查看: 14773|回复: 32
[CFD及热分析] ansys热分析实例整理
发表于 2005-7-28 21:57 | 显示全部楼层 |阅读模式
Emp1:
  1. /GRA,POWER
  2. /NOPR                           ! set preferences for menu filtering to thermal
  3. /PMETH,OFF
  4. KEYW,PR_SET,1    !KEYW, Keyword, KEY — Sets a keyword used by the GUI for context filtering
  5. KEYW,PR_THERM,1
  6. /GO               !/GO — Reactivates suppressed printout
  7. /COM,
  8. /COM,Preferences for GUI filtering have been set to display:
  9. /COM,  Thermal  !/COM, Comment — Places a comment in the output
  10. /FILNAM,wkshop1         ! set jobname to "wkshop1"
  11. /TITLE,Workshop 1 - Basic Heat Transfer Analysis of a Fin
  12. /PREP7                        ! enter the preprocessor
  13. ET,1,PLANE55                ! define element type 3, PLANE55
  14. MP,KXX,1,10,                ! define material properties only KXX is required
  15. RECTNG,0.0,0.6,0.0,0.1, ! create fin geometry using rectangle command
  16. LSEL,S,LOC,X,0        ! select line by location x = 0
  17. LESIZE,ALL,,,1                ! set number of division on all selected  lines to 1
  18. ALLSEL,ALL                ! select everything
  19. LSEL,S,LOC,Y,0.1        ! select line by location, y = 0.1
  20. LESIZE,ALL,,,12        ! set number of divisions on all selected lines to 12
  21. ALLSEL,ALL                ! select everythinghelp,amesh
  22. LPLOT                           ! plot lines
  23. MSHAPE,0,2D                ! specify mapped meshing
  24. MSHKEY,1
  25. AMESH,ALL                ! mesh all areas
  26. FINISH                        ! exit the preprocessor
  27. /SOLU                           ! enter solution
  28. LSEL,S,LOC,X,0        ! select line at base on fin for temp loading
  29. DL,ALL,,TEMP,300        ! set temperature on line to 300
  30. ALLSEL,ALL                ! select everything
  31. LSEL,S,LOC,Y,0        ! select lower line for convection loading
  32. LSEL,A,LOC,Y,0.1        ! select top line for convection loadingsave
  33. SFL,ALL,CONV,0.4, ,80,        ! apply convection to lines, top and bottom
  34. ALLSEL,ALL                ! select everything
  35. SAVE                        ! save the databse before solution
  36. /STAT,SOLU                  ! review status before solution
  37. SOLVE                        ! execute solution
  38. FINISH                          ! exit solution
  39. /POST1                          ! begin postprocessing
  40. PLNSOL,TEMP, ,0,        ! plot nodal solution, temperature
  41. PATH,path1,2,30,20,                ! name a path, path1 !Defines a path name and establishes parameters for the path.
  42. PPATH,1,,0,0.1        ! define the coordinates of the first point on the path
  43. PPATH,2,,0.6,0.1        ! define the coordinates of the second point on the path
  44. PDEF,STAT        ! review path definition
  45. PDEF,tupper,TEMP, ,AVG                ! map data onto path
  46. PLPATH,TUPPER                        ! produce a path plot
  47. PRPATH,TUPPER                        ! list path items
  48. PLPAGM,TUPPER,1,'NODE'          ! produce a path plot on geometry
  49. PLNSOL,TF,X,0,                  ! produce plot of thermal flux in x-dir
  50. /VSCALE,1,1,0              !PLPAGM, Item, Gscale, Nopt — Displays path items along the path geometry
  51. PLVECT,TF, , , ,VECT,NODE,ON,0        ! produce a vector plot of flux
  52. PRRSOL,HEAT                         ! list reaction solution, heat
  53. qactual = 96.526                         ! define scalar parameters
  54. qideal = 0.4*2.0*0.6*(300-80)          ! calculate q ideal
  55. eta = qactual/qideal                    ! define/calculate fin efficiency
  56. SAVE                ! PLVECT, Item, Lab2, Lab3, LabP, Mode, Loc, Edge — Displays results as vectors
[ 本帖最后由 yejet 于 2006-11-13 09:10 编辑 ]
发表于 2006-11-13 09:10 | 显示全部楼层
Emp2
  1. /SHO,plots,grph
  2. /AUTO      !/AUTO, WN — Resets the focus and distance specifications to "automatically calculated
  3. /GRAP,FULL
  4. /TYP,,4    $/COM,
  5. /COM, Preferences for GUI filtering have been set to display:
  6. /COM,  Thermal     $KEYW,PR_SET,1
  7. !KEYW, Keyword, KEY — Sets a keyword used by the GUI for
  8. !context filtering
  9. KEYW,PR_THERM,1    $/FILNAM,wkshop2
  10. /TITLE,Workshop #2 - Full Power Transistor Analysis - Steady-State
  11. /PREP7                 !*  Define Geometry
  12. RECTNG,,.01,0.03+0.01+.0025,0.03+0.01+.0025+0.0075
  13. RECTNG,,.0225,0.03+0.01,0.03+0.01+.0025
  14. RECTNG,,.0225,0.03,0.03+0.01
  15. RECTNG,,.0025,,0.03
  16. RECTNG,.0075,0.0125,,0.03
  17. RECTNG,.0175,.0225,,0.03
  18. AGLU,ALL
  19. LFILLT,14,33,.0025, ,
  20. LFILLT,33,20,0.0025, ,
  21. LFILLT,18,34,0.0025, ,
  22. LFILLT,34,24,0.0025, ,
  23. AL,7,8,9
  24. AL,10,11,33
  25. AL,12,15,16
  26. AL,22,23,34
  27. ASEL,,LOC,Y,0,0.04  $AADD,ALL
  28. ! KEYOPT, ITYPE, KNUM, VALUE — Sets element key options
  29. ET,1,PLANE77                           ! 2-D 8 node thermal solid elem
  30. KEYOPT,1,1,0                           ! Consistent C matrix
  31. KEYOPT,1,3,0                           ! Planar
  32. ET,2,SURF151                           ! Thermal surface effect elem
  33. KEYOPT,2,3,0                           ! Planar
