查看: 1328|回复: 2
[Virtual.Lab] 13.6版本计计算噪声传递函数
发表于 2018-1-10 10:45 | 显示全部楼层 |阅读模式
各位大神们:好!
       我是初学者,在计算NTF时出现"The Mesh Mapping contains mapped Acoustical nodes from some envelope faces for which other linked nodes are not mapped. Those mapped modes will be igored for the coupling. Any paneks using such ignored nodes must be modified.You can create a 'Group from feature' on the mesh mapping(include the nodes!)to find out which faces are not completely included by mapped nodes"的问题,怎么解决,谢谢啦!
发表于 2018-1-10 16:50 | 显示全部楼层
检查下耦合面参数的设置,保证所有的声学节点都耦合上。
 楼主| 发表于 2018-1-11 09:26 | 显示全部楼层
GMT+8, 2025-1-7 22:28 , Processed in 0.053564 second(s), 18 queries , Gzip On.
