看: 2155|回复: 3
[Virtual.Lab] Trying to connect to SYSNOISE process?咋解决
发表于 2018-4-5 18:36 | 显示全部楼层 |阅读模式
XPR VERSION 11
Requested task is SYSNOISE sequential computation.
Working directory on server is C:\Users\DELL\AppData\Local\Temp
Checking that the SYSNOISE launch script (E:\Program Files\LMS\Virtual.Lab.R11\VirtualLab\Sysnoise\5.6\bin\sysnoise_nogui.bat) exists on server...
OK
SYSNOISE log file on server is C:\Users\DELL\AppData\Local\Temp\DELL-146742-sysnoise.log.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
xxxxxxxxxxxx  JOB EXECUTION START
>> ERROR :  Aborting Coupled Direct Response  procedure due to error...
**** ERROR has occurred during computation ****
You may try to compute the solution in manual mode and try to attach the results afterwards.
A FATAL ERROR OCCURRED.  PROGRAM STOPPED
我在c盘里没有发现 C:\Users\DELL\AppData\Local\Temp\DELL-146742-sysnoise.log.这到底怎么解决很着急 谢谢啦
发表于 2018-4-5 20:10 | 显示全部楼层
我也是这个问题,还没有解决
发表于 2018-4-7 12:24 | 显示全部楼层
杀毒软件?防火墙有没有阻挡?模型在其他电脑上能不能计算?
 楼主| 发表于 2018-4-8 09:57 | 显示全部楼层
阻挡的该允许的都允许了  就出现这个问题
GMT+8, 2025-1-6 12:36 , Processed in 0.073676 second(s), 17 queries , Gzip On.