  34. KEYOPT,2,4,0                           ! Include midside node
  35. KEYOPT,2,5,1                           ! Extra node for convection
  36. KEYOPT,2,6,0                           ! Extra node is fluid temp
  37. KEYOPT,2,8,2                           ! Evaluate Hf at average temp
  38. KEYOPT,2,9,0                           ! Exclude radiation
  39. R,1                                      ! real set 1
  40. R,2                                      ! real set 2
  41. UIMP,1,DENS, , ,3500,                ! density for material 1
  42. UIMP,1,KXX, , ,50,                    ! thermal conductivity for material 1
  43. UIMP,1,C, , ,500,                    ! specific heat for material 1
  44. UIMP,2,DENS, , ,8900,                ! material 2 properties
  45. UIMP,2,KXX, , ,393,         !UIMP, MAT, Lab1, Lab2, Lab3, VAL1, VAL2, VAL3
  46. UIMP,2,C, , ,385,         !Defines constant material properties (GUI)
  47. UIMP,3,DENS, , ,2700,                ! material 3 properties
  48. UIMP,3,KXX, , ,156,
  49. UIMP,3,C, , ,963,
  50. ASEL,,LOC,Y,0.0425,0.05                ! assign attributes to area 1
  51. AATT,1,1,1
  52. ASEL,,LOC,Y,0.04,0.0425                ! assign attributes to area 2
  53. AATT,2,1,1
  54. ASEL,,LOC,Y,0,0.04                ! assign attributes to area 3
  55. AATT,3,1,1
  56. SMRT,3                                ! set smart size level 3
  57. ALLSEL                                ! select everything
  58. AMES,ALL                        ! mesh all areas
  59. LSEL,R,EXT                        ! select external lines
  60. LSEL,R,LOC,X,.001,1                ! reselect lines by location
  61. LSEL,R,LOC,Y,-1,.042
  62. NSLL,,1                            ! select nodes attached to lines
  63. ESLN                          ! select elements attached to selected nodes
  64. N,5000,,-0.01                   ! define node 5000
  65. TYPE,2        $ REAL,2         ! set meshing attributes to type 2, real 2
  66. !ESURF — Generates elements overlaid on the free faces of existing selected elements.
  67. ESURF,5000                        ! create surf151 elem, extra node is 5000
  68. ALLSEL                                ! select everything
  69. SAVE,transistor,db                ! save the database as transistor.db
  70. SAVE                                ! save the database as jobname.db
  71. /SOLUTION         !BFA, AREA, Lab, VAL1, VAL2, VAL3, PHASE — Defines a body force load on an area.
  72. BFA,1,HGEN,5333334        ! Apply heat generation to transistor
  73. SFL,2,HFLUX,1500                ! Apply heat flux to lines
  74. SFL,30,HFLUX,1500                ! Apply heat flux to lines
  75. SFL,3,HFLUX,1500
  76. ESEL,,TYPE,,2                    ! Select surf. Effect elements
  77. SFE,ALL,1,CONV,,51     ! Apply  Conv. to Surf. Eff. Elem.
  78. ALLSEL
  79. D,5000,TEMP,50                   ! Extra node fixed at ambient temp
  80. /PBC,TEMP,1             !!*  Visually verify loads
  81. /PBF,HGEN,,1            !/PSF, Item, Comp, KEY, KSHELL — Shows surface load symbols on model displays
  82. /PSF,CONV,2   $EPLO
  83. SAVE  $SOLVE  $FINISH   $/POST1
  84. ESEL,S,TYPE,,1                  ! select all type 1 ,PLANE77 elements
  85. ALLSEL,BELOW,ELEM
  86. ! select everything below the selected elements
  87. NSLE,S                          ! select nodes attached to elements
  88. PLNSOL,TEMP, ,0,                ! plot nodal solution, temperature
  89. NSORT,TEMP, ,0,0,_Z3,0          ! sort nodes based on temperature
  90. PRNSOL,TEMP,                        ! print sorted list
  91. NUSORT                          ! unsort nodes
  92. /ZOOM,1,RECT,-0.554972,0.504832,0.183702,0.968805
  93. ! zoom up on hot areas
  94. /GRAPHICS,FULL                  ! turn power graphics off
  95. ALLSEL,ALL                          ! select everything
  96. PRRSOL,HEAT                 ! print reaction solution, heat flow rate
  97. NSEL,S,TEMP,,100,106, ,0        ! select nodes by results, temperature
  98. NPLOT                           ! plot nodes for checking
  99. ESLN,S                          ! select elements attached to nodes
  100. EPLOT                           ! plot elements for checking/viewing
  101. PLNSOL,TEMP, ,0,                ! plot nodal solution, temperature
  102. /AUTO, 1      $/REP
  103. ALLSEL,ALL                         ! select everything
  104. /VSCALE,1,1,0                   ! set scaling of vectors for vector plot
  105. PLVECT,TF, , , ,VECT,ELEM,ON,0  ! produce thermal flux plot
  106. /VSCALE,1,1,0                   ! set scaling of vectors for vector plot
  107. PLVECT,TG, , , ,VECT,ELEM,ON,0  ! produce thermal gradient plot
  108. /EXPAND,2,RECT,HALF,0.00001         ! expand results
  109. ESEL,S,TYPE,,1                  ! select all type 1 elements
  110. ALLSEL,BELOW,ELEM        ! select everything below the selected elements
  111. NSLE,S                             ! select nodes attached to elements
  112. PLNSOL,TEMP,,0,           ! plot nodal solution, temperature
  113. FINISH                          ! exit the postprocessor
发表于 2006-11-13 09:11 | 显示全部楼层
Emp3:
  1. /SHO,plots3,grph
  2. /AUTO   $/GRAP,FULL
  3. /TYP,,4      $/COM,
  4. /COM, Preferences for GUI filtering have been set to display:
  5. /COM,  Thermal
  6. KEYW,PR_SET,1
  7. KEYW,PR_THERM,1
  8. /TITL, Nonlinear Thermal Analysis of a Transistor
  9. /PREP7    !*  Define Geometry
  10. RECTNG,,.01,0.03+0.01+.0025,0.03+0.01+.0025+0.0075
  11. RECTNG,,.0225,0.03+0.01,0.03+0.01+.0025
  12. RECTNG,,.0225,0.03,0.03+0.01
  13. RECTNG,,.0025,,0.03
  14. RECTNG,.0075,0.0125,,0.03
  15. RECTNG,.0175,.0225,,0.03
  16. AGLU,ALL
  17. LFILLT,14,33,.0025, ,
  18. LFILLT,33,20,0.0025, ,
  19. LFILLT,18,34,0.0025, ,
  20. LFILLT,34,24,0.0025, ,
  21. AL,7,8,9
  22. AL,10,11,33
  23. AL,12,15,16
  24. AL,22,23,34
  25. ASEL,,LOC,Y,0,0.04
  26. AADD,ALL
  27. ET,1,PLANE77           ! 2-D 8 node thermal solid elem
  28. KEYOPT,1,1,0           ! Consistent C matrix
  29. KEYOPT,1,3,0           ! Planar
  30. ET,2,SURF151           ! Thermal surface effect elem
  31. KEYOPT,2,3,0           ! Planar
  32. KEYOPT,2,4,0           ! Include midside node
  33. KEYOPT,2,5,1           ! Extra node for convection
  34. KEYOPT,2,6,0           ! Extra node is fluid temp
  35. KEYOPT,2,8,2           ! Evaluate Hf at average temp
  36. KEYOPT,2,9,0           ! Exclude radiation
  37. R,1   $R,2
  38. UIMP,1,DENS, , ,3500,
  39. UIMP,1,KXX, , ,50,
  40. UIMP,1,C, , ,500,
  41. UIMP,2,DENS, , ,8900,
  42. UIMP,2,KXX, , ,393,
  43. UIMP,2,C, , ,385,
  44. UIMP,3,DENS, , ,2700,
  45. UIMP,3,KXX, , ,156,
  46. UIMP,3,C, , ,963,
  47. ASEL,,LOC,Y,0.0425,0.05
  48. AATT,1,1,1
  49. ASEL,,LOC,Y,0.04,0.0425
  50. AATT,2,1,1
  51. ASEL,,LOC,Y,0,0.04
  52. AATT,3,1,1
  53. SMRT,3
  54. ALLSEL
  55. AMES,ALL
  56. LSEL,R,EXT
  57. LSEL,R,LOC,X,.001,1
  58. LSEL,R,LOC,Y,-1,.042
  59. NSLL,,1
  60. ESLN
  61. N,5000,,-0.01
  62. TYPE,2
  63. REAL,2
  64. ESURF,5000
  65. ALLSEL
  66. SAVE,transistor,db
  67. /COM, Input Temp-Dependent Thermal Cond Properties
  68. MPTGEN,1,4,50,50,
  69. MPDATA,KXX,1,1,53,52,47,41, , ,
  70. MPPLOT,KXX,1,,,,,
  71. /COM, Input Temp-Dependent Film Properties
  72. MPTEMP,1,50,75,100,150,175,200
  73. MPDATA,HF,4,1,18.8,17.0,16.3,14.4,12.4,6.5,
  74. MPPLOT,HF,4,,,,,
  75. FINI    $/SOLUTION
  76. SOLCONTROL,ON    ! Default at ANSYS 5.5
  77. ANTYPE,0             ! New Static analysis
  78. TUNIF,100            ! Uniform ambient starting temperature
  79. BFA,1,HGEN,5333333         ! Apply heat generation to transistor
  80. /COM,  Apply Radiative Heat Flux to Lines
  81. SFL,2,HFLUX,2400
  82. SFL,30,HFLUX,2400
  83. SFL,3,HFLUX,2400
  84. ESEL,,TYPE,,2            ! Select surf. Effect elements
  85. SFE,ALL,1,CONV,,(-4)           ! Apply Free Conv. to Surf. Eff. Elem.
  86. ALLSEL
  87. D,5000,TEMP,60           ! Extra node fixed at hotter ambient temp
  88. !*  Visually verify loads
  89. /PBC,TEMP,1
  90. /PBF,HGEN,,1
  91. /PSF,CONV,2
  92. EPLO
  93. OUTRES,ALL,ALL   ! Write results at all times for all entities
  94. TIME,1            ! Time at end of load step = 1 second
  95. AUTOTS,-1           ! Program Chosen ATS
  96. NSUB,10          ! Initial number of substeps
  97. KBC,0            ! Ramp loads
  98. CNVTOL,HEAT, ,0.0001,2    ! Tighten convergence criterion
  99. /TITL, Transistor Cooled by Free Convection
  100. SAVE
  101. SOLVE
  102. FINISH
  103. /POST1
  104. SET,LIST           ! Results summary listing
  105. SET,LAST           ! Bring in last results set
  106. ESEL,,TYPE,,1
  107. NSLE
  108. PLNS,TEMP            ! Temperature plot
  109. ESEL,,TYPE,,2
  110. ETABLE, ,NMISC,   5
  111. ETABLE, ,NMISC,   7
  112. PRETAB
  113. ESEL,,TYPE,,1
  114. NSLE
  115. SET,1,3            ! Bring in results at failure point (t=0.35)
  116. PLNS,TEMP          ! Temperature plot
  117. ALLSEL   $FINI
Emp4:
  1. /SHO,plots4,grph
  3. /TYP,,4  $/COM,
  5. /COM,  Thermal
  6. KEYW,PR_SET,1
  7. KEYW,PR_THERM,1
  8. /TITLE, Transient Thermal Analysis of a Transistor
  16. AGLU,ALL
  17. LFILLT,14,33,.0025, ,   $LFILLT,33,20,0.0025, ,
  18. LFILLT,18,34,0.0025, ,  $LFILLT,34,24,0.0025, ,
  19. AL,7,8,9    $AL,10,11,33
  20. AL,12,15,16  $AL,22,23,34
  21. ASEL,,LOC,Y,0,0.04
  22. AADD,ALL
  23. ET,1,PLANE77           ! 2-D 8 node thermal solid elem
  24. KEYOPT,1,1,0           ! Consistent C matrix
  25. KEYOPT,1,3,0           ! Planar
  26. ET,2,SURF151           ! Thermal surface effect elem
  27. KEYOPT,2,3,0          ! Planar
  28. KEYOPT,2,4,0          ! Include midside node
  29. KEYOPT,2,5,1          ! Extra node for convection
  30. KEYOPT,2,6,0          ! Extra node is fluid temp
  31. KEYOPT,2,8,2          ! Evaluate Hf at average temp
  32. KEYOPT,2,9,0          ! Exclude radiation
  33. R,1   $R,2
  34. UIMP,1,DENS, , ,3500,   $UIMP,1,KXX, , ,50,
  35. UIMP,1,C, , ,500,       $UIMP,2,DENS, , ,8900,
  36. UIMP,2,KXX, , ,393,    $UIMP,2,C, , ,385,
  37. UIMP,3,DENS, , ,2700,   $UIMP,3,KXX, , ,156,
  38. UIMP,3,C, , ,963,
  39. ASEL,,LOC,Y,0.0425,0.05  $AATT,1,1,1
  40. ASEL,,LOC,Y,0.04,0.0425   $AATT,2,1,1
  41. ASEL,,LOC,Y,0,0.04
  42. AATT,3,1,1   $SMRT,3
  43. ALLSEL  $AMES,ALL
  44. LSEL,R,EXT   $LSEL,R,LOC,X,.001,1
  45. LSEL,R,LOC,Y,-1,.042
  46. NSLL,,1   $ESLN    $N,5000,,-0.01
  47. TYPE,2    $REAL,2
  48. ESURF,5000    $ALLSEL   $FINI
  49. SAVE,transistor,db
  50. /SOLUTION
  51. SOLCONTROL,ON             ! Default at ANSYS 5.5
  52. ANTYPE,4             ! New Transient analysis
  53. TRNOPT,FULL           ! Use full method
  54. EQSLV,ITER,5            ! automatic solver and direct assembly
  55. TUNIF,50             ! Uniform ambient starting temperature
  56. BFA,1,HGEN,2666667           ! Apply heat generation to transistor
  57. /COM,  Apply Radiative Heat Flux to Lines
  58. SFL,2,HFLUX,1500    $SFL,30,HFLUX,1500
  59. SFL,3,HFLUX,1500
  60. ESEL,,TYPE,,2            ! Select surf. Effect elements
  61. SFE,ALL,1,CONV,,30        ! Apply LP Fan Conv. to Surf. Eff. Elem.
  62. ALLSEL
  63. D,5000,TEMP,50           ! Constrain extra node temp to ambient temp
  64. !*  Visually verify loads
  65. /PBC,TEMP,1   $/PBF,HGEN,,1
  66. /PSF,CONV,2   $EPLO
  67. OUTRES,ALL,ALL            ! Write results at all times for all entities
  68. TIME,1            ! Time at end of load step = 1 second
  69. AUTOTS,-1         ! Program Chosen ATS
  70. DELTIM,.01,.0025,60,0            ! INITIAL, MIN, MAX time step
  71. KBC,0    ! Ramp loads
  72. !KBC, KEY — Specifies stepped or ramped loading within a load step
  73. TINTP,,,,0.75,0.5,0.1           ! THETA=0.75, OSC=0.5, TOL=0.1
  74. !TINTP— Defines transient integration parameters.
  75. /COM, MONITOR,3,5000,HEAT  ! Does not work at 5.5.1
  76. SAVE,tabular,db
  77. /TITL, LS 1 - Transistor Activation (1 second)
  78. SAVE   $SOLVE
  79. TIME,300           ! Time at end of load step = 300 seconds
  80. /TITL, LS 2 - Low Power Operation (300 seconds)
  81. SOLVE
  82. /TITL, LS 3 - High Power Load Ramp (302 seconds)
  83. SFSCALE,CONV,1.7             ! Scale convection hf by 1.7 for high power
  84. BFA,1,HGEN,2666667*2    ! Transistor heat generation
  85. TIME,302            ! Time at end of load step = 302 seconds
  86. SOLVE
  87. /TITL, LS 4 - High Power Operation (900 seconds)
  88. TIME,900            ! Time at end of load step = 900 seconds
  89. SOLVE
  90. /TITL, LS 5 - High Power Operation - Steady State
  91. AUTOTS,OFF            ! Turn off automatic time stepping
  92. NSUB,1            ! one substep
  93. TIME,1000           ! Time at end of load step = 1000 seconds
  94. TIMINT,OFF            ! Turn off time integration
  95. SOLVE   $FINISH    $/POST1
  96. SET,2           ! Bring in results at time = 300 seconds
  97. ESEL,,TYPE,,1    $NSLE
  98. PLNS,TEMP            ! Temperature plot
  99. ALLSEL
  100. SET,5            ! Bring in steady state results
  101. PRRS             ! List reaction heat flow
  102. FINISH    $/POST26
  103. /TITL,
  104. KSEL,,,,KP(0.01,0.05,0)
  105. NSLK
  106. *GET,N1,NODE,,NUM,MAX   ! High Temp Node Number
  107. ALLSEL
  108. NSOL,2,N1,TEMP, ,TEMP_MAX  ! Max temp variable
  109. SOLU,3,DTIME, ,TIME_STP    ! Time step variable
  110. SOLU,4,RESEIG, ,RESP_EIG   ! Response eigenvalue
  111. PROD,5,3,4, ,OSC, , ,1,1,1,! Calculate oscillation limit
  112. /COM, Calculate lumped mass approximation
  113. FILLDATA,7,1, ,1,94.144,0,
  114. EXP,8,1, , ,TERM1, , ,-.002655,-44.144,
  115. ADD,9,7,8, ,CALC_10W, , ,1,1,1,
  116. FILLDATA,10,1,,1,97.165,0
  117. ! Steady-state High Power Temperature line
  118. /GTHK,CURVE,2
  119. /GRID,1
  120. /AXLAB,X,Time (s)
  121. /GTHK,AXIS,2  !/GTHK, Label, THICK — Sets line thicknesses for graph lines.
  122. /GROPT,AXDV,1 !GROPT, Lab, KEY — Sets various line graph display options
  123. /GROPT,AXNM,ON
  124. /GROPT,AXNSC,1,
  125. /GROPT,DIG1,4,
  126. /GROPT,DIG2,0,
  127. /GROPT,LTYP,1
  128. /XRANGE,0,1000 !/XRANGE, XMIN, XMAX — Specifies a linear abscissa (X) scale range
  129. /YRANGE,DEFAULT,,1
  130. /AXLAB,Y,Temperature (C) !/AXLAB, Axis, Lab — Labels the X and Y axes on graph displays.
  131. PLVAR,2,9,10            ! Plot Max T, Calc T, and SS T variables
  132. PRVAR,3            ! List time step variable
  133. /AXLAB,Y,Oscillation Limit
  134. PLVAR,5            ! Plot Oscillation limit variable
  135. Fini
发表于 2006-11-13 09:12 | 显示全部楼层
Emp5:
  1. ! Transient Thermal Analysis of a Transistor - Tabular Loads
  2. !TRANSIENT ANALYSIS OF TRANSISTOR USING TABULAR LOADS
  3. !STARTING FROM tabular.db CREATED IN WORKSHOP 4
  4. !tabular.db HAS SOLID MODEL, FEA MODEL, ALL LOADS FOR
  5. !FIRST LOAD STEP, TRANSIENT ANALYSIS DEFINED, INITIAL T,
  6. !SOLUTION CONTROLS ON, ITERATIVE SOLVER, OUTPUT CONTROLS,
  7. !DELTIM, AND TIME INTEGRATION CONTROLS DEFINED
  8. RESUME,tabular,db
  9. !INTO THE SOLUTION PROCESSOR
  10. /SOLU
  11. !DELETE LOADS CURRENTLY APPLIED TO THE MODEL
  12. BFADELE,ALL,ALL
  13. ! REMOVES THE HEAT GENERATION ON AREAS
  14. SFLDELE,ALL,ALL  ! REMOVES RADIATION FLUX ON LINES
  15. !BFADELE, AREA, Lab — Deletes body force loads on an area
  16. SFEDELE,ALL,ALL,ALL !REMOVES THE Hf DEFINITION FOR THE
  17. !SURFACE EFFECT ELEMENTS BUT LEAVES
  18. !HE Tb DEFINITION(50 degrees) ON
  19. !THE EXTRA NODE(NODE NUMBER 5000)
  20. *DIM,TIMESET,ARRAY,3 !DEFINE ARRAY FOR TIME STEP RESET
  21. TIMESET(1)=1.0,300,302
  22. *DIM,HEATGEN,TABLE,5,TIME
  23. ! DEFINE TABLE FOR HEAT GEN.=F(T)
  24. HEATGEN(1,0)=1.E-6,1.0,300,302,900
  25. HEATGEN(1,1)=0.0,2666667,2666667,2*2666667,2*2666667
  26. *DIM,CONVHF,TABLE,5,TIME           ! DEFINE TABLE FOR Hf=G(T)
  27. CONVHF(1,0)=1.E-6,1.0,300,302,900
  28. CONVHF(1,1)=30,30,30,51,51
  29. *DIM,HEATFLX,TABLE,3,TIME
  30. ! DEFINE TABLE FOR HFLUX=Q(T)
  31. HEATFLX(1,0)=1.E-6,1.0,900
  32. HEATFLX(1,1)=0.0,1500,1500
  33. /TITLE,Transistor Analysis Using Tabular Input
  34. TIME,900
  35. !DEFINE COMPONENTS(NOT NECESSARY), APPLY TABULAR BCS
  36. !TO THE COMPONENTS
  37. ASEL,S,AREA,,1                  ! SELECT TRANSISTOR AREA
  38. ALLSEL,BELOW,AREA
  39. ! SELECT ELEMENTS ASSOCIATED WITH AREA
  40. CM,TRANAREA,ELEMENT
  41. !CM, Cname, Entity — Groups geometry items into a component
  42. ALLSEL,ALL
  43. LSEL,S,LINE,,2,3,1    ! SELECT LINES FOR RADIATION FLUX
  44. LSEL,A,LINE,,30
  45. CM,FLUXLINE,LINE      ! CREATE COMPONENT
  46. ESEL,S,ENAME,,SURF151
  47. ! SELECT ELEMENTS FOR CONVECTION
  48. CM,CONVELEM,ELEMENT        ! CREATE COMPONENT
  49. ALLSEL,ALL
  50. !APPLY LOADS USING COMPONENT NAMES
  51. BFE,TRANAREA,HGEN,1,%HEATGEN%
  52. ! HEAT GENERATION
  53. SFL,FLUXLINE,HFLUX,%HEATFLX%          ! RADIATION FLUX
  54. SFE,CONVELEM,1,CONV,,%CONVHF%          ! CONVECTION HF
  55. !FORCE TIME STEP RESET AT LOAD CHANGE POINTS
  56. TSRES,%TIMESET%   $SOLVE
  57. FINISH     $/POST26
  58. KSEL,,,,KP(0.01,0.05,0)   $NSLK
  59. *GET,N1,NODE,,NUM,MAX
  60. NSOL,2,N1,TEMP,,TEMP_MAX
  61. FINI
Emp6:
  1. ! ANSYS 5.5 Heat Transfer Seminar Notes  ! Workshop #6
  2. ! Low Pressure Gas Turbine Case Thermal Analysis
  3. ! MUST HAVE case.db AND work6excel.txt TO RUN
  4. RESUME,case,db    ! Supplied with seminar files
  5. /TITLE, Low Pressure Gas Turbine Case Thermal Analysis
  6. !*  SET PREFERENCES TO THERMAL AND FLUID/PMETH,OFF
  7. KEYW,PR_SET,1      $KEYW,PR_THERM,1
  8. KEYW,PR_FLUID,1   $KEYW,PR_MULTI,1
  9. /COM,
  10. /COM,Preferences for GUI filtering have been set to display:
  11. /COM,  Thermal  $/COM,  ANSYS Fluid
  12. /PREP7  !DEFINE THE SURF151 AND FLUID116 TYPES
  13. ET,2,SURF151   $ET,3,FLUID116
  14. KEYOPT,2,3,1   $KEYOPT,2,4,1
  15. KEYOPT,2,5,1   ! KEYOPTIONS FOR SURF151s
  16. KEYOPT,2,6,0    $KEYOPT,2,8,2
  17. KEYOPT,2,9,0
  18. KEYOPT,3,1,1         ! KEYOPTIONS FOR FLUID116s
  19. KEYOPT,3,2,1   $ETLIST, ALL
  20. MPLIST    ! LIST PREDEFINED TEMP-DEPENDENT MPs
  21. ! REAL SET FOR FLUID116
  22. PI=ACOS(-1)   $R,2
  23. R,3,,1E-6,           ! Diameter, area, # channels
  24. !CREATE KEYPOINTS 112,113,114 ON WP
  25. K,,16.7628783879,145.253628512,0
  26. K,,16.4392239406,146.100950574,0
  27. K,,16.6407907696,147.310654059,0
  28. !CREATE LINES FOR FLUID ELEMENTS
  29. LSTR, 112, 113  $LSTR, 113, 114
  30. !SET ELEMENT ATTRIBUTES FOR THE LINES
  31. LSEL, , , ,91,92  $LATT,20,3,3,0, , ,
  32. !SET ELEMENT DIVISIONS TO ONE FOR
  33. !FLUID LINES
  34. LESIZE,ALL, , ,1,1
  35. !MESH LINES WITH FLUID116
  36. LMESH,ALL   $CMLIST
  37. ! LIST PREDEFINED LINE COMPONENTS
  38. !CREATE SUR151S FOR ZONE 101
  39. CMSEL,S,LZONE101
  40. LPLOT  $NSLL,S,1  $NPLOT
  41. TYPE,2  $MAT,1   $REAL,2
  42. ESURF,380    ! NODE 380 IS POINT A AND EXTRA NODE
  43. ESEL,R,ENAME,,151
  44. !CREATE A COMPONENT FOR SURF151 ON ZONE101
  45. CM,SURF101,ELEM
  46. ESEL,ALL   $ESEL,U,TYPE,,2
  47. ! REPEAT FOR ZONE 102
  48. CMSEL,S,LZONE102
  49. LPLOT   $NSLL,S,1  $NPLOT
  50. ESURF,380   $ESEL,R,TYPE,,2
  51. CM,SURF102,ELEM
  52. ESEL,ALL   $ESEL,U,TYPE,,2
  53. !REPEAT FOR ZONE 103
  54. CMSEL,S,LZONE103
  55. LPLOT  $NSLL,S,1  $NPLOT
  56. ESURF,381             ! NODE 381 IS AT POINT B
  57. ESEL,R,TYPE,,2   $CM,SURF103,ELEM
  58. ESEL,ALL   $ESEL,U,TYPE,,2
  59. CMSEL,S,LZONE104
  60. NSLL,S,1  $ NPLOT
  61. !NSLL,Type,NKEY , Selects those nodes associated with the selected lines
  62. ESURF,382   ! NODE 382 IS AT POINT C
  63. ESEL,R,TYPE,,2   $CM,SURF104,ELEM
  64. ESEL,ALL  $NSEL,ALL
  65. !DIMENSION THE TABLE FOR HF FOR ZONE104
  66. *DIM,HF104,TABLE,4,5,1,TIME,Y,
  67. !READ IN THE EXCEL SPREADSHEET
  68. *TREAD,HF104,work6excel,txt,,4,
  69. ALLSEL,ALL    $LPLOT
  70. !SELECT THE LINES WHERE COUPLING IS NEEDED
  71. FLST,5,8,4,ORDE,8
  72. !FLST,NFIELD,NARG,TYPE,Otype,LENG
  73. !Specifies data required for a picking operation .
  74. FITEM,5,16 !FITEM,NFIELD,ITEM,ITEMY,ITEMZ—Identifies items chosen by a picking operation
  75. FITEM,5,29  $FITEM,5,41  $FITEM,5,57  $FITEM,5,60
  76. FITEM,5,80  $FITEM,5,88  $FITEM,5,-89
  77. LSEL,S, , ,P51X !CREATE COMPONENT OF LINES AT INTERFACE
  78. CM,LINTERFA,LINES  $/REPLOT
  79. NSLL,S,1   $NPLOT
  80. !CHECK THE DISTANCE BETWEEN NODES TO
  81. !SET TOLERANCE FOR COUPLING
  82. NDISTANCE,136,15   !CREATE THE COUPLING EQUATIONS
  83. CPINTF,TEMP,0.005,    $ALLSEL,ALL
  84. FINI  $/SOLUTION  $SOLCONTROL,ON,0
  85. !SELECT COMPONENT SURF101
  86. CMSEL,S,SURF101
  87. SFE,ALL,1,CONV, , %HF101%  ! APPLY TABULAR Hf
  88. SFE,ALL,1,CONV,2,       !SELECT COMPONENT SURF102
  89. CMSEL,S,SURF102
  90. SFE,ALL,1,CONV, , %HF102%  ! APPLY TABULAR Hf
  91. SFE,ALL,1,CONV,2,       !SELECT COMPONENT SURF103
  92. CMSEL,S,SURF103
  93. SFE,ALL,1,CONV, , %HF103%  ! APPLY TABULAR Hf
  94. SFE,ALL,1,CONV,2,       !SELECT COMPONENT SURF104
  95. CMSEL,S,SURF104
  96. SFE,ALL,1,CONV, , %HF104%  ! APPLY TABULAR Hf
  97. SFE,ALL,1,CONV,2,
  98. !SELECT COMPONENT LZONE105 (LINES IN ZONE105)
  99. CMSEL,S,LZONE105        !APPLY TABULAR Hf AND Tb
  100. SFL,ALL,CONV, %HF105% , , %TB05T09%
  101. !SELECT COMPONENT LZONE106
  102. CMSEL,S,LZONE106        !APPLY TABULAR Hf AND Tb
  103. SFL,ALL,CONV, %HF106% , , %TB05T09%
  104. !SELECT COMPONENT LZONE107
  105. CMSEL,S,LZONE107   !APPLY TABULAR Hf AND Tb
  106. SFL,ALL,CONV, %HF107% , , %TB05T09%
  107. !SELECT COMPONENT LZONE108
  108. CMSEL,S,LZONE108    !APPLY TABULAR Hf AND Tb
  109. SFL,ALL,CONV, %HF108% , , %TB05T09%
  110. !SELECT COMPONENT LZONE109
  111. CMSEL,S,LZONE109    !APPLY TABULAR Hf AND Tb
  112. SFL,ALL,CONV, %HF109% , , %TB05T09%
  113. ALLSEL,ALL      !DEFINE TABLE ARRAYS FOR INLET FLUID
  114. !TEMPERATURE AND MASS FLOW RATES
  115. !IN THE TWO FLUID116S
  116. *DIM,TINLET,TABLE,4,1,1,TIME, ,
  117. *DIM,FLOWAB,TABLE,4,1,1,TIME, ,
  118. *DIM,FLOWBC,TABLE,4,1,1,TIME, ,
  119. TINLET(1,0,1) = 0    $TINLET(1,1,1) = 304.33
  120. TINLET(2,0,1) = 3    $TINLET(2,1,1) = 870.33
  121. TINLET(3,0,1) = 160  $TINLET(3,1,1) = 870.33
  122. TINLET(4,0,1) = 163  $TINLET(4,1,1) = 304.33
  123. FLOWAB(1,0,1) = 0   $FLOWAB(1,1,1) = 0.001
  124. FLOWAB(2,0,1) = 3   $FLOWAB(2,1,1) = 0.0042
  125. FLOWAB(3,0,1) = 160  $FLOWAB(3,1,1) = 0.0042
  126. FLOWAB(4,0,1) = 163  $FLOWAB(4,1,1) = 0.001
  127. FLOWBC(1,0,1) = 0    $FLOWBC(1,1,1) = 0.000692
  128. FLOWBC(2,0,1) = 3    $FLOWBC(2,1,1) = 0.002908
  129. FLOWBC(3,0,1) = 160  $FLOWBC(3,1,1) = 0.002908
  130. FLOWBC(4,0,1) = 163  $FLOWBC(4,1,1) = 0.000692
  131. LPLOT     $/AUTO, 1   $/REP
  132. !SPECIFY INLET FLUID TEMPERATURE
  133. !AT NODE 380 AS TABULAR INPUT
  134. D,380,TEMP,%TINLET%
  135. !SPECIFY MASS FLOW RATE ON FLUID116
  136. !FROM A TO B, USING HFLUX
  137. SFE,252,,HFLUX, ,%FLOWAB%
  138. SFELIS,252,HFLUX  !SPECIFY MASS FLOW RATE FROM B TO C
  139. SFE,253,,HFLUX, ,%FLOWBC%  $SFELIS,253,HFLUX
  140. ANTYPE,0        ! ANALYSIS TYPE STEADY-STATE
  141. TIME,1.E-6         ! TIME AT END OF STEADY-STATE
  142. NSUB,1       ! ONE SUBSTEP
  143. ALLSEL
  144. SOLVE         ! RUN STEADY-STATE
  145. SAVE        ! SAVE THE DATABASE FOR RESTART
  146. FINISH   $/POST1
  147. PLNSOL,TEMP         ! REVIEW THERMAL CONTOURS
  148. FINISH   $RESUME   $/SOLU
  149. ANTYPE,,REST  $TIMINT,ON
  150. !DT_START = DX**2/(10 x ALPHA) = 0.05 seconds
  151. DELTIM,0.05,0.005,10,0
  152. KBC,0       ! RAMP LOADS
  153. TIME,163
  154. !DEFINE THE ARRAY TO USE FOR TIME STEP SIZE RESET
  155. *DIM,TSTEP,ARRAY,2,1,1, , ,
  156. TSTEP(1,1,1)=3   $TSTEP(2,1,1)=160
  157. TSRES,%TSTEP%    ! USE TSTEP ARRAY
  158. OUTRES,NSOL,ALL  $SAVE
  159. SOLVE   $FINI
发表于 2006-11-13 09:13 | 显示全部楼层
Emp7:
  1. /filn,stltube     ! db created in Ch. 3 (ch3_ex.inp will create)
  2. RESU
  3. /PREP7
  4. ACLEAR,ALL        ! Clear thermal mesh
  5. EDEL,ALL        ! Delete surface effect elements
  6. NDEL,ALL        ! Delete extra node
  7. ETDEL,1        ! Delete element type 1 (thermal solids)
  8. ETDEL,2        ! Delete element type 2 (surface effect elements)
  9. FINISH  $/SOLU
  10. LSCLEAR,ALL    ! Clear all thermal loads
  11. FINISH
  12. /filn,stress        ! Change jobname to STRESS
  13. /PREP7
  14. /TITL, THERMAL-STRESS ANALYSIS OF STEEL TUBE WITH FINS
  15. /NOPR  !/NOPR,Suppresses the expanded interpreted input data listing.
  16. /PMETH,OFF
  17. KEYW,PR_SET,1   !KEYW,Keyword,KEY—Sets a keyword used by the GUI for context filtering
  18. KEYW,PR_STRUC,1  $KEYW,PR_THERM,1
  19. KEYW,PR_MULTI,1
  20. /GO   $/COM,
  21. /COM,Preferences for GUI filtering have been set to display:
  22. /COM,Structural   $/COM,Thermal
  23. ET,1,PLANE82          ! 8 node structural planar solid
  24. KEYOPT,1,3,1    ! Axisymmetric option
  25. !INPUT Structural MPs
  26. UIMP,1,EX, , ,28E6   $UIMP,1,DENS, , ,0.00073
  27. UIMP,1,ALPX, , ,5E-6 $UIMP,1,NUXY, , ,0.3
  28. !Add 0.075 Fillet Radius in Corner
  29. LFILLT,12,15,.075  $AL,2,4,5
  30. AADD,ALL $NUMC,ALL
  31. TYPE,1   $MAT,1  $REAL,1
  32. SMRT,3   $MSHKEY,0
  33. AMESH,ALL        ! Mesh model
  34. NWRITE        ! Write node file (stltube.nod)
  35. SAVE   $FINI
  36. /FILN,stltube        ! Resume thermal model
  37. RESU  $ALLSEL  $/POST1
  38. SET,LAST   ! Read in thermal results set
  39. BFINT,stress,node,,,,,0,,0,1          ! Perform body load interp.
  40. FINI  $/FILN,stress        ! Resume structural model
  41. RESU  $ALLSEL   $/SOLU
  42. /INPUT,stltube,bfin,,,0        ! Read in body load temps (stltube.bfin)
  43. /PBF,TEMP,1   $EPLO        ! Check temperature loads
  44. ! Specify Analysis Settings and Other Loads
  45. ANTYPE,0  $TREF,70
  46. OMEGA,,2500,   $DL,1, ,SYMM
  47. DL,8, ,SYMM    $DL,3, ,SYMM
  48. SFL,5,PRES,1500   $SFL,7,PRES,1500
  49. SAVE   $SOLVE   $FINI
  50. ! POSTPROCESS WITH TEMPS
  51. /POST1
  52. PLNS,S,EQV   $PLES,SDSG
  53. PLNS,EPTH,Z  $PLNS,EPEL,Z
  54. FINI          $/SOLU
  55. ANTY,,REST   !Restart Solution and run w/o Temps
  56. BFDELE,ALL,TEMP
  57. /TITL, NO TEMPERATURE LOAD
  58. SOLVE    $FINI
  59. !POSTPROCESS W/O TEMPS
  60. /POST1    SET,LAST   $PLNS,BFE,TEMP
  61. PLNS,S,EQV  $FINI
发表于 2006-11-14 11:09 | 显示全部楼层
楼主能不能说下做的什么热分析
发表于 2006-11-14 11:10 | 显示全部楼层
我也是感觉这么好的例子应该有些说明,当然了,大家谁知道的可以写下自己的理解
有奖励哟
发表于 2006-11-14 12:44 | 显示全部楼层
是呀,感觉看起来好累。谁有时间看1遍再运行一下,把说明和注释加上就好了。
发表于 2006-11-14 18:53 | 显示全部楼层
我也觉得楼主如果能够做一下这些例子的相关介绍就更好了,很感谢楼主的分享!
发表于 2006-12-11 15:40 | 显示全部楼层
感谢楼主,但没有文字说明,还是感到有点麻烦。
发表于 2006-12-12 10:20 | 显示全部楼层
请问楼主有没有LS-DYNA的热分析例子啊,大哥们知不知道我下面这段热分析命令是什么问题啊,分析时总是显示
The LS-DYNA time step size should not exceed     0.651E-06
to avoid contact instabilities.  If the step size is
bigger then scale the penalty of the offending surface.
time step larger than problem time
热分析时间设置
*CONTROL_THERMAL_TIMESTEP
         1       1.0       5.0         0         0      20.0
*CONTROL_CONTACT
                   5                                                           1
*CONTROL_SOLUTION
         2
*CONTROL_THERMAL_NONLINEAR
        10       0.0       0.5
*CONTROL_THERMAL_SOLVER
         1         0         3      1E-4         0         1       0.9
         1       1.0       5.0         0         0      20.0
*INITIAL_TEMPERATURE_SET
        10        20
        11        20
*SET_NODE_GENERAL
      PART         1
*SET_NODE_GENERAL
        11
      PART         2
*BOUNDARY_TEMPERATURE_SET
        10         0        20
        11         0        20
*MAT_THERMAL_ISOTROPIC(钢)
         1   7.80E+6         0         0
       480      4.62
*CONTROL_TIMESTEP
    0.0000    0.9000         0  0.00      0.00
*CONTROL_TERMINATION
0.500E-03         0   0.00000   0.00000   0.00000
$                                 TIME HISTORY                                 $
*DATABASE_BINARY_D3PLOT
0.5000E-06
*DATABASE_BINARY_D3THDT
0.100E-07
发表于 2006-12-17 12:02 | 显示全部楼层
期待大侠整理一下
附加点说明
发表于 2006-12-17 13:06 | 显示全部楼层
呵呵,资料是很不错,不过要是能给每个例子附加上一个简短的说明就好了,至少说明一下所给出例题的模型是怎么样的,不然看起来就太费劲了呀。
GMT+8, 2025-1-6 15:02 , Processed in 0.071540 second(s), 21 queries , Gzip On.
